Incoming caller id match voice port and cisco callmanager gives a dial tone
charlotterob
We have the following problem,
We have a cisco 2811 with 5 voice ports configured as follows
voice port 1 123-456-7890 FAX
voice port 2 123-456-7880 FAX
voice port 3 123-456-7870 FAX
voice port 4 123-456-7860 CONF
voice port 5 123-456-7850 CONF
ok whats happening is that when a customer call us for example from
785-012-XXXX which match the last four digits of voice port 5 , callmanager answers the call and give the caller a dial tone as if that person was inside our office picking up a handset of one of our phones, instead to route the call to the main extension callmanager give the caller matching the first 4 digits of its caller id a dial tone?
i have look everywhere and i cant find a solution
24 Replies 24
when i do
#debug isdn q931
shows the following
voice-2811#debug isdn q931
debug isdn q931 is ON.
voice-2811#
then when i do
voice-2811#term mon
voice-2811#
Right. Now when a call comes is, you should see the Q931 output. Assuming you are telnetting to the router and the default debug logging options have not been changed.
it doesnt do anything, i too was waiting for some kind of log to show up
but no log was showing, yes i am using telnet to access.
Do show log. If debug to monitor has been disabled, maybe the the debug is there.
You can reenable monitor output with:
logging monitor debugging
Anyway. Assuming the called number is presented four digit, and the DP is set with direct-inward dial and incoming called-number ....
(four dots literally, not the full fax number)
Then the fax should answer calls from outside from any calling number.
voice-2811#show log
Syslog logging: enabled (11 messages dropped, 21 messages rate-limited,
0 flushes, 0 overruns, xml disabled, filtering disabled)
Console logging: level critical, 0 messages logged, xml disabled,
filtering disabled
Monitor logging: disabled
Buffer logging: level notifications, 204 messages logged, xml disabled,
filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
No active filter modules.
Trap logging: level informational, 457 message lines logged
Log Buffer (4096 bytes):
19:55.387 EST: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0,
changed state to up
000183: *Jan 13 14:19:55.391 EST: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state t
o down
000184: *Jan 13 14:19:55.391 EST: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administratively do
wn
000185: *Jan 13 14:19:55.499 EST: %SYS-5-CONFIG_I: Configured from memory by console
000186: *Jan 13 14:19:55.851 EST: %SYS-5-RESTART: System restarted --
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.3(11)T10, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 03-Mar-06 19:06 by dchih
000187: *Jan 13 14:19:55.867 EST: %SNMP-5-COLDSTART: SNMP agent on host voice-2811 is undergoing a cold start
000188: *Jan 13 14:19:58.659 EST: %DSPRM-5-UPDOWN: DSP 5 in slot 0, changed state to up
000457: Mar 27 23:08:33.341 EST: %SYS-5-CONFIG_I: Configured from console by xxxx on vty0 (192.168.xxx.xxx)
000458: Mar 27 23:12:08.061 EST: %SYS-5-CONFIG_I: Configured from console by xxxx on vty0 (192.168.xxx.xxx)
000459: Mar 27 23:13:16.577 EST: %SYS-5-CONFIG_I: Configured from console by xxxx on vty0 (192.168.xxx.xxx)
000460: Mar 27 23:16:46.844 EST: %SYS-5-CONFIG_I: Configured from console by xxxx on vty0 (192.168.xxx.xxx)
000461: Mar 27 23:25:38.250 EST: %SYS-5-CONFIG_I: Configured from console by xxxx on vty0 (192.168.xxx.xxx)
000462: Mar 27 23:29:32.574 EST: %SYS-5-CONFIG_I: Configured from console by xxxx on vty0 (192.168.xxx.xxx)
000463: Mar 28 16:36:01.237 EST: %SYS-5-CONFIG_I: Configured from console by xxxx on vty0 (192.168.xxx.xxx)
000622: Mar 28 17:16:40.785 EST: %SYS-5-CONFIG_I: Configured from console by xxxx on vty0 (192.168.xxx.xxx)
can you explain to me again about the ....
thank you
Here you go, you had monitor logging disabled. reenter it as I indicated above.
Then retake the call.
You don't need to obscure private address in info configuration; they don't mean a thing to anybody.
#dial-peer voice 1015 pots
direct-inward-dial
fix the issue, you were right about telco passing only 4 digits, thank you very much for all your help, and i guess i will put this issue in my book! but without you i couldnt fixed, it always takes more than 1 head to fix a cisco problem. thank you very much god bless you!
Thank you very much for the nice words and rating. Good luck and have fun, if you can, with these things.
Hi Paolo,
Very nice work here :) You really showed a great deal of patience and follow through as well as excellent technical knowledge!
5 points from me all day long!
Thanks again,
Rob
Yes he was great and really patient with me, without his knowledge i wouldnt be able to do it
Thanks paolo
