Incoming call to ext# from FXO port
We currently have department that has multible FXO ports sent to a Hunt Pilot, and it is working fine.
I would like to change it to it being directed to a single extension, then the single extension being
routed to the Hunt Pilot. Then final destination is unimportant to this post. Just thought it would
cut down on the confusion about what I am asking. I do not wish to make any changes to the outgoing
calls for this extension or department.
Here is the original configuration for one of the ports in question.
voice-port 0/1/3
connection plar 7805
description Maintenance 3
caller-id enable
(7805 is the Hunt Pilot that calls a list of phones in a Line Group, and it is working).
I made the simple change below, expecting it to work, but the FXO port answers, but never rings the phone.
(180400 is the extension number I wish the call to be rounted to).
voice-port 0/1/3
connection plar 180400
caller-id enable
What am I missing?
It is a 2921 Voice Router, with OS version 15-1-3
Remember it is working when sent the the Hunt Pilot, and outgoing calls are not
routed to this FXO port, and are working the way we want them to.
Lynn Hedspeth
Hall of Fame Super Silver
You need to make sure that you have a dial-peer matching the 180400 destination.
HTH,
Chris
Re: Incoming call to ext# from FXO port
I tried the following with the same results.
dial-peer voice 5 pots
destination-pattern 180400
port 0/1/3
I am a little confused, about the need for a destination-pattern if
I am not calling outward. But I tried the above.
Lynn Hedspeth
You are attempting to loop the call back onto the same port, your dial-peer needs to point to most likely your CUCM (you did not explain your topology). Please post your full config.
Chris
voice-port 0/1/3 is the one I am testing, but once it is working I will need to make the same changes to 2 other ports.
voice-port 0/1/0 and 0/1/3 will eventually need to have the same destination.
I removed the dial-peer entry I made earlier after it didn't work, so you won't find it in the following config text.
What I am trying to accomplish is. Originally those 3 ports were routed to a Hunt Pilot (7805) which rings all the phones in that department. I want to change it so it only rings the secretaries phone/extension. It is an IP phone extension 180400. The original configuration was working, we just desided to change how or who it rings to. So it was already working, I just need to change the destination. I have only changed one of the ports while testing.
Here is the complete config:
Lynn Hedspeth
CCS-CO-VoiceGateway-01#show run
Building configuration...
Current configuration : 8644 bytes
version 15.1
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service linenumber
service sequence-numbers
hostname CCS-CO-VoiceGateway-01
boot-start-marker
boot-end-marker
card type t1 0 0
no logging console
enable secret 5 $1$oRG0$R6DVgjti2uVcdMLsAZqyS.
aaa new-model        !
aaa authentication login default local line
aaa authorization console
aaa authorization exec default local none
aaa session-id common
clock timezone EST -5 0
clock summer-time DST recurring
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/0/1
no ipv6 cef
no ip source-route
ip cef
ip domain name catawba.nc.us
isdn switch-type primary-ni
trunk group FXO
voice-card 0
dsp services dspfarm
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
h323
  h225 display-ie ccm-compatible
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
voice class h323 1
  h225 timeout tcp establish 3
application
global
  service alternate Default
license udi pid CISCO2921/K9 sn FTX1503A0D3
hw-module pvdm 0/0
hw-module pvdm 0/1
archive
log config
  hidekeys
username kngadmin privilege 15 secret 5 $1$DQsH$dsMc1EOCyZ8nvtYjlp03m/
username ccsadmin privilege 15 secret 5 $1$mpW.$XtSDzGCWLAET3UulnolgY/
redundancy
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24
controller T1 0/0/1
interface GigabitEthernet0/0
description Voice LAN
ip address 172.25.180.2 255.255.255.0
ip virtual-reassembly in
duplex auto
speed auto
no snmp trap link-status
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.25.180.2
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn map address 011* plan unknown type unknown
isdn supp-service name calling
no cdp enable
interface Serial0/0/1:23
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.25.180.1
control-plane
voice-port 0/0/0:23
bearer-cap Speech
voice-port 0/1/0
description Maintenance 1
caller-id enable
voice-port 0/1/1
connection plar 7801
description Transportation 1
caller-id enable
voice-port 0/1/2
description Maintenance 2
caller-id enable
voice-port 0/1/3
connection plar 180404
caller-id enable
voice-port 0/0/1:23
bearer-cap Speech
voice-port 0/2/0
description Transportation 2
caller-id enable
voice-port 0/2/1
mgcp fax t38 ecm
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 172.25.180.11 identifier 2 priority 2 version 7.0
sccp ccm 172.25.180.10 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register CO_Xcoder
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 6
associate application SCCP
dial-peer voice 1 voip
preference 1
destination-pattern [1-8]...
session target ipv4:172.25.180.10
incoming called-number ..........
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
no vad
dial-peer voice 101 pots
preference 1
destination-pattern 9[2-9].........
direct-inward-dial
port 0/0/1:23
forward-digits 10
dial-peer voice 102 pots
preference 1
destination-pattern 91[2-9].........
direct-inward-dial
port 0/0/1:23
forward-digits 11
dial-peer voice 103 pots
preference 1
destination-pattern 9011.T
direct-inward-dial
port 0/0/1:23
prefix 011
dial-peer voice 104 pots
preference 1
destination-pattern 9[4-9]11
direct-inward-dial
port 0/0/1:23
forward-digits 3
dial-peer voice 105 pots
preference 1
destination-pattern 911
direct-inward-dial
port 0/0/1:23
forward-digits 3
dial-peer voice 2 voip
preference 1
destination-pattern [0-8]...
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 201 pots
preference 2
direct-inward-dial
port 0/0/0:23
forward-digits 10
dial-peer voice 202 pots
preference 2
direct-inward-dial
port 0/0/0:23
forward-digits 11
dial-peer voice 203 pots
preference 2
direct-inward-dial
port 0/0/0:23
prefix 011
dial-peer voice 204 pots
preference 2
direct-inward-dial
port 0/0/0:23
forward-digits 3
dial-peer voice 205 pots
preference 2
direct-inward-dial
port 0/0/0:23
forward-digits 3
dial-peer voice 801 pots
preference 1
destination-pattern 9828.......
direct-inward-dial
port 0/0/1:23
forward-digits 10
dial-peer voice 802 pots
preference 2
direct-inward-dial
port 0/0/0:23
forward-digits 10
dial-peer voice 803 pots
preference 1
destination-pattern 9704.......
direct-inward-dial
port 0/0/1:23
forward-digits 10
dial-peer voice 804 pots
preference 2
direct-inward-dial
port 0/0/0:23
forward-digits 10
dial-peer voice 701 pots
preference 3
destination-pattern 9[2-9]T
direct-inward-dial
port 0/0/1:23
forward-digits 7
dial-peer voice 702 pots
preference 4
direct-inward-dial
port 0/0/0:23
forward-digits 7
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 4 gain -6
transfer-system full-consult
timeouts interdigit 4
ip source-address 172.25.180.2 port 2000
max-ephones 110
max-dn 150
system message primary CM Fallback Mode
keepalive 15
voicemail 8000
alias 1 .... to 180200
alias 2 7045 to 180413
banner login ^C
     *                     AUTHORIZED ACCESS ONLY                     *
     *    This system and all of its components are restricted to     *
     *   authorized users for legitimate business purposes and are    *
     *   subject to audit. Persons who violate this policy will be    *
     *  subject to the disciplinary process. The actual or attempted  *
     *  unauthorized access, use modification or copying of computer  *
     *       systems is a violation of Federal and State laws.        *
^C
line con 0
line aux 0
line vty 0 4
exec-timeout 15 0
transport input telnet ssh
transport output all
line vty 5 15
exec-timeout 15 0
scheduler allocate 20000 1000
ntp source GigabitEthernet0/0
ntp server 10.100.0.2 prefer
end
CCS-CO-VoiceGateway-01#exit
Well, you have some overlapping dial-peers, dial-peer 1 and 2 that would match the original number 7805, if you want 180400 to go to the same destination you need to create duplicate of one of these dial-peers (whichever one you actually want to use) and set the destination-pattern to something like "destination-pattern 180400" or "180...", etc.
HTH,
Chris
I greatly appreciate your help, and advise.
I copied dial-peer 1 as suggested, edited the dial-peer name, and the destination-pattern to
the commands below.
dial-peer voice 3 voip
preference 1
voice-class codec 1
voice-class h323 1
no vad
I am still having the same problem. Rings 2 times, FXO port picks up, and
then nothing else happens. I can change the
voice-port 0/1/3
connection plar 7805    (back to 7805 Hunt Pilot from 180400 extension and the call will go thru to the line group ok).
So I know the incoming line and port are working.
By the way the complete config I sent you had 180404 instead. Because I was using a spare extension in my office to test with. I have matched the same extension numbers in both the "voice-port" and "dial-peer" locations.
Lynn Hedspeth
Where should the call got to? CUCM? If so, what it it's IP address?
You say the FXO rings, is the call actually arriving on this port?
Please post "debug voice dialpeer" and "debug vpm signal"
HTH,
Chris
I had it working by a workaround I thought of this morning. I changed the number that is sent to a 4 digit random number that is passed by the original "dial-peer voice 1 voip". Then added a translation pattern in the CUCM to send the new 4 digit "7099" to the final distination of 180400. It works, but I would still like to know why it won't pass 180400 directly from the router.
We are sending this to the CUCM, and the ip address is 172.25.180.10 which is correct in the dial peer you had me create.
As far as I can tell the call is being answered by the FXO port.
The "debug voice dialpeer", and "debug vpm signal" outputs are below. 1 after the other.
Lynn Hedspeth
DEBUG VOICE DIALPEER LOG
Log Buffer (8192 bytes):
000431: *Jul  4 15:30:27.192 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=180400, Peer Info Type=DIALPEER_INFO_SPEECH
000432: *Jul  4 15:30:27.192 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=180400
000433: *Jul  4 15:30:27.192 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
000434: *Jul  4 15:30:27.192 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=180400, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
000435: *Jul  4 15:30:27.192 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=1
000436: *Jul  4 15:30:27.196 DST: //-1/03B22F018106/DPM/dpMatchPeersCore:
000437: *Jul  4 15:30:27.196 DST: //-1/03B22F018106/DPM/dpMatchPeersCore:
000438: *Jul  4 15:30:27.196 DST: //-1/03B22F018106/DPM/dpMatchPeersCore:
000439: *Jul  4 15:30:27.196 DST: //-1/03B22F018106/DPM/dpMatchSafModulePlugin:
000440: *Jul  4 15:30:27.196 DST: //-1/03B22F018106/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=1
     3: Dial-peer Tag=2
000441: *Jul  4 15:30:27.196 DST: //-1/03B22F018106/DPM/dpMatchPeersCore:
000442: *Jul  4 15:30:27.196 DST: //-1/03B22F018106/DPM/dpMatchPeersCore:
000443: *Jul  4 15:30:27.196 DST: //-1/03B22F018106/DPM/dpMatchPeersCore:
000444: *Jul  4 15:30:27.196 DST: //-1/03B22F018106/DPM/dpMatchSafModulePlugin:
000445: *Jul  4 15:30:27.196 DST: //-1/03B22F018106/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=1
000446: *Jul  4 15:30:27.196 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=180400, Called Number=180400, Peer Info Type=DIALPEER_INFO_SPEECH
000447: *Jul  4 15:30:27.196 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000448: *Jul  4 15:30:27.196 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000449: *Jul  4 15:30:27.196 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
000450: *Jul  4 15:30:27.196 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=1
000451: *Jul  4 15:30:27.196 DST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=180400, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
000452: *Jul  4 15:30:27.196 DST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=3
000453: *Jul  4 15:30:27.196 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
000454: *Jul  4 15:30:27.196 DST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
000455: *Jul  4 15:30:27.196 DST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
000456: *Jul  4 15:30:27.196 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
000457: *Jul  4 15:30:27.196 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000458: *Jul  4 15:30:27.196 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000459: *Jul  4 15:30:27.196 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000460: *Jul  4 15:30:27.196 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
000461: *Jul  4 15:30:27.196 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=1
000462: *Jul  4 15:30:27.196 DST: //-1/03B22F018106/DPM/dpMatchPeersCore:
000463: *Jul  4 15:30:27.196 DST: //-1/03B22F018106/DPM/dpMatchPeersCore:
000464: *Jul  4 15:30:27.196 DST: //-1/03B22F018106/DPM/dpMatchPeersCore:
000465: *Jul  4 15:30:27.196 DST: //-1/03B22F018106/DPM/dpMatchSafModulePlugin:
   dialstring=180400, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
000466: *Jul  4 15:30:27.196 DST: //-1/03B22F018106/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=1
000467: *Jul  4 15:30:27.204 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=, Peer Info Type=DIALPEER_INFO_SPEECH
000468: *Jul  4 15:30:27.204 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
000469: *Jul  4 15:30:27.204 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
000470: *Jul  4 15:30:27.204 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
000471: *Jul  4 15:30:27.204 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000472: *Jul  4 15:30:27.204 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000473: *Jul  4 15:30:27.204 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000474: *Jul  4 15:30:27.204 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
000475: *Jul  4 15:30:27.204 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=1
000476: *Jul  4 15:30:36.544 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000477: *Jul  4 15:30:36.548 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000478: *Jul  4 15:30:36.548 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
000479: *Jul  4 15:30:36.548 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
000480: *Jul  4 15:30:36.548 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000481: *Jul  4 15:30:36.548 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000482: *Jul  4 15:30:36.548 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000483: *Jul  4 15:30:36.548 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
000484: *Jul  4 15:30:36.548 DST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=1
CCS-CO-VoiceGateway-01#no debug voice dialpeer
voip dialpeer default debugging is off
DEBUG VPM SIGNAL LOG
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=1
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=1
   Result=NO_MATCH(-1)
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=1
   Result=NO_MATCH(-1)
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=1
000485: *Jul  4 15:34:48.763 DST: %SYS-5-CONFIG_I: Configured from console by ccsadministrator on vty0 (10.100.254.13)
000486: *Jul  4 15:38:09.606 DST: %SYS-5-CONFIG_I: Configured from console by ccsadministrator on vty0 (10.100.254.13)
000487: *Jul  4 15:39:44.262 DST: htsp_process_event: [0/1/3, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
000488: *Jul  4 15:39:44.262 DST: htsp_timer - 125 msec
000489: *Jul  4 15:39:44.390 DST: htsp_process_event: [0/1/3, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
000490: *Jul  4 15:39:44.390 DST: htsp_timer - 10000 msec
000491: *Jul  4 15:39:44.390 DST: htsp_timer3 - 5600 msec
000492: *Jul  4 15:39:44.390 DST: [0/1/3] htsp_start_caller_id_rx:BELLCORE
000493: *Jul  4 15:39:44.390 DST: htsp_start_caller_id_rx create dsp_stream_manager
000494: *Jul  4 15:39:44.390 DST: [0/1/3] htsp_dsm_create_success  returns 1
000495: *Jul  4 15:39:46.070 DST: htsp_process_event: [0/1/3, FXOLS_RINGING, E_DSP_SIG_0100]
000496: *Jul  4 15:39:46.070 DST: fxols_ringing_not
000497: *Jul  4 15:39:46.070 DST: htsp_timer_stop
000498: *Jul  4 15:39:46.070 DST: htsp_timer - 10000 msec
000499: *Jul  4 15:39:49.990 DST: htsp_process_event: [0/1/3, FXOLS_RINGING, E_HTSP_EVENT_TIMER3]fxols_snoop_clid_stop
000500: *Jul  4 15:39:49.990 DST: htsp_timer_stop3
000501: *Jul  4 15:39:50.002 DST: htsp_process_event: [0/1/3, FXOLS_RINGING, E_DSP_SIG_0000]
000502: *Jul  4 15:39:52.130 DST: htsp_process_event: [0/1/3, FXOLS_RINGING, E_DSP_SIG_0100]
000503: *Jul  4 15:39:52.130 DST: fxols_ringing_not
000504: *Jul  4 15:39:52.130 DST: htsp_timer_stop
000505: *Jul  4 15:39:52.130 DST: htsp_timer_stop3
000506: *Jul  4 15:39:52.130 DST: [0/1/3] htsp_stop_caller_id_rx. message length 0htsp_setup_ind
000507: *Jul  4 15:39:52.130 DST: [0/1/3] get_fxo_caller_id:Caller ID receive failed.  parseCallerIDString:no data.
000508: *Jul  4 15:39:52.130 DST: [0/1/3] get_local_station_id calling num= calling name= calling time=07/04 15:39  orig called=
000509: *Jul  4 15:39:52.130 DST: [0/1/3] htsp_dsm_close_done
000510: *Jul  4 15:39:52.130 DST: htsp_process_event: [0/1/3, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
000511: *Jul  4 15:39:52.130 DST: fxols_wait_setup_ack:
000512: *Jul  4 15:39:52.130 DST: [0/1/3] set signal state = 0xC timestamp = 0fxols_check_auto_call
000513: *Jul  4 15:39:52.134 DST: htsp_process_event: [0/1/3, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
000514: *Jul  4 15:39:52.134 DST: htsp_timer - 120000 msec
000515: *Jul  4 15:39:52.142 DST: htsp_call_bridged invokedhtsp_progress_notify
000516: *Jul  4 15:39:52.146 DST: htsp_process_event: [0/1/3, FXOLS_PROCEEDING, E_HTSP_VOICE_CUT_THROUGH]fxols_proc_voice
000517: *Jul  4 15:40:01.470 DST: htsp_call_bridged invokedhtsp_progress_notify
000518: *Jul  4 15:40:01.478 DST: htsp_process_event: [0/1/3, FXOLS_PROCEEDING, E_HTSP_VOICE_CUT_THROUGH]fxols_proc_voice
000519: *Jul  4 15:40:09.590 DST: htsp_process_event: [0/1/3, FXOLS_PROCEEDING, E_DSP_SIG_1100]fxols_offhook_disc
000520: *Jul  4 15:40:09.590 DST: htsp_timer2 - 350 msec
000521: *Jul  4 15:40:09.942 DST: htsp_process_event: [0/1/3, FXOLS_PROCEEDING, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
000522: *Jul  4 15:40:09.942 DST: htsp_timer_stop
000523: *Jul  4 15:40:09.942 DST: htsp_timer_stop2
000524: *Jul  4 15:40:09.942 DST: htsp_timer_stop3
000525: *Jul  4 15:40:09.958 DST: htsp_process_event: [0/1/3, FXOLS_PROCEEDING, E_HTSP_RELEASE_REQ]fxols_offhook_release
000526: *Jul  4 15:40:09.958 DST: htsp_timer_stop
000527: *Jul  4 15:40:09.958 DST: htsp_timer_stop2
000528: *Jul  4 15:40:09.958 DST: htsp_timer_stop3
000529: *Jul  4 15:40:09.958 DST: [0/1/3] set signal state = 0x4 timestamp = 0
000530: *Jul  4 15:40:09.958 DST: htsp_timer - 2000 msec
000531: *Jul  4 15:40:11.958 DST: htsp_process_event: [0/1/3, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
000532: *Jul  4 15:40:11.958 DST: htsp_process_event: [0/1/3, FXOLS_ONHOOK, E_DSP_SIG_0100]
CCS-CO-VoiceGateway-01#no debug vpm signal
Voice Port Module signaling debugging is disabled
378
