11-13-2013 04:35 AM - edited 03-16-2019 08:22 PM
Hello community,
i have a Call Manager 8.6.
Is it possible somehow to import some external numbers (about 1000) so, when they call me , to show something else in the phone display ?
For example :
Caller number +302106111119, imported as "Customer 1", and phone display shows "Customer 1".
I dont think that is possible, but i said to ask here first
Nick
Solved! Go to Solution.
11-13-2013 07:10 AM
Hi Nick,
This can be accomplished using a script from top NetPro
Paolo;
Check number2name
Cheers!
Rob
"Why do the best things always disappear "
- The Band
11-13-2013 07:10 AM
Hi Nick,
Paolo;
Check number2name
Cheers!
Rob
- The Band
11-15-2013 01:20 AM
Hi Rob,
Once again, thanks a lot !
11-15-2013 07:09 AM
Hi Nick,
You are always welcome buddy!
Cheers!
Rob
- The Band
11-18-2013 02:39 AM
Hi Nick,
other option could be to install 3rd party app to handle your needs.
E.g. 2Ring PHONE SERVICES would be the best choice for you.
There is also really powerfull synchronization, so you are able to import as many contacts as you want from various sources.
Just follow the link (http://www.2ring.com/NewJuice) to check it out and moreover, FREE or TRIAL license is available.
HTH,
Martin
