incoming call issue with 1 DID - Cause i = 0x80A9 - Temporary failure
I have a 2851 with ios 12.4(h3) running MGCP. when someone calls the did 1531 they get a fast busy tone. the debugs shows the folliwing
FFHQVG01#
*Jun 12 16:45:40.729: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x1A54
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x4081, '9163387070'
Plan:Unknown, Type:Subscriber(local)
Called Party Number i = 0xC1, '1531'
Plan:ISDN, Type:Subscriber(local)
*Jun 12 16:45:40.757: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x9A54
Channel ID i = 0xA98301
*Jun 12 16:45:40.757: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x9A54
*Jun 12 16:45:40.873: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x1A54
*Jun 12 16:45:40.889: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x9A54
*Jun 12 16:45:43.609: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x046F
Cause i = 0x8090 - Normal call clearing
*Jun 12 16:45:43.873: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x846F
*Jun 12 16:45:43.893: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x046F
have you seen something like this before ?
we have 1000 DIDs and only 1 is giving the problem thank you
1 ACCEPTED SOLUTION
Green
Re: incoming call issue with 1 DID - Cause i = 0x80A9 - Temporar
Oh ok looks like a change notification problem
COuld you please try to delete the DN and add it back if same issue can you restart ccm.exe ?
Green
We use always the same channel?
What is 1531?
Cris could you pleas eupload CCM detailed trace for the failure?
so far yes, the same channel
1531 is the did
I placed the call at 9:54 or so
Green
06/12/2008 09:54:49.201 CCM|Digit analysis: match(pi="1", fqcn="", cn="9163387070",plv="4", pss="Lib-FF-911:Phones-CAC:Lib-FF-Centrex:Lib-FF-Local:Lib-FF-LD:Voicemail:MeetMe", dd="1531",dac="0")|<:SOLVOIPPUB-CLUSTER><:10.202.1.11><:2><:10.168.98.254><:>
06/12/2008 09:54:49.201 CCM|Digit analysis: analysis results|<:SOLVOIPPUB-CLUSTER><:10.202.1.11><:2><:10.168.98.254><:>
06/12/2008 09:54:49.201 CCM||PretransformCallingPartyNumber=9163387070
|DialingPartition=
|DialingPattern=
06/12/2008 09:54:49.217 CCM|Forwarding - initiateCFNA - CFNA to VM, callKey= 0x17C3E|<:SOLVOIPPUB-CLUSTER><:10.202.1.11><:2><:10.168.98.254><:>
06/12/2008 09:54:49.217 CCM|Forwarding - ERROR processCFToVM - both oCdpnVMPN and cdpnVMPN are NULL - clear the call, callKey= 0x17C3E|<:SOLVOIPPUB-CLUSTER><:10.202.1.11><:2><:10.168.98.254><:>
Which version of CCM?
Did you delete the DN recently ?
What is seen in the traces is that for this DN
is not in the DA table but in the intercepts
|InterceptPartition=Phones-CAC
|InterceptPattern=1531
Is that the correct info (partition)?
If CCM 4.1(3)sr5d or less an upgrade may be required for CSCsj30852 for long term fix or a CCM.exe restart for workaround
CCM version 4.0(2a)es64
I didn't delete the DN
the DN is on partition Phones-CAC that is the correct partition and I just double check and the DN is associated to 5 more phones.
Green
that fixed the issue
thank you
Gonzalo,
What is "change notification problem"? How does deleting & recreating DN help here?
1530
