Incoming Call Dial-Peer
I can't seem to get my CME to route my incoming calls to my phones.  I would like to have 1001 and 1002 both ring when the telephone # is dialed.  Can you please help me figure out what is wrong?  I can call out just fine, just not able to receive any calls.  Cisco 2821 / C2800NM-ADVENTERPRISEK9-M Version 15.1(4)M8 / CME 8.0 / Phone = 7975
DID # = 7852465184 and 9137129524
Building configuration...
Current configuration : 8366 bytes
! Last configuration change at 23:48:10 CST Sun Jun 29 2014 by woodjl1650
! NVRAM config last updated at 23:48:11 CST Sun Jun 29 2014 by woodjl1650
version 15.1
hostname CME
boot-start-marker
boot system flash:c2800nm-adventerprisek9-mz.151-4.M8.bin
boot system flash:c2800nm-ipvoice_ivs-mz.151-3.T2.bin
boot-end-marker
aaa new-model
aaa session-id common
clock timezone CST -6 0
clock summer-time CST recurring
dot11 syslog
no ip source-route
no ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.20
ip dhcp excluded-address 192.168.1.200 192.168.1.252
ip dhcp pool HomeLAN
 network 192.168.1.0 255.255.255.0
 domain-name jjkkcc.org
 default-router 192.168.1.2
 dns-server 209.244.0.3 8.8.8.8 4.2.2.2
 option 150 ip 192.168.1.2
ip domain name jjkkcc.org
ip name-server 8.8.8.8
ip name-server 4.2.2.2
no ipv6 cef
voice rtp send-recv
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 sip
  registrar server expires max 120 min 60
  localhost dns:sip.flowroute.com
  outbound-proxy dns:sip.flowroute.com
  early-offer forced
  midcall-signaling passthru
  sip-profiles 100
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729r8
voice class sip-profiles 100
 response ANY sdp-header Audio-Attribute modify "sendonly" "sendrecv"
 request ANY sdp-header Audio-Attribute modify "sendonly" "sendrecv"
voice-card 0
 dspfarm
license udi pid CISCO2821 sn FTX1033A2QR
username woodjl1650 privilege 15 secret 5 $1$U/hT$kJDcp7OubFSJG6YaU1w82.
redundancy
interface GigabitEthernet0/0
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 192.168.1.2 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
no ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list NAT interface GigabitEthernet0/0 overload
ip nat inside source static tcp 192.168.1.6 80 interface GigabitEthernet0/0 80
ip nat inside source static tcp 192.168.1.6 32400 interface GigabitEthernet0/0 32400
ip nat inside source static tcp 192.168.1.16 4040 interface GigabitEthernet0/0 4040
ip nat inside source static tcp 192.168.1.250 443 interface GigabitEthernet0/0 443
ip access-list standard NAT
 permit 192.168.1.0 0.0.0.255
tftp-server flash:apps11.8-5-3TH1-6.sbn
tftp-server flash:cnu11.8-5-3TH1-6.sbn
tftp-server flash:cvm11sccp.8-5-3TH1-6.sbn
tftp-server flash:dsp11.8-5-3TH1-6.sbn
tftp-server flash:jar11sccp.8-5-3TH1-6.sbn
tftp-server flash:SCCP11.8-5-3S.loads
tftp-server flash:term06.default.loads
tftp-server flash:term11.default.loads
tftp-server flash:MISCH-1.3.3.SBN
tftp-server flash:CP7921G-1.3.3.LOADS
tftp-server flash:CP7925G-1.3.3.LOADS
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:SCCP42.8-5-3S.loads
tftp-server flash:term31.default.loads
tftp-server flash:term41.default.loads
tftp-server flash:term45.default.loads
tftp-server flash:term61.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:term70.default.loads
tftp-server flash:term71.default.loads
tftp-server flash:term75.default.loads
tftp-server flash:SCCP31.8-5-3S.loads
tftp-server flash:SCCP41.8-5-3S.loads
tftp-server flash:SCCP45.8-5-3S.loads
tftp-server flash:SCCP70.8-5-3S.loads
tftp-server flash:SCCP75.8-5-3S.loads
tftp-server flash:SCCP69xx.8-5-3-0.loads
tftp-server flash:apps37sccp.1-3-4-0.bin
tftp-server flash:apps31.8-5-3TH1-6.sbn
tftp-server flash:apps42.8-5-3TH1-6.sbn
tftp-server flash:apps45.8-5-3TH1-6.sbn
tftp-server flash:apps75.8-5-3TH1-6.sbn
tftp-server flash:apps41.8-5-3TH1-6.sbn
tftp-server flash:apps70.8-5-3TH1-6.sbn
tftp-server flash:APPSH-1.3.3.SBN
tftp-server flash:APPS-1.3.3.SBN
tftp-server flash:SYSH-1.3.3.SBN
tftp-server flash:cvm70sccp.8-5-3TH1-6.sbn
tftp-server flash:cvm41sccp.8-5-3TH1-6.sbn
tftp-server flash:cvm45sccp.8-5-3TH1-6.sbn
tftp-server flash:cvm75sccp.8-5-3TH1-6.sbn
tftp-server flash:cvm31sccp.8-5-3TH1-6.sbn
tftp-server flash:cvm42sccp.8-5-3TH1-6.sbn
tftp-server flash:SYS-1.3.3.SBN
tftp-server flash:WLANH-1.3.3.SBN
tftp-server flash:GUIH-1.3.3.SBN
tftp-server flash:jar75sccp.8-5-3TH1-6.sbn
tftp-server flash:jar45sccp.8-5-3TH1-6.sbn
tftp-server flash:GUI-1.3.3.SBN
tftp-server flash:jar70sccp.8-5-3TH1-6.sbn
tftp-server flash:jar42sccp.8-5-3TH1-6.sbn
tftp-server flash:jar41sccp.8-5-3TH1-6.sbn
tftp-server flash:jar31sccp.8-5-3TH1-6.sbn
tftp-server flash:WLAN-1.3.3.SBN
tftp-server flash:TNUXH-1.3.3.SBN
tftp-server flash:TNUX-1.3.3.SBN
tftp-server flash:dsp41.8-5-3TH1-6.sbn
tftp-server flash:dsp70.8-5-3TH1-6.sbn
tftp-server flash:cnu45.8-5-3TH1-6.sbn
tftp-server flash:cnu42.8-5-3TH1-6.sbn
tftp-server flash:cnu75.8-5-3TH1-6.sbn
tftp-server flash:cnu31.8-5-3TH1-6.sbn
tftp-server flash:cnu70.8-5-3TH1-6.sbn
tftp-server flash:cnu41.8-5-3TH1-6.sbn
tftp-server flash:dsp31.8-5-3TH1-6.sbn
tftp-server flash:dsp42.8-5-3TH1-6.sbn
tftp-server flash:dsp45.8-5-3TH1-6.sbn
tftp-server flash:dsp75.8-5-3TH1-6.sbn
control-plane
no ccm-manager fax protocol cisco
no mgcp timer receive-rtcp
mgcp profile default
dial-peer voice 100 voip
 description Incoming dialpeer and 1+10 digits
 destination-pattern ^1[2-9]..[2-9]......$
 session protocol sipv2
 session target ipv4:216.115.69.144
 incoming called-number .T
 voice-class codec 1
 voice-class sip early-offer forced
 dtmf-relay rtp-nte
dial-peer voice 101 voip
 description 10-digit local Calls
 destination-pattern ^[2-9]..[2-9]......$
 voice-class codec 1
 dtmf-relay rtp-nte
dial-peer voice 102 voip
 description International Calls
 destination-pattern ^011T
 voice-class codec 1
 dtmf-relay rtp-nte
dial-peer voice 103 voip
 description N11 Calls
 destination-pattern ^[2-9]11$
 voice-class codec 1
 dtmf-relay rtp-nte
dial-peer voice 300 voip
 description 913712XXXX calls to CME
 huntstop
 destination-pattern ^913712....$
 session target dns:sip.flowroute.com
 voice-class codec 1
 dtmf-relay rtp-nte
dial-peer voice 301 voip
 description 785246XXXX calls to CME
 huntstop
 destination-pattern ^785246....$
 voice-class codec 1
 dtmf-relay rtp-nte
sip-ua
 credentials xxxxxxxxxxxx
 authentication xxxxxxxxxxxxx
 no remote-party-id
 retry invite 2
 retry register 10
 timers connect 100
 registrar dns:216.115.69.144 expires 3600
 sip-server dns:sip.flowroute.com
 host-registrar
telephony-service
 max-ephones 25
 max-dn 25
 ip source-address 192.168.1.2 port 2000
 load 7975 flash:SCCP75.8-5-3S.loads
 max-conferences 8 gain -6
 web admin system name admin secret 5 $1$LKD7$gxjAOF/zTy/CHVSfR0/cr0
 dn-webedit
 time-webedit
 transfer-system full-consult
ephone-dn  1
 number 1001
 label Office
 name Office
ephone  1
 device-security-mode none
 description Home Office
 mac-address C062.6B62.143A
 type 7975
 button  1:1
line con 0
line aux 0
line vty 0 4
 privilege level 15
 transport input telnet
scheduler allocate 20000 1000
ntp update-calendar
ntp server 96.226.242.9
ntp server 216.229.0.179
end
Thank you in advance
Everyone's tags (3)
Hello!1. Are u sure you
Hello!
1. Are u sure you recieve incoming calls? Did u try to use 'debug voice dial-peer', 'debug voice ccapi inout', 'debug ccsip messages'?
2. As I understand, u need to configure hunt group for DNs '1001', '1002'. If yes, you should use:
voice hunt-group 1 parallel
pilot 1) u  can try to use DID;
        2) u can configure voice-translation rules to point to some hunt-numbers and then put these numbers.
list 1001, 1002
may be some additional commands will be needed...
Kirill
Still nothing, added the hunt
Still nothing, added the hunt group but still no incoming calls.
SIP #1) 7852465184
SIP #2) 9137129524
I'm pretty sure it has something to do with my dial-peer and routing, but not sure.  I am rather new to VOIP so any config changes or suggestion on my current config would be greatly appreciated.
Attached is my current config via txt document
Thank you in advance.
Do u have any incoming calls
Hello!
Do u have any incoming calls to your CME? not to hunt-number...
Explain, how do u test this hunt-group?
Do u need all calls going to these numbers to be forwarded to hunt-group?
Why do u need this dial-peers:
 huntstop
 voice-class codec 1
 dtmf-relay rtp-nte
 huntstop
 voice-class codec 1
 dtmf-relay rtp-nte
Do u have additional box with CME installed?
Try next...
1) configure translation-profile:
voice translation-rule 999
 rule 1 /7852465184/ /5001/
voice translation-profile 999
 translate called 999
2) add it to test dial-peer
dial-peer voice 999 voip
 description Incoming test
 session target ipv4:216.115.69.144 - correct IP-address forTelco
 incoming called-number 7852465184 - if Telco sends this number in DNIS
 translation-profile incoming 999
 voice-class codec 1
 dtmf-relay rtp-nte
And test existing hunt-group...
Please, post 'debug ccssip messages' shile testing.
Kirill
I removed my CUCM and just
I removed my CUCM and just using the CME now.  I tried called my DID's through my cell phone and I get a call can not be completed or a busy tone.  Tried the debugging command, but nothing showed up when I dialed those numbers.  I would like to have the IP phones 1001-1003 ring when one of the DID is dialed.
Possibly, you don't recieve
Possibly, you don't recieve any calls from Telco...
How do u connect to ur router? using telnet, ssh? did u issue 'term mon' before debug?
Does router show nothing whilr debugging outgoing call?
regards,
Kirill
Attached is the debug
Has it ever worked?Because if
Has it ever worked?
Because if you don't see any SIP messages while calling in, I suppose there is problem with SIP-provider.
Kirill
I haven't gotten it configure
I haven't gotten it configure propperly, so I haven't been able to get it work.  I finally got some messages to show up (see attached).
Also attached is my current config
Hello!Try to create dial-peer
Hello!
Try to create dial-peer common with dial-peer voice 1 voip.
You need to:
1) put voice class-codec with g711/g729;
2) make incoming-called number +17852465184
Please, post debug ccsip all and debug voice ccapi inout;
Kirill
Could my codec be the issues
Could my codec be the issues?
Attached is the "debug ccsip messages"
415
