Incoming Call not working on FXO with MGCP Gateway
Hi friends,
              I'm using CUCM 8.6 with gateway 2901, configured as MGCP. I'm Using VIC2-2FXO for PSTN termination.The outgoing calls from fxo is working fine. But the incoming calls hangs up and not ringing the ip phone.
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.10.10.201
ccm-manager config
mgcp
mgcp call-agent 10.10.10.201 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp bind control source-interface GigabitEthernet0/1.20
mgcp bind media source-interface GigabitEthernet0/1.20
voice-port 0/0/0
supervisory disconnect dualtone mid-call
cptone SA
timing hookflash-out 50
I debugged mgcp incoming calls, I got the following replay.
CME_2901#
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_sys_msg(208):[lvl=0]MGCP sys msg: (EXTERNAL_EVENT)
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/xlate_mgcp_sys_ev(69):[lvl=0]xlate sys msg: (EXTERNAL_EVENT, 31625
454)
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_sys_msg(217):[lvl=0]sys msg values: (INVALID MGCP
EVENT, 0,  , 3645, CALL_IDLE)
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_handle_cmapp_event(441):[lvl=0]process
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_cmapp_send_keepalive(286):[lvl=0]send NTFY KeepAlive
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_get_by_ifn(1330):[lvl=0]Entered
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_get_tree_link_by_ifn(1149):[lvl=0]Entered
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_compute_key(198):[lvl=0]type -1 slot FFFFFFFF subunit F
FFFB650
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_get_tree_link_by_ifn(1161):[lvl=0]computed key 0xF0000000
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/send_mgcp_empty_notify_msg(3675):[lvl=1]endpt *, complete_endpt *@CME_2901
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_packet(864):[lvl=0]Entered
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_estimate_msg_buf_length(496):[lvl=1]328 bytes needed for header
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_estimate_msg_buf_length(785):[lvl=1]373 bytes needed after checking parameter lines
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_estimate_msg_buf_length(808):[lvl=1]373 bytes needed  after cheking SDP lines
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_parameter_lines(9542):[lvl=0]Entered
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_val_mandatory_parms(13064):[lvl=0]Entered
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_request_id(10015):[lvl=0]Entered
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_request_id(10035):[lvl=0]SUCCESS: Request ID string building is OK
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_obs_events(11420):[lvl=0]Entered
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_obs_events(11428):[lvl=0]mp_head_obs_evt_list NOT NULL
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_obs_events(11468):[lvl=0]out of for loop for next nodein list
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_parameter_lines(9845):[lvl=0]SUCCESS: Building MGCP Parameter lines is OK
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_packet(1018):[lvl=1]SUCCESS: MGCP message building OK -END of building
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_get_ne_info(2744):[lvl=0]Entered
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_get_ne_info(2768):[lvl=1]Used endpoint NE 10.10.10.201
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_enq_retx_msg(911):[lvl=0]trans_id 519806332,ntfy_ent 10.10.10.201
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_root_get_profile(1905):[lvl=0]Entered
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/MGCP_NEDB_get_next_addr(1211):[lvl=1]
NOTIFY ENTITY = 10.10.10.201next->10.10.10.201
      <END>
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_add_trans_id_rec(1155):[lvl=1]Add trans id (519806332, 2A1AEC30) record
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_stw_timer_start(393):[lvl=0]timer type 0, duration 500
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_stw_timer_start(393):[lvl=0]timer type 15, duration 20000
Jan 29 07:27:30.532: MGCP Packet sent to 10.10.10.201:2427--->NTFY 519806332 *@CME_2901 MGCP 0.1
X: 0O:
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/send_mgcp_empty_notify_msg(3738):[lvl=2]NTFY Packet sent successfully - *
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_count_active_mgc_msg_stat(239):[lvl=1]MGC stat - 10.10.10.201, total=24105, succ=23744, failed=240
Jan 29 07:27:30.532: MGCP Packet received from 10.10.10.201:2427--->200 519806332
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_mgcp_msg(3534):[lvl=0] : <NEW MGCP MSG From CA>
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_parse_packet(312):[lvl=0]call mgcp_parse_header
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_parse_packet(316):[lvl=0]out mgcp_parse_header
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_parse_packet(326):[lvl=1]SUCCESS: - MGCP Header parsing was OK
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_parse_packet(344):[lvl=2]SUCCESS: - END of Parsing
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_msg_ack(6876):[lvl=0]Entered
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_count_active_mgc_msg_stat(239):[lvl=1]MGC stat - 10.10.10.201, total=24105, succ=23745, failed=240
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcp_msg_ack(6948):[lvl=1]Removing msg : NTFY 519806332 *@CME_2901
MGCP 0.1
X: 0
O:
Jan 29 07:27:30.532: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_socket(3645):[lvl=0]Entered
What will be the issue,
Your replay will be highly appreciated
1 REPLY
Hall of Fame Super Silver
Is your MGCP port defined to point to the phone's DN?  Is the Calling Search Space applied to the GW listing the Parition of the phone's DN?
Chris
941
