incoming call translation in saudi
HI,
Need some help for incoming translation
I am able  to call Jeddah  by dialing 9  0 12 6521234
but when Incoming call comes its not showing the exact no as above so i am not able to redial from the phone
edwin
Please send "debug voip ccapi
Please send "debug voip ccapi inout" for an inbound call.
Manish
Hello manish, thanks for the
Hello manish, thanks for the response,
i just tried to dial 9 2078292, the call is not going , attached debug
you forget to attach file.
ok i found the pro, i just
ok i found the pro, i just added another dial peer and now i am able to dial
dial-peer voice 1003 pots
 corlist outgoing localcalls
 description "Local Calls"
 preference 2
 destination-pattern 9[1-8]0[1-9]....
 port 0/0/1
 forward-digits 7
 no sip-register
Hello manish , attached in
Hello manish ,
attached in the debug
i am recieving call from 0133437700
so my phone caller id should show 90133437700
but its showing 190133437700
my translation profile is as follow
voice translation-rule 1
 rule 1 /^9/ /6669/
voice translation-rule 9
 rule 1 /\(5.......\)/ /90\1/
 rule 2 /^11\(.......\)/ /9\1/
 rule 3 /\(3.......\)/ /901\1/
 rule 4 /\(4.......\)/ /90\1/
 rule 6 /\(6.......\)/ /90\1/
 rule 7 /\(7.......\)/ /90\1/
 rule 8 /\(012.......\)/ /9\1/
voice translation-profile Phone1
 translate called 1
voice translation-profile incoming_add_9
 translate calling 9
Change rule number 3 like
Change rule number 3 like this...
rule 3 /01\(3.......\)/ /901\1/
Manish
Hi Manish,I was just going
Hi Manish,
I was just going through the issue, i had a small query.
Your suggestion about the rule 3 change is perfect.
But what would be the output of this rule 3 /\(3.......\)/ /901\1/ for the same number 0133437700?
i guess output must be  0190133437700 or 90133437700
Please let me know on this, i am bit confused.
rakesh
0190133437700ThanksManish
0190133437700
Manish
Hi Manish,In that case why
Hi Manish,
In that case why was it giving the output as 190133437700. I hope rule number 3 was matched, If i am not wrong...
the caller id shows 133437700
the caller id shows 133437700 after i change the rule
Edwin , please provide us two
Edwin , please provide us two more debug for an incoming call from 0133437700.
debug isdn q931
debug voice translation rule
i cannot find the "debug isdn
i cannot find the "debug isdn q931" command
i found "debug voice translation"
okay , please post voice
okay , please post voice translation-rule debug
 rule 3 /\(13.......\)/ /90\1
rule 3 /\(13.......\)/ /90\1/
this solved the issue , may be the incoming no was 133437700
my caller id shows 90133437700, so i am able to redial now
116
