Incoming calls fail
Here is the situation ...
PSTN --- (ISDN BRI)-H323 --- Call Manager --- Ip Phone
Outgoing calls are fine. Incoming calls into ISDN BRI fail with ISDN cause code :
Cause i = 0x809B - Destination out of order
I have attached a debug isdn q931 and a debug voip ccapi inout
Hall of Fame Super Gold
Re: Incoming calls fail
CCM gets '214510164' and doesn't know what to do with that.
You have to transform number into a valid extension either at GW or CCM level.
If you have done that already, check it again.
Quick reply :)
I have a "2145101XX" Translation pattern on the CCM with a Called Party Transform Mask of an internal IP extension!
Sorry, I correct myself. CCM unaware of the number would be "destination unknow".
You get instead out-of-order that leads me to think some misconfiguration but I'm unable to tell what exactly, it's on the CM however.
Unrelated, you may want to set netwrock-clock-participate for your BRIs and isdn tei-negotiation preserve.
Check the calling search space for the H323 gateway, be sure that this calling search space has the translation pattern's partition in it. Subsequently, check the calling search space of your translation pattern, and be sure it contains the partition in which your internal extension resides.
Hope that helped, if so please rate.
1) CSS for GW and phone is the same
2) CSS has phone partition in it
3) Translation Pattern and Phone are in same partition
Also when I dial the Translation pattern from another internal phone it rings the correct extension.
Does the GW CSS have the translation pattern's partition in it?
Yup
Just to be sure, why don't make the DDI translation on the GW, do you know how to use translation-profile and rule ?
So I made a translation profile on the gateway that looks like this:
voice translation-rule 10
rule 1 /2145101../ /1814/
voice translation-profile #Incoming-to-Reception#
translate calling 10
dial-peer voice 1 voip
translation-profile incoming #Incoming-to-Reception#
destination-pattern 2145101..
voice-class codec 1
session target ipv4:10.1.100.252
no vad
I keep getting the same error!
You applied the profile as incoming, must be outgoing under DP 1.
Also make sure the rule is right with "test voice translation-rule 10 xxxxxxx".
If still same error that proves something on CM in really wrong.
Hi All,
I wasn't sourcing my H323 traffic. I added the following command under the voice VLAN on the 4244 and it worked straight away.
h323-gateway voip bind srcaddr 172.16.100.2
Thanks for the suggestions
394
