incoming call redirection
Can I do the following. I need that the incoming call to the numbers 01-02-03-04 should be redirected to i.e.81-82-83-84
i should add
num-exp 14800001 81
num-exp 14800002 82
num-exp 14800003 83
num-exp 14800004 84
I have already the expression :
num-exp 148000.. ..
Can i still call the other numbers in the 10 till 99
1 REPLY
Silver
Re: incoming call redirection
To define how to expand a telephone extension number into a particular destination pattern, use the num-exp command in global configuration mode. To cancel the configured number expansion, use the no form of this command.
num-exp extension-number expanded-number
no num-exp extension-number
Please view the use of the command num-exp with ex:
Examples
The following example expands the extension number 55541 to the number 14085555541:
num-exp 55541 14085555541
The following example expands all five-digit extensions beginning with 5 such that the 5 is replaced with the digits 1408555 at the beginning of the extension number:
num-exp 5.... 1408555....
120
