Incoming Call issue
Hi All,
We have a cisco 2801 router that currently has our ISDN service connected to it. This ISDN service has a 100 incoming number range associated with it. It now also has 2 additional incoming numbers that are completely outside of this range. I need to somehow configure the router to accept the calls coming from the additional 2 incoming numbers. Currently, when someone calls one of these 2 numbers, the call will successfully go through the first time, but then when a second call tries to go through (after the first call has ended)the caller receives a busy signal. Speaking to my Telco, they say it is a SIP Translation issue! I have no idea where to start. Can anyone provide me with some help?! I have MSN Messenger if it helps to try and get this sorted out as soon as possible.
I have attached our config for everyone to look at. As you can see the 100 range is working fine and is defined by the 02611780.. i have 2 other numbers to add which are 0262251234 and 0262254321 (completely out of the range and are not sequential)
Your help is greatly appreciated! Any questions, please just ask!
1 ACCEPTED SOLUTION
Green
Re: Incoming Call issue
dial-peer voice 3 voip is the one you are using for 02611780..
Try to add the following:
dial-peer voice 6 voip
translation-profile outgoing calling
destination-pattern 62251234
voice-class codec 1
max-redirects 10
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
no vad
dial-peer voice 7 voip
destination-pattern 0262254321
voice-class codec 1
max-redirects 10
dtmf-relay rtp-nte
no vad
Green
voice-class codec 1
max-redirects 10
dtmf-relay rtp-nte
no vad
voice-class codec 1
max-redirects 10
dtmf-relay rtp-nte
no vad
Thankyou! That was relatively easy! With no problems at all. Thanks!
123
