Incoming call to Analogue phone via FXS issue
Hi Everyone,
Can someone please share the knoweldge of what could be the cause of the incoming call via SIP trunk being failed to reach analogue phone which is connected to a FXS port on CUBE? I have a site with a cave location where there was an existing telephone cabling and have provided an analogue phone in there. However, the SIP trunk is terminated on an another site which shares DID range and I have attached configuration of both CUBE routers.
Main site with SIP trunk: wan1r001 (Cisco 2911-VSEC-CUBE with 1 FXO and FXS)
The site with an analogue line: yan1r001 (Cisco 2911-VSEC-CUBE with 1 FXO and FXS)
CUCM Version: CUCM 8.6.2
I have also done 'debug ccsip message' and the following is its output when an incoming call was tested to the line. The call flow for that test call would be PSTN -> SIP SP -> CUBE at wan1r001 -> CUCM 8.6 > CUBE at yan1r001 -> end-point?
wan1r001#
Oct 29 05:43:36.647: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:893037779@172.19.86.2:5060 SIP/2.0
Via: SIP/2.0/UDP 203.52.2.164:5060;branch=z9hG4bKtlnijt204o30h0pte1k1.1
From: <sip:893340333@203.52.2.164;user=phone;url-cookie=VNWEHA1-a61ngtns76ee3>;tag=538692716-1383025416599-
To: "893037779 893037779"<sip:893037779@myorg.com.au;url-cookie=VNWEHA1-n7eublr6digf0>
Call-ID: BW164336599291013317570105@10.83.154.147
CSeq: 22973644 INVITE
Contact: <sip:893340333@203.52.2.164:5060;url-cookie=VNWEHA1-1uu40pjrhm1a0;transport=udp>
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Accept: application/media_control+xml,application/sdp,multipart/mixed
Supported:
Max-Forwards: 29
Content-Type: application/sdp
Content-Length: 416
v=0
o=BroadWorks 890728072 1 IN IP4 203.52.2.164
s=-
c=IN IP4 203.52.2.164
t=0 0
a=media-release:hngl5rp9pujvivh05pvumib1j8rpvg8o25736svbbeur62084c30
a=media-release-con-addr:d6v1k1hvmhvh1081o9j0
m=audio 18146 RTP/AVP 8 18 0 101
a=ptime:20
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=fmtp:18 annexb=no
a=silenceSupp:off - - - -
Oct 29 05:43:36.655: //209336/E3D681B6B855/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 29 Oct 2013 05:43:36 GMT
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Oct 29 05:43:36.655: //209337/E3D681B6B855/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:7779@10.6.130.11:5060 SIP/2.0
Via: SIP/2.0/UDP 172.19.86.2:5060;branch=z9hG4bK528D6186E
Remote-Party-ID: <sip:00893340333@172.19.86.2>;party=calling;screen=no;privacy=off
From: <sip:00893340333@as.nipt.telstra.com>;tag=3122EC0-1952
To: <sip:7779@10.6.130.11>
Call-ID: E3D71DDE-3F9311E3-B85BDB9E-82954B39@172.19.86.2
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3822485942-1066602979-3092634526-2190822201
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1383025416
Contact: <sip:00893340333@172.19.86.2:5060>
Expires: 300
Max-Forwards: 28
Content-Disposition: session;handling=required
Content-Length: 303
v=0
o=CiscoSystemsSIP-GW-UserAgent 6895 6200 IN IP4 172.19.86.2
s=SIP Call
c=IN IP4 172.19.86.2
t=0 0
m=audio 28006 RTP/AVP 8 18 0 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
wan1r001#
Oct 29 05:43:36.659: //209337/E3D681B6B855/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
wan1r001#
Oct 29 05:43:46.651: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:893037779@172.19.86.2:5060 SIP/2.0
CSeq: 22973644 CANCEL
Max-Forwards: 29
Content-Length: 0
Oct 29 05:43:46.655: //209336/E3D681B6B855/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 29 Oct 2013 05:43:46 GMT
Content-Length: 0
Oct 29 05:43:46.655: //209337/E3D681B6B855/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:7779@10.6.130.11:5060 SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1383025426
Reason: Q.850;cause=16
Content-Length: 0
Sent:
SIP/2.0 487 Request Cancelled
To: "893037779 893037779"<sip:893037779@myorg.com.au;url-cookie=VNWEHA1-n7eublr6digf0>;tag=31255CC-211E
Content-Length: 0
Oct 29 05:43:46.659: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:893037779@172.19.86.2:5060 SIP/2.0
CSeq: 22973644 ACK
Max-Forwards: 29
Content-Length: 0
Oct 29 05:43:46.663: //209337/E3D681B6B855/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
Received:
To: <sip:7779@10.6.130.11>;tag=317832~57a3ab79-9f8e-4dee-acfc-ddcdab5c1646-53630368
CSeq: 101 INVITE
Content-Length: 0
Oct 29 05:43:46.667: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
wan1r001#ACK sip:7779@10.6.130.11:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
wan1r001#
Thanks in advance for your assistance.
1 ACCEPTED SOLUTION
layhlaing
You'll need to capture debugs simultaneously on both CUBE routers and capture an affected call:
First CUBE:
deb voice ccapi inout
deb ccsip messages
Second CUBE:
deb ccsip messages
deb vpm signal
Please share the complete configuration for both routers.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
layhlaing
First CUBE:
deb ccsip messages
Second CUBE:
deb ccsip messages
deb vpm signal
Jorge Armijo
Re: Incoming call to Analogue phone via FXS issue
Thanks Jorge for your help. I have replicated this issue and gathered debugs as attached. Complete configs are also attached.
FXS analogue lines that we use in the first CUBE are working fine but not this one at second CUBE. And I am seeing the CANCEL request in the debug on CUBE1 and the calling is failing over to "SIP failover number" which is there at SP level for "Business continuity" which should only happens when SIP trunk is out of service.
Can you please explain a bit of what you can see in the debugs?
Cheers,
Hi Jorge,
I am just letting you know that the issue has been resolved. It was the change that we made on the CUBE2 router few days ago. It happened when Nortel PoE switches were replaced with Cisco ones and it slipped my mind to see the issue. After updating the SIP trunk's IP address in CUCM, both incoming calls and outbound calls to/from that analogue phone was working. The correct amount of debugging level as you advised has pointed me out this so thanks again.
Cheers,
Lay
Good to know
Jorge Armijo
238
