Incoming Caller-ID is unknown for pstn calls for e1 CAS gateway in Argentina
I am having an issue with a gateway which has an e1 cas.
I am not able to see show isdn status command, debug isdn q931.
I have done debug voip ccapi inout and got the following output:
Sep 17 11:04:23 GMT: //-1/BE90E0D594B7/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=19055100
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=1
   cisco-anisi=0
   dest=011
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Sep 17 11:04:23 GMT: //-1/BE90E0D594B7/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x493DB254, Call Info(
   Calling Number=19055100,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Restricted),
   Called Number=011(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=36000, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
   Sub Called(TON=Unknown, NPI=Unknown, Data=, Length=200)
Sep 17 11:04:23 GMT: //-1/BE90E0D594B7/CCAPI/ccCheckClipClir:
   In: Calling Number=19055100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Restricted)
   Out: Calling Number=19055100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Restricted)
Sep 17 11:04:23 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 17 11:04:23 GMT: :cc_get_feature_vsa malloc success
Sep 17 11:04:23 GMT:  cc_get_feature_vsa count is 7
Sep 17 11:04:23 GMT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1228046992,feature_id:3047
Sep 17 11:04:23 GMT: //3052/BE90E0D594B7/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=19055100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Restricted),
   Called Number=011(TON=Unknown, NPI=Unknown))
Sep 17 11:04:23 GMT: //3052/BE90E0D594B7/CCAPI/cc_process_call_setup_ind:
   Event=0x4B55B380
Sep 17 11:04:23 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 011
Sep 17 11:04:23 GMT: //3052/BE90E0D594B7/CCAPI/ccCallSetContext:
   Context=0x4E6569A8
   >>>>CCAPI handed cid 3052 with tag 36000 to app "_ManagedAppProcess_Default"
Sep 17 11:04:23 GMT: //3052/BE90E0D594B7/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Sep 17 11:04:23 GMT: //3052/BE90E0D594B7/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=500, Params=0x4E959850, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Sep 17 11:04:23 GMT: //3052/BE90E0D594B7/CCAPI/ccCheckClipClir:
   Destination Pattern=[1-8]...., Called Number=36011, Digit Strip=FALSE
   Called Number=36011(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=BE90E0D5-1EBF-11E3-94B7-DD708B4E28F4, Outgoing Dial-peer=500
Sep 17 11:04:23 GMT: //3052/BE90E0D594B7/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=19055100
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=1
   cisco-anisi=0
   dest=36011
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Sep 17 11:04:23 GMT: //3052/BE90E0D594B7/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4A9158BC, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=19055100,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Restricted),
   Called Number=36011(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=500, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Sep 17 11:04:23 GMT:  cc_get_feature_vsa count is 8
Sep 17 11:04:23 GMT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1228051024,feature_id:3048
Sep 17 11:04:23 GMT: //3053/BE90E0D594B7/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Sep 17 11:04:23 GMT: //3053/BE90E0D594B7/CCAPI/ccCallSetContext:
   Context=0x4E959800
Sep 17 11:04:23 GMT: //3052/BE90E0D594B7/CCAPI/ccSaveDialpeerTag:
Sep 17 11:04:23 GMT: //3053/BE90E0D594B7/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
Sep 17 11:04:23 GMT: //3053/BE90E0D594B7/CCAPI/cc_api_call_proceeding:
   Interface=0x4A9158BC, Progress Indication=NULL(0)
Sep 17 11:04:23 GMT: //3053/BE90E0D594B7/CCAPI/cc_api_set_delay_xport:
   CallInfo(delay xport=TRUE)
Sep 17 11:04:23 GMT: //3053/BE90E0D594B7/CCAPI/cc_api_call_alert:
   Interface=0x4A9158BC, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Sep 17 11:04:23 GMT: //3052/BE90E0D594B7/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Sep 17 11:04:23 GMT: //3053/BE90E0D594B7/CCAPI/cc_api_call_notify:
   Data Bitmask=0x7, Interface=0x4A9158BC, Call Id=3053
Sep 17 11:04:23 GMT: //3053/BE90E0D594B7/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
Sep 17 11:04:23 GMT: //3053/BE90E0D594B7/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
Sep 17 11:04:23 GMT: //3052/BE90E0D594B7/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=3052
Sep 17 11:04:33 GMT: //3052/BE90E0D594B7/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x493DB254, Call Id=3052
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Sep 17 11:04:33 GMT: //3052/BE90E0D594B7/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=3052
Sep 17 11:04:33 GMT: //3053/BE90E0D594B7/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Sep 17 11:04:33 GMT: //3053/BE90E0D594B7/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Sep 17 11:04:33 GMT: //3052/BE90E0D594B7/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Sep 17 11:04:33 GMT: //3052/BE90E0D594B7/CCAPI/cc_api_get_transfer_info:
Sep 17 11:04:33 GMT: //3053/BE90E0D594B7/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4A9158BC, Tag=0x0, Call Id=3053,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Sep 17 11:04:33 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 17 11:04:33 GMT: :cc_free_feature_vsa freeing 49329248
Sep 17 11:04:33 GMT:  vsacount in free is 7
Hall of Fame Super Gold
E1 CAS is E1 R2, not ISDN. No isdn debug command will show anything.
how can i troubleshoot the unknown caller id issues?
Please suggest a solution
Re: Incoming Caller-ID is unknown for pstn calls for e1 CAS gate
You would have to check all relevant settings. GW has the caller id correctly.
Hello
Can you find the below linkf?.
http://www.cisco.com/en/US/partner/tech/tk652/tk653/technologies_configuration_example09186a00800ad389.shtml
Can you find also the below configuration , i hope this help you?.
controller E1 0/0/0
framing NO-CRC4
line-termination 75-ohm
ds0-group 0 timeslots 1-10 type r2-digital r2-compelled ani
cas-custom 0
country telmex
category 2
answer-signal group-b 1
dnis-digits min 1 max 16
  ani-digits min 0 max 10
  ani-timeout 1
  timer interdigit incoming 1000
  groupa-callerid-end
Thank you
please rate all useful information
761
