07-30-2007 08:13 AM - edited 03-14-2019 10:50 PM
Where in Callmanager 4.1 do I check to see why incoming calls go directly to vmail?
07-30-2007 08:31 AM
Hi Jose,
Normally this is checked on a per device level.
From CCMAdmin;
Device>Phone(in question)>Directory Number Configuration>Look for CFWDALL set to go to Voicemail
Hope this helps!
Rob
07-30-2007 09:02 AM
Under "Call Forward and Pickup Settings", everything is unchecked except "Forward No Answer Internal and Forward No Answer External" both of these items are checked off. Any other suggestions?
07-30-2007 09:17 AM
Hi Jose,
What I would try is accessing this particular device via CCMAdmin and actually setting an extension in the CFWDALL space. Then update/reset the device and test to see if calls now go to the extension you set.
Then go back to the device remove the extension you set in the CFWDALL space update/reset the device and see if if the CFWDALL in now cleared and the phone rings as it should.
Hope this helps!
Rob
08-04-2007 08:38 AM
This might be a bug that you are encountering. Rob's solution is a work around. Check this bug ID out - 4.2(3) Bug cscsj30852
