Community Member
Incoming call not landing on IP phones using CUCM
Hi all,
I am facing an issue; the incoming calls are not landing on the IP phones using the CUCM, below is the debug for the same and it shows the cause as Unallocation/Unassigned number.
I checked the config of Gateway, route pattern, partitions and CSS but seems to be ok.
.Jan  3 17:01:44.977: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=93 nr=117
.Jan  3 17:01:44.977: ISDN Se0/0/0:15 Q931: SETUP pd = 8  callref = 0x017B
         Sending Complete
         Bearer Capability i = 0x8090A3
                 Standard = CCITT
                 Transfer Capability = Speech
                 Transfer Mode = Circuit
                 Transfer Rate = 64 kbit/s
         Channel ID i = 0xA98381
                 Exclusive, Channel 1
         Calling Party Number i = 0x0083, '0162508156'
                 Plan:Unknown, Type:Unknown
         Called Party Number i = 0x81, '1065'
                 Plan:ISDN, Type:Unknown
.Jan  3 17:01:44.981: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=94
.Jan  3 17:01:44.981: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x817B callID = 0x00F5 switch = primary-net5 interface = User
.Jan  3 17:01:44.985: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=117 nr=94
.Jan  3 17:01:44.985: ISDN Se0/0/0:15 Q931: CALL_PROC pd = 8  callref = 0x817B
.Jan  3 17:01:44.985: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=118 nr=94
.Jan  3 17:01:44.985: ISDN Se0/0/0:15 Q931: DISCONNECT pd = 8  callref = 0x817B
         Cause i = 0x8081 - Unallocated/unassigned number
.Jan  3 17:01:44.993: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=118
.Jan  3 17:01:44.997: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=119
.Jan  3 17:01:45.037: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=94 nr=119
.Jan  3 17:01:45.037: ISDN Se0/0/0:15 Q931: RELEASE pd = 8  callref = 0x017B
.Jan  3 17:01:45.037: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=95
Any suggestions?
Mayank
Everyone's tags (7)
Mayank,
Is it a new config or old config ?
If it was working before & not working now, check if the incoming dial-peer config is changed on gateway ?
It appears that you have DID range ( 1065 being part of it ) & the telco is just sending last 4 digits to the gateway & gateway is not able locate the number. DP config needs to be checked ?
GP.
Community Member
Hi Mr. Pande,
It is a new config and it never worked.  Let me check the same with the telco and will also copy the dial peer config  here for more suggestions around it.
Mayank
If you took DID range, then I dont see any issue at Telco side, they are sending digits as they should.
GP.
Community Member
Yes you are right.. even I dont see an issue with the telco end.
Forgot to ask, what type of gateway protocol is being used ? My above explaination holds good for H.323.
GP.
Community Member
Hi Mr. Pandey,
The gateway is H.323
Mayank
Cool. Let us know the dial-peer config.
GP.
Community Member
posting it in another 3 - 4 minutes... thanks for the help
Community Member
config attached for your reference.
I'll be travelling, would respond after couple of hours. Others might also help you here.
GP.
Community Member
thanks again for your help.
Re: Incoming call not landing on IP phones using CUCM
An important VOIP dial-peer is missing from the config or you can modify the existing VOIP dial-peer as below..
dial-peer voice x voip     ------------------> x is just the dial-peer Tag e.g. 1,2, 3 etc...
destination-pattern 1... ------------------> This is to represent your DID range.
session target ipv4:10.3.3.11 --------------------> This is your callmanager
voice-class codec 100
dtmf-relay h245-alphanumeric
no vad
If you let me know your DID range, I can get back with precise config.
GP.
Community Member
thanks ... I will share the DID range shortly with you
Community Member
The required information is as under :-
The ISDN onramp has 600 DIDs allocated. The allocation is +60 3 2773 1000 to 1599. Number for external extension is 8.
Community Member
I have modified the existing VOIP dial-peer as suggested but the issue still persists
How does the new dial-peer config looks now ? Pls post only that dial-peer config.
What is the DN range assigned to your phones ? If you have DID range 1000 to 1599, you should either have the same DN range or have a translation pattern to convert those DIDs to your DN range. Pls confirm if such config is in place in your CUCM.
GP.
Community Member
Please find the responses below :-
dial-peer voice 2 voip
preference 2
incoming called-number .T
no vad
I will be attaching the translation pattern shortly.
also try removing " incoming called-number .T " from the DP. This will also work only if you have proper DN range or Translation pattern configured in CUCM
GP.
Community Member
If there are multiple interfaces on the gateway, can you check whether you added a bind command for the interface (ip address) that is configured as the h.323 gateway in call manager?
Gateway(config-if)#h323-gateway voip bind srcaddr X.X.X.X
Community Member
Hi Baris,
It is already done... thanks for highlighting.
Please also let us know what would be the CSS on gateway for called and calling party, same as phones or something different?
Mayank
CSS can be different, just ensure that the partitions in which your phones are, shd be included in gateway's CSS. Same to be done for phone CSS too ( include gateway partitions ). You can play with partitions & CSS.
GP.
Community Member
One quick query ....
If my interface's IP address is 192.168.1.1 which is the gateway ... will that be the srcaddr in the suggested command below?
correct.
Community Member
"also try removing " incoming called-number .T " from the DP. This will also work only if you have proper DN range or Translation pattern configured in CUCM"
Did the same... no improvements!
As I said, it will work only if you have the DID range as extension numbers ( DN ) or there is a proper translation pattern in place to translate your DID range to DN range. I dont see any details from you on this point.
GP.
Community Member
Hi Mr. Pande,
The translation pattern is displayed in the *.doc attachement above, is this what you are looking for?
Regars,
Mayank Nauni
Hi Mayank,
What is your DN range ?
I see a Translation pattern for 1xxx, which translates to a big number, are you using E.164 DN plan ?
GP.
Community Member
DID range is 327731000 to 327731599 and we have given 4 digit DN to IP phones e.g 10000, 1001, 1002.
"I see a Translation pattern for 1xxx, which translates to a big number, are you using E.164 DN plan ?"
I am not sure about it ... can you suggest me how to find it out?
Remove your translation pattern " 1xxx " from CUCM & it should fix it.
GP.
1985
