InboundCall on E1 port
Hi all ,
I have CUCM v9.1 and  Cisco2921 as a MGCP gateway to access PSTN through two E1 ports. I don't have a problem on Outbound call.
For inbound call ,
My number of E1 is 269408XX ,  the extension schema of ip phones is 08XX , but I can't make a call and this error comes out.
debug isdn q931 is              ON.
MGCP-VG#
Jan  6 12:56:24.099: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0380
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839E
                Exclusive, Channel 30
        Calling Party Number i = 0x0183, '01007969096'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0xC1, '26940809'
                Plan:ISDN, Type:Subscriber(local)
        Sending Complete
Jan  6 12:56:24.559: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8380
        Cause i = 0x8081 - Unallocated/unassigned number
MGCP-VG#
1 ACCEPTED SOLUTION
You should have Inbound CSS containing the partition of those extensions.
ex: lets say if the extensions are in 'PT_Extn' partition then create a css as 'CSS_Inbound' add the 'PT_Extn' to it. Assign the CSS to GW for 'Call Routing Information - Inbound Calls'
//Suresh Please rate all the useful posts.
Please check the significant digits & the CSS fiedld on the MGCP endpoint configuration
The significant digits are 4
ok, that should be fine. you have the right inbound css assigned?
also do you apply any translation pattern for these inbound calls before routing them to the ip phones?
No , i don't have any inbound CSS assigned and i didn't apply any translation pattern .
I think I don't need translation pattern becuase i use this schema on ip phones 08XX ,
It is working  , thanks very much
Good to know it is working fine now. Thanks for the rating.
This look like partition/css issue. Check this thread - https://supportforums.cisco.com/thread/2007133.
Manish
197
