Community Member
Incoming called number
I need to know if my understanding is correct, can the command incoming called-number command be used in the fxo interface in the gateway or it is limited to an T1 E1 interface.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: Incoming called number
incoming called number used to match the called number in the inbound dialpeer
with FXO you have one number associated with it which mean always one number to be called ( no need )
however with E1/T1 there is a range of numbers in this case you may need to make some changes or translations only to some called numbers( part of the range)  in this case this command will be useful
hops this helps
if helpful Rate
hops this helps
if helpful Rate
Hall of Fame Super Silver
Can you provide us a reason you would want to do this?  As stated FXO line is always tied to one incoming called number, perhaps you meant FXS/DID line which can have mutliple DIDs arive on the same port in which case you can use the command.
HTH,
Chris
4519
