Incoming call rings and then disconnects
I just replaced an FXO card in a 2911 router since it was having multiple issues.  Now one last issue I'm facing is that when I call the last number in the hunt sequence it rings once and disconnects.  I was running "debug vpm all" and it seems like as compared to the working line this one doesn't establishes the call all the way.  Below are the logs any ideas?
WORKING LOG:
Jan 20 12:56:35.064: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
Jan 20 12:56:35.064: TGRM: reg_invoke_tgrm_call_update(0, 0, 0, 65535, 1, TGRM_CALL_PENDING, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Jan 20 12:56:35.064: htsp_timer - 125 msec
Jan 20 12:56:35.192: htsp_process_event: [0/0/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
Jan 20 12:56:35.192: htsp_timer - 10000 msec
Jan 20 12:56:36.440: htsp_process_event: [0/0/0, FXOLS_RINGING, E_DSP_SIG_0100]
Jan 20 12:56:36.440: fxols_ringing_not
Jan 20 12:56:36.440: htsp_timer_stop
Jan 20 12:56:36.440: htsp_timer_stop3 htsp_setup_ind
Jan 20 12:56:36.444: [0/0/0] get_local_station_id calling num= calling name= calling time=01/20 12:56  orig called=
Jan 20 12:56:36.444: TGRM: reg_invoke_tgrm_accept_call(1, TGRM_CALL_VOICE, TGRM_DIRECTION_IN, 0, 0, 0, 65535)
Jan 20 12:56:36.444: TGRM: Calling vtsp_tsp_call_setup_ind().
Jan 20 12:56:36.448: htsp_validate_cap****
Jan 20 12:56:36.448: dsp_digit_collect_off: [0/0/0] packet_len=8 channel_id=128 packet_id=36htsp_connect: no_offhook 0 call_connected 0
Jan 20 12:56:36.448: htsp_process_event: [0/0/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
Jan 20 12:56:36.448: fxols_wait_setup_ack:
Jan 20 12:56:36.448: [0/0/0] set signal state = 0xC timestamp = 0
Jan 20 12:56:36.448: dsp_set_sig_state: [0/0/0] packet_len=12 channel_id=128 packet_id=39 state=0xC timestamp=0x0fxols_check_auto_call
Jan 20 12:56:36.452: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
Jan 20 12:56:36.452: htsp_timer_stop
Jan 20 12:56:36.488: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
Jan 20 12:56:36.492: htsp_call_bridged invoked
Jan 20 12:56:36.496: flex_dsprm_forking_mixing_support:
Jan 20 12:56:36.496: mars_flex_dsprm_current_codec_comp:DSP:0 FLEX Complexity Codec
Jan 20 12:56:36.496:  DSPWARE Version >= 3.0, actual is 4.2
Jan 20 12:56:36.500: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
Jan 20 12:56:36.724: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
Jan 20 12:56:36.724: htsp_timer_stop2
NON WORKING:
Jan 20 12:50:40.253: htsp_process_event: [0/0/1, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
Jan 20 12:50:40.253: TGRM: reg_invoke_tgrm_call_update(0, 0, 1, 65535, 1, TGRM_CALL_PENDING, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Jan 20 12:50:40.253: htsp_timer - 125 msec
Jan 20 12:50:40.381: htsp_process_event: [0/0/1, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
Jan 20 12:50:40.381: htsp_timer - 10000 msec
Jan 20 12:50:41.633: htsp_process_event: [0/0/1, FXOLS_RINGING, E_DSP_SIG_0100]
Jan 20 12:50:41.633: fxols_ringing_not
Jan 20 12:50:41.633: htsp_timer_stop
Jan 20 12:50:41.633: htsp_timer_stop3 htsp_setup_ind
Jan 20 12:50:41.633: [0/0/1] get_local_station_id calling num= calling name= calling time=01/20 12:50  orig called=
Jan 20 12:50:41.633: TGRM: reg_invoke_tgrm_accept_call(1, TGRM_CALL_VOICE, TGRM_DIRECTION_IN, 0, 0, 1, 65535)
Jan 20 12:50:41.633: TGRM: Calling vtsp_tsp_call_setup_ind().
Jan 20 12:50:41.641: dsp_digit_collect_on: [0/0/1] packet_len=20 channel_id=129 packet_id=35 min_inter_delay=240 max_inter_delay=9760 mim_make_time=10 max_make_time=100 min_brake_time=10 max_brake_time=100
Jan 20 12:50:41.641: htsp_process_event: [0/0/1, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
Jan 20 12:50:41.641: fxols_wait_setup_ack:
Jan 20 12:50:41.641: [0/0/1] set signal state = 0xC timestamp = 0
Jan 20 12:50:41.641: dsp_set_sig_state: [0/0/1] packet_len=12 channel_id=129 packet_id=39 state=0xC timestamp=0x0fxols_check_auto_call
Jan 20 12:50:41.917: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_DSP_SIG_0110]fxols_rvs_battery
Jan 20 12:50:41.917: htsp_timer_stop2
Bronze
Hi Mohammad,
Router is receiving a battery reversal signal from service provider when phone is ringing.
By default FXO port will disconnect the call if battery reversal is detected. To disable battery reversal detection configure below mentioned command under FXO port
voice-port
no battery-reversal
shut
no shut
Kindly check after making above changes.
Mohit Singh
Thank you for the reply, I tried it but it is still dowing the same thing happening.  Going to create a ticket with telco.
Re: Incoming call rings and then disconnects
Why would the FXO port still see the battery reversal?  Here is some more information:
"show voice trace"
NON WORKING
0/0/1 State Transitions: timestamp (state, event) -> (state, event) ...
69446.732 (FXOLS_RINGING, E_DSP_SIG_0100) ->
69446.736 (FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK) ->
69447.012 (FXOLS_PROCEEDING, E_DSP_SIG_0110) ->
69467.620 (FXOLS_PROCEED_RVS_BT, E_DSP_SIG_1100) ->
69467.972 (FXOLS_PROCEEDING, E_HTSP_EVENT_TIMER2) ->
69467.972 (FXOLS_PROCEEDING, E_HTSP_RELEASE_REQ) ->
69468.568 (FXOLS_GUARD_OUT, E_DSP_SIG_0110) ->
69468.972 (FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER) ->
69468.972 (FXOLS_ONHOOK, E_DSP_SIG_0100) ->
WORKING
0/0/0 State Transitions: timestamp (state, event) -> (state, event) ...
69383.764 (FXOLS_RINGING, E_DSP_SIG_0100) ->
69383.768 (FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK) ->
69383.772 (FXOLS_PROCEEDING, E_HTSP_CONNECT) ->
69383.812 (FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH) ->
69383.820 (FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH) ->
69384.044 (FXOLS_CONNECT, E_DSP_SIG_0110) ->
69406.776 (FXOLS_CONNECT, E_DSP_SIG_1100) ->
69407.128 (FXOLS_CONNECT, E_HTSP_EVENT_TIMER2) ->
69407.192 (FXOLS_REMOTE_RELEASE, E_HTSP_RELEASE_REQ) ->
69407.720 (FXOLS_GUARD_OUT, E_DSP_SIG_0110) ->
69409.192 (FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER) ->
69409.192 (FXOLS_ONHOOK, E_DSP_SIG_0100) ->
Bronze
collect below debugs and share for a test call.
debug vpm signal
debug voip vtsp session
debug voip vtsp default
debug voip ccapi inout
Also share voice port configuration
Mohit Singh
Thank you for the reply.  Weirdest thing I moved it from fxo0/0/1 to 0/0/3 and now everything is working.  I'm wondering if the 0/0/1 was defective in the new card as well.
Bronze
You had to disable battery reversal or without it new port is working?
Mohit Singh
I tried disabling the battery reversal on 0/0/1 (the original port) but no use.  On the new port it is working without it.
757
