10-29-2013 04:46 AM - edited 03-16-2019 08:07 PM
I am new to telephony and trying to learn things which i dont understand fully.
Please let me know whether the incoming called-number . is required under the dail-peer which is pointing to the CUCM.
I understand that it is needed under POTS dail-peer if you using DID.
Solved! Go to Solution.
10-29-2013 06:54 AM
Sure you do, you always want to control which dial-peer you are hitting, so using this is like default route catch all, otherwise a default dial-peer 0 would be used, which may have adverse affect on your desired behavior.
HTH, please rate all useful posts!
Chris
10-29-2013 11:47 AM
This is required for both POTS and voip dial-peer. I dont know what your setup is but it is best practice to do this so you can have control on what dial-peers your call is matching. The default dial-peer 0 is often used when no dial-peers are matched for the inbound leg to the gateway. As I explained, this dial-peer by default has G729 as the codec, has VAD enabled..which you do not want on a voip call. For you to change the characteristics you need to define a dial-peer that will match the inbound leg of your call and then define what codec to use, dtmf-relay, disable VAD etc...This has caused many issues for people in the past..
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
10-30-2013 03:02 AM
The dial-peer pointing to cucm can be both inbound and outbound from the gateway's perspective. When a call comes in from cucm to the gateway, then that will be inbound. When a call is sent to cucm from the gateway, then that will be outbound. You need dial-peers for both
dial-peer voice 1 voip
description inbound from cucm
inoming called number .
dtmf-relay h245-alpha
voice-class codec 1
no vad
dial-peer voice 2 voip
description outbound to cucm
destination-pattern 74..
session target ipv4:10.10.10.10
voice-class codec 1
no vad
In some cases you can have a single dial-peer for both inbound and oubound dial-peer. I dont do it because I like the flexibility of having seperate dial-peers for both
description ***to cucm
incoming called number.
voice-class codec 1
no vad
10-29-2013 05:14 AM
Hi Mahmood
incoming called number used to match the called number in the inbound dialpeer.Look on E1/T1 there are a range of numbers in this case you may need to make some changes or translations only to some called numbers( part of the range) in this case this command will be useful.
Thank you
Please rate all useful information
10-29-2013 05:16 AM
Please find the below link which will help you:-
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Thank you
islam
10-29-2013 06:24 AM
Hi Islam,
Correct me if am wrong.
I dont think we use . for inbound right?
10-29-2013 06:54 AM
Chris
10-29-2013 07:28 AM
Hi Chris,
Thanks for clarifying, I was just thing in any different approach about the post and it got confused me.
Thank you
10-29-2013 10:42 AM
Rakesh..Chris gave a perfect answer and you only gave him 4 points....!!!
10-31-2013 06:19 AM
Hi Chris,
Aokan@ i guess it was a mistake in rating and now i am unable to change it. sorry for that.
10-31-2013 06:44 AM
You can always rate another answer here :-)
Chris
10-29-2013 11:21 AM
Hi Chris,
Thanks for the reply.
I think my question was not clear.
I am refering this to a voip dial-peer which is pointing to CUCM,so please let me know if this is required.
10-29-2013 11:28 AM
Hi mahmood
No , this is not required for voip dial-peer , this is only so important for POTS dial-peer.Please do not forget to rate all useful information.
Thank you
10-29-2013 11:31 AM
Yes it is required! It is a MUST as Chris has explained. Without defining this dial-peer you cant control the following: The type of Codec that your call will use, VAD, dtmf-rely types etc. This is very critical in any deployment.
10-29-2013 11:41 AM
Dear Aokanlawon
Is this required for POTS and VOIP ?. I did many configuration with only incoming calling-number .under pots dial-peer and i did not do any inocming called-numb under VOIP dial-peer and all working as expected .Can you explain please ?.This is the first time , i heared that . Is this manadtory , so why my projects work?.
Thank you
10-29-2013 11:47 AM
10-29-2013 11:56 AM
Everyone knows that under dial-peer voip should configureas destination-pattern , codec , dtmf-relay , no vad , ip of your sub or pub , but my question is regarding incoming called-number . under VOIP dial-peer . Please take a look on cisco document below why cisco not add incoming called-number under dial-peer voip , this is not only my config , many configuration even Cisco , i have advanced services configuration from Cisco for one of my projects , and they did not add this command . yes may be best , but not manadatory:-
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00801142f8.shtml
Thank you
