Incoming call problem
When i have the hunt pilot configured the calls are not completed.
if i change the hunt pilot number to not match the DNIS then i am able to complete the call.
i don´t understand why the router is matching the DNIS.
in attach i send a debug i did. (ccapi inout; isdn q931 and voice translation)
voice translation-rule 1
rule 1 /0/ /236200230/
rule 2 /1/ /4419/
rule 3 /2/ /4420/
rule 4 /3/ /4420/
rule 5 /4/ /4410/
rule 6 /5/ /4420/
rule 7 /6/ /4420/
rule 8 /7/ /4420/
rule 9 /8/ /4420/
rule 10 /9/ /4420/
voice translation-profile DDI
translate called 1
voice-port 0/2/0:15
translation-profile incoming DDI
dial-peer voice 2200 voip
destination-pattern 236200230
voice-class codec 2
session protocol sipv2
session target ipv4:10.162.100.70
session transport udp
dtmf-relay rtp-nte
ephone-hunt 1 sequential
pilot 2
list 4420, 4421, 4422
timeout 45
statistics collect
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Incoming call problem
One more think, when i call i get a dialtone one the caller side.
You should have said that before, and I should have inferred it from the ISDN trace. Configure
dial-peer voice pots 1
incoming called-number .
direct-inward-dial
And everything will work then.
If calls comes in via PRI, why are you mentioned voip DP?
In your country, do you have overlap receiving ?
i have a voip DP because that is where i want the call to go.
it has to leave the router to a SIP server.
interface Serial0/2/0:15
description *** Acesso Primario 236200230 ***
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving
isdn incoming-voice voice
no cdp enable
Then prepare a tranaltion-rule that makes sense, as the current one does not.
If still trouble, include only debug isdn 931 and ccsip message.
There is no need to use ZIP or attachments.
the translation doesn´t make sense???
Could you please tell me why? Because if there is no pilot number it works fine....
has you can see in the debug, the call never gets to the voip dialpeer so ccsip debug does not help.
001463: Feb 24 13:30:04.274: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0044
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18381
                Preferred, Channel 1
        Progress Ind i = 0x8083 - Origination address is non-ISDN
        Calling Party Number i = 0x0081, '213848218'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x81, '0'
                Plan:ISDN, Type:Unknown
001464: Feb 24 13:30:04.290: ISDN Se0/2/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8044
        Channel ID i = 0xA98381
                Exclusive, Channel 1
001465: Feb 24 13:30:04.290: ISDN Se0/2/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x8044
001466: Feb 24 13:30:04.418: ISDN Se0/2/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x0044
GPS_Pombal_RT#
001467: Feb 24 13:30:04.422: %ISDN-6-CONNECT: Interface Serial0/2/0:0 is now connected to 213848218 N/A
GPS_Pombal_RT#
001468: Feb 24 13:30:13.122: ISDN Se0/2/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x0044
        Cause i = 0x8090 - Normal call clearing
        Progress Ind i = 0x8288 - In-band info or appropriate now available
        Display i = 'Chamada desligada'
001469: Feb 24 13:30:13.126: %ISDN-6-DISCONNECT: Interface Serial0/2/0:0  disconnected from 213848218 , call lasted 8 seconds
GPS_Pombal_RT#
001470: Feb 24 13:30:13.126: ISDN Se0/2/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0xCE
001471: Feb 24 13:30:13.134: ISDN Se0/2/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x8044
001472: Feb 24 13:30:13.206: ISDN Se0/2/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0044
GPS_Pombal_RT#
GPS_Pombal_RT#
GPS_Pombal_RT#sh deb
GPS_Pombal_RT#sh debugging
The following ISDN debugs are enabled on all DSLs:
debug isdn error is             ON.
debug isdn q931 is              ON.   (filter is OFF)
CCSIP SPI: SIP Call Statistics tracing is enabled       (filter is OFF)
CCSIP SPI: SIP Call Message tracing is enabled  (filter is OFF)
CCSIP SPI: SIP Call State Machine tracing is enabled    (filter is OFF)
CCSIP SPI: SIP Call Events tracing is enabled   (filter is OFF)
CCSIP SPI: SIP error debug tracing is enabled   (filter is OFF)
CCSIP SPI: SIP info debug tracing is enabled    (filter is OFF)
CCSIP SPI: SIP media debug tracing is enabled   (filter is OFF)
CCSIP SPI: SIP Call preauth tracing is enabled  (filter is OFF)
CCSIP SPI: SIP Call transport tracing is enabled        (filter is OFF)
GPS_Pombal_RT#u all
All possible debugging has been turned off
Something is wrong with you voip DP. Try for example "show dialplan number xxxx" where xxx is the number to which 0 is translated.
The ephone pilot has nothing to do with voip DP.
The dial-peer 198 is the backup of the VOIP dial-peer.
GPS_Pombal_RT#sh dialplan number 236200230
Macro Exp.: 236200230
VoiceOverIpPeer2200
        peer type = voice, system default peer = FALSE, information type = voice,
        description = `Ligacao VContact',
        tag = 2200, destination-pattern = `236200230',
        answer-address = `', preference=0,
        CLID Restriction = None
        CLID Network Number = `'
        CLID Second Number sent
        CLID Override RDNIS = disabled,
        source carrier-id = `', target carrier-id = `',
        source trunk-group-label = `',  target trunk-group-label = `',
        numbering Type = `unknown'
        group = 2200, Admin state is up, Operation state is up,
        incoming called-number = `', connections/maximum = 0/unlimited,
        DTMF Relay = enabled,
        modem transport = system,
        URI classes:
            Incoming (Request) =
            Incoming (To) =
            Incoming (From) =
            Destination =
        huntstop = disabled,
        in bound application associated: 'DEFAULT'
        out bound application associated: ''
        dnis-map =
        permission :both
        incoming COR list:maximum capability
        outgoing COR list:minimum requirement
        Translation profile (Incoming):
        Translation profile (Outgoing):
        incoming call blocking:
        translation-profile = `'
        disconnect-cause = `no-service'
        advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
        type = voip, session-target = `ipv4:10.162.100.70',
        technology prefix:
        settle-call = disabled
        ip media DSCP = ef, ip signaling DSCP = af31,
        ip video rsvp-none DSCP = af41,ip video rsvp-pass DSCP = af41
        ip video rsvp-fail DSCP = af41,
        UDP checksum = disabled,
        session-protocol = sipv2, session-transport = udp,
        req-qos = best-effort, acc-qos = best-effort,
        req-qos video = best-effort, acc-qos video = best-effort,
        req-qos audio def bandwidth = 64, req-qos audio max bandwidth = 0,
        req-qos video def bandwidth = 384, req-qos video max bandwidth = 0,
        dtmf-relay = rtp-nte,
        RTP dynamic payload type values: NTE = 101
        Cisco: NSE=100, fax=96, fax-ack=97, dtmf=121, fax-relay=122
               CAS=123, TTY=119, ClearChan=125, PCM switch over u-law=0,A-law=8
               G726r16 using static payload
               G726r24 using static payload
        RTP comfort noise payload type = 19
        fax rate = fax,   payload size =  20 bytes
        fax protocol = system
        fax-relay ecm enable
        Fax Relay SG3-to-G3 Enabled (by system configuration)
        fax NSF = 0xAD0051 (default)
        voice-class codec = 2
        codec = g729r8,   payload size =  20 bytes,
        text relay = disabled
        Media Setting = flow-through (global)
        Expect factor = 10, Icpif = 20,
        Playout Mode is set to adaptive,
        Initial 60 ms, Max 250 ms
        Playout-delay Minimum mode is set to default, value 40 ms
        Fax nominal 300 ms
        Max Redirects = 1, signaling-type = cas,
        VAD = enabled, Poor QOV Trap = disabled,
        Source Interface = NONE
        voice class sip url = system,
        voice class sip rel1xx = system,
        redirect ip2ip = disabled
        local peer = false
        probe disabled,
        Secure RTP: system (use the global setting)
        voice class perm tag = `'
        Time elapsed since last clearing of voice call statistics never
        Connect Time = 1925269, Charged Units = 0,
        Successful Calls = 129, Failed Calls = 0, Incomplete Calls = 0
        Accepted Calls = 0, Refused Calls = 0,
        Last Disconnect Cause is "10  ",
        Last Disconnect Text is "normal call clearing (16)",
        Last Setup Time = 8415975.
        Last Disconnect Time = 8436256.
Matched: 236200230   Digits: 9
Target: ipv4:10.162.100.70
VoiceEncapPeer198
        description = `Geral_CC',
        tag = 198, destination-pattern = `236200230',
        answer-address = `', preference=2,
        group = 198, Admin state is up, Operation state is up,
        Outbound state is up,
        DTMF Relay = disabled,
        URI classes:
            Destination =
        dnis-map =
        permission :both
        type = pots, prefix = `210438123',
        forward-digits 0
        session-target = `', voice-port = `0/2/0:15',
        direct-inward-dial = enabled,
        digit_strip = enabled,
        register E.164 number with H323 GK and/or SIP Registrar = TRUE
        fax rate = system,   payload size =  20 bytes
        supported-language = ''
        Connect Time = 6014, Charged Units = 0,
        Successful Calls = 0, Failed Calls = 0, Incomplete Calls = 0
        Accepted Calls = 1, Refused Calls = 0,
        Last Setup Time = 1354239.
        Last Disconnect Time = 1360284.
Target:
GPS_Pombal_RT#
GPS_Pombal_RT#
GPS_Pombal_RT#sh dial-peer voice summary
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT
100    pots  up   up             011[257]           0                      up   0/2/0:15
101    pots  up   up             4419               0                      up   0/3/1
198    pots  up   up   21043812- 236200230          2                      up   0/2/0:15
2000   voip  up   up             43..               0  syst ipv4:10.42.2.254
2200   voip  up   up             236200230          0  syst ipv4:10.162.100.70
2100   voip  up   up             3...               0  syst ipv4:10.40.2.254
2500   voip  down down           09........         0  syst ipv4:10.40.2.254
1000   pots  up   up   1         01T                0                      up   0/2/0:15
200    pots  up   up             02........         0                      up   0/2/0:15
300    pots  up   up             03........         0                      up   0/2/0:15
600    pots  up   up             06........         0                      up   0/2/0:15
700    pots  up   up             070[78]......      0                      up   0/2/0:15
620    pots  up   up             06[129]...         0                      up   0/2/0:15
801    pots  up   up             0800......         0                      up   0/2/0:15
808    pots  up   up             080[89]......      0                      up   0/2/0:15
900    pots  up   up             09........         0                      up   0/2/0:15
10000  pots  up   up   0         00T                0                      up   0/2/0:15
110    pots  up   up             4418               0                      up   0/3/0
20001  pots  up   up             4420$              0                           50/0/1
20002  pots  up   up             4410$              0                           50/0/2
20003  pots  up   up             236200234$         9                           50/0/2
20004  pots  up   up             4411$              0                           50/0/3
20005  pots  up   up             236200235$         9                           50/0/3
20006  pots  up   up             4412$              0                           50/0/4
20007  pots  up   up             236200236$         9                           50/0/4
20008  pots  up   up             4413$              0                           50/0/5
20009  pots  up   up             236200237$         9                           50/0/5
20010  pots  up   up             4414$              0                           50/0/6
20011  pots  up   up             4415$              0                           50/0/7
20012  pots  up   up             4416$              0                           50/0/8
20013  pots  up   up             4417$              0                           50/0/9
20014  pots  up   up             4421$              0                           50/0/10
20015  pots  up   up             236200232$         9                           50/0/10
20016  pots  up   up             4422$              0                           50/0/11
20017  pots  up   up             236200233$         9                           50/0/11
20018  pots  up   up             4423$              0                           50/0/12
20019  pots  up   up             236200238$         9                           50/0/12
20020  pots  up   up             4424$              0                           50/0/13
20021  pots  up   up             4425$              0                           50/0/14
20022  pots  up   up             7620$              0                           50/0/15
20023  pots  up   up             7720$              0                           50/0/16
20024  pots  up   up             7820$              0                           50/0/17
20025  pots  up   up             7920$              0                           50/0/18
20070  pots  up   up             A2A000             0                           50/0/1
20071  pots  up   up             2                  0                           50/0/1
20072  pots  up   up             A2A001             0                           50/0/10
20073  pots  up   up             A2A002             0                           50/0/11
dial-peer voice 198 pots
description Geral_CC
preference 2
direct-inward-dial
port 0/2/0:15
forward-digits 0
prefix 210438123
You may have an ACL or routing problem preventing the SIP call to go out.
I really don't think so.
The only thing that i have to do to make this work, is to change the pilot number to a different one of the DNIS. In this case it works fine.
That's why i don't think it's a routing problem.
I don't understand why the router is matching the DNIS... there is in no place in the configuration a match calling, that is why this doesn't make any sense to me.
Hope it helps.
direct-inward-dial
That was it!!!!!
Sorry for not saying about the dialtone in the first place.
Thank you so much for your help.
No problem. Thank you for the nice rating and good luck!
427
