Incoming calls from PSTN cannot be completed
Hello guys!
          Outgoing calls work great (except MOH), but when placing an incoming call from the PSTN to the Voice Gateway and then to the CUCM 8.5 the caller gets the message that the call cannot be completed at this time. The scenario is simple:
1. CUCM 8.5 (the voice gateway is configured as an H323 device in the CUCM)
2. Cisco 2921 as Voice Gateway (CISCO2921-V/K9)
3. SIP trunk to PSTN
These are the dial peers configured on the Cisco 2921 (attached is the debug voip ip dialpeer output):
dial-peer voice 2 voip
translation-profile outgoing 1
destination-pattern 787.......
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 20 voip
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 200 voip
translation-profile outgoing GCHC_Main_Pilot
destination-pattern 787687....
session target ipv4:192.168.70.2
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2000 voip
destination-pattern 939.......
dtmf-relay rtp-nte
codec g711ulaw
no vad
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Does the SIP trunk on CUCM has CSS assigned with pairtion of the phone you are calling?
Can you post "debug ccsip messages"
Chris
Chris
Hello Chris,
       As you mentioned, I added the CSS on the h323 gateway configuration window on the CUCM under Call Routing Information - Inbound Calls and now the call gets routed to extention 200 as intended but when answered the calling party from the PSTN keeps ringing. Here the  debug ccsip messages (sorry for the long message):
Apr 18 16:33:53.322: //-1/Msg/ccsipDisplayMsg:
Received:
INVITE sip:7876871300@10.32.116.242:5060 SIP/2.0
Via: SIP/2.0/UDP 10.32.1.90:5060;branch=z9hG4bKs7748f10c8b0jjcg93c0.1
To: "7876871300 7876871300"<>7876871300@gurabocommunitypr.com>
Call-ID: BW123523979180412-1245035637@10.31.1.4
CSeq: 589789286 INVITE
Contact: <7872350808>
Supported: 100rel
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY
Accept: multipart/mixed,application/media_control+xml,application/sdp
Max-Forwards: 69
Content-Type: application/sdp
Content-Length: 201
v=0
o=BroadWorks 12005838 1 IN IP4 10.32.1.90
s=-
c=IN IP4 10.32.1.90
t=0 0
m=audio 52386 RTP/AVP 18 0 13 101
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
a=fmtp:18 annexb=no
Apr 18 16:33:53.326: //-1/dpMatchPeersCore:
   Calling Number=7876871300, Called Number=7876871300, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=7876871300
Apr 18 16:33:53.326: //-1/dpMatchCore:
   Dial String=7876871300, Expanded String=7876871300, Calling Number=7876871300T
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Apr 18 16:33:53.326: //-1/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=2 Is Matched
   Result=Success(0); Outgoing Dial-peer=200 Is Matched
   Result=Success(0) after DP_MATCH_DEST
Apr 18 16:33:53.326: //-1/dpMatchSafModulePlugin:
   dialstring=7876871300, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Apr 18 16:33:53.326: //-1/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=200
     2: Dial-peer Tag=2
Apr 18 16:33:53.326: //-1/dpAssociateIncomingPeerCore:
   Calling Number=7872350808, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Match Rule=DP_MATCH_ANSWER; Calling Number=7872350808
Apr 18 16:33:53.326: //-1/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
   Dial String=, Expanded String=, Calling Number=7872350808T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
Apr 18 16:33:53.326: //-1/dpMatchPeertype:exit@5908
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=7872350808
   Result=Success(0); Incoming Dial-peer=2 Is Matched
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Apr 18 16:33:53.326: //-1/dpAssociateIncomingPeer:exit@6520
   Result=-1
   Calling Number=7872350808, Called Number=7876871300, Voice-Interface=0x0,
   Match Rule=DP_MATCH_REQUEST_URI; URI=sip:7876871300@10.32.116.242:5060
   Result=-1
   Match Rule=DP_MATCH_TO_URI; URI=sip:7876871300@gurabocommunitypr.com
   Result=-1
   Match Rule=DP_MATCH_FROM_URI; URI=sip:7872350808@10.31.1.4;user=phone
   Result=-1
   Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=7876871300
   Result=Success(0); Incoming Dial-peer=20 Is Matched
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=20
Apr 18 16:33:53.326: //-1/dpAssociateIncomingPeerSPI:exit@6471
Apr 18 16:33:53.330: //-1/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 18 Apr 2012 16:33:53 GMT
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Apr 18 16:33:53.330: //-1/dpMatchPeersCore:
   Calling Number=, Called Number=7876871300, Peer Info Type=DIALPEER_INFO_SPEECH
Apr 18 16:33:53.330: //-1/dpMatchCore:
Apr 18 16:33:53.330: //-1/MatchNextPeer:
Apr 18 16:33:53.330: //-1/dpMatchSafModulePlugin:
   dialstring=7876871300, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Apr 18 16:33:53.330: //-1/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=2
   Result=SUCCESS(0)
     2: Dial-peer Tag=2
   Result=SUCCESS(0)
     2: Dial-peer Tag=2
Apr 18 16:33:53.330: //-1/dpAssociateIncomingPeerCore:
   Calling Number=7876871300, Called Number=, Voice-Interface=0x0,
   Match Rule=DP_MATCH_ANSWER; Calling Number=7876871300
Apr 18 16:33:53.330: //-1/dpMatchPeertype:
   Dial String=, Expanded String=, Calling Number=7876871300T
   Result=-1
Apr 18 16:33:53.330: //-1/dpMatchPeertype:exit@5908
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=7876871300
   Result=Success(0); Incoming Dial-peer=200 Is Matched
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=200
Apr 18 16:33:53.330: //-1/dpAssociateIncomingPeer:exit@6520
   Result=-1
   Result=SUCCESS(0)
     2: Dial-peer Tag=2
   Result=SUCCESS(0)
     2: Dial-peer Tag=2
Apr 18 16:33:53.338: //-1/dpMatchPeersCore:
   Calling Number=, Called Number=7872350808, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=7872350808
Apr 18 16:33:53.338: //-1/dpMatchCore:
   Dial String=7872350808, Expanded String=7872350808, Calling Number=
Apr 18 16:33:53.338: //-1/MatchNextPeer:
Apr 18 16:33:53.338: //-1/dpMatchSafModulePlugin:
Apr 18 16:33:53.338: //-1/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
Apr 18 16:33:53.338: //-1/dpAssociateIncomingPeerCore:
   Calling Number=200, Called Number=, Voice-Interface=0x0,
   Match Rule=DP_MATCH_ANSWER; Calling Number=200
Apr 18 16:33:53.338: //-1/dpMatchPeertype:
   Dial String=, Expanded String=, Calling Number=200T
   Result=-1
Apr 18 16:33:53.338: //-1/dpMatchPeertype:exit@5908
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=200
   Result=-1
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Apr 18 16:33:53.338: //-1/dpAssociateIncomingPeer:exit@6520
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
   Calling Number=, Called Number=200, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=200
   Dial String=200, Expanded String=200, Calling Number=
   Result=-1
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
   Result=NO_MATCH(-1)
Apr 18 16:33:53.338: //-1/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: "7876871300 7876871300"<>7876871300@gurabocommunitypr.com>;tag=4899D94-E0
Require: 100rel
RSeq: 4830
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Contact: <10.32.116.242:5060>
Content-Length: 0
Apr 18 16:33:53.346: //-1/Msg/ccsipDisplayMsg:
Received:
PRACK sip:10.32.116.242:5060 SIP/2.0
Via: SIP/2.0/UDP 10.32.1.90:5060;branch=z9hG4bKt7k8c120cg41sig7i5k1.1
CSeq: 589789287 PRACK
RAck: 4830 589789286 INVITE
Max-Forwards: 69
Content-Length: 0
Apr 18 16:33:53.350: //-1/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Content-Length: 0
Apr 18 16:34:13.104: //-1/dpAssociateIncomingPeerCore:
   Calling Number=787687...., Called Number=, Voice-Interface=0x0,
   Match Rule=DP_MATCH_ANSWER; Calling Number=787687....
Apr 18 16:34:13.104: //-1/dpMatchPeertype:
Apr 18 16:34:13.104: //-1/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=787687....T
   Result=-1
Apr 18 16:34:13.104: //-1/dpMatchPeertype:exit@5908
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=787687....
   Result=-1
Apr 18 16:34:13.104: //-1/dpMatchSafModulePlugin:
Apr 18 16:34:13.104: //-1/dpAssociateIncomingPeer:exit@6520
Apr 18 16:34:13.108: //-1/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:7876871300@gurabocommunitypr.com:5060 SIP/2.0
Via: SIP/2.0/UDP 10.32.116.242:5060;branch=z9hG4bKB56A2
From: <>7872350808@gurabocommunitypr.com>;tag=489EAD0-1E32
To: <>7876871300@gurabocommunitypr.com>
Date: Wed, 18 Apr 2012 16:34:13 GMT
Call-ID: 2A777967-88AB11E1-80CDB966-5A2A7388@10.32.116.242
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0514655897-2292912609-2160507238-1512731528
User-Agent: Cisco-SIPGateway/IOS-12.x
CSeq: 101 INVITE
Timestamp: 1334766853
Expires: 180
Max-Forwards: 68
Content-Disposition: session;handling=required
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 5680 8555 IN IP4 10.32.116.242
s=SIP Call
c=IN IP4 10.32.116.242
t=0 0
m=audio 19086 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-15
a=ptime:20
Apr 18 16:34:13.112: //-1/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Apr 18 16:34:13.124: //-1/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <>7876871300@gurabocommunitypr.com>;tag=361963164-1334766943785
CSeq: 101 INVITE
Supported:
Contact: <7876871300>
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Content-Length: 0
Apr 18 16:34:13.124: //-1/dpMatchPeersCore:
Apr 18 16:34:13.124: //-1/dpMatchCore:
Apr 18 16:34:13.124: //-1/MatchNextPeer:
Apr 18 16:34:13.124: //-1/dpMatchSafModulePlugin:
Apr 18 16:34:13.124: //-1/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
Apr 18 16:34:13.124: //-1/dpAssociateIncomingPeerCore:
Apr 18 16:34:13.124: //-1/dpMatchPeertype:
   Result=-1
Apr 18 16:34:13.124: //-1/dpMatchPeertype:exit@5908
Apr 18 16:34:13.124: //-1/dpAssociateIncomingPeer:exit@6520
Sent:
SIP/2.0 180 Ringing
Require: 100rel
RSeq: 4831
Content-Length: 0
Apr 18 16:34:13.132: //-1/Msg/ccsipDisplayMsg:
Received:
PRACK sip:7876871300@10.32.116.242:5060 SIP/2.0
Via: SIP/2.0/UDP 10.32.1.90:5060;branch=z9hG4bKgqhu7m009gkgrjkjb3s1.1
CSeq: 589789288 PRACK
RAck: 4831 589789286 INVITE
Max-Forwards: 69
Content-Length: 0
Apr 18 16:34:13.136: //-1/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Content-Length: 0
Apr 18 16:34:13.180: //-1/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported:
Content-Length: 196
v=0
o=BroadWorks 12006052 1 IN IP4 10.32.1.90
s=-
t=0 0
m=audio 50516 RTP/AVP 0 101
c=IN IP4 10.32.1.90
a=fmtp:101 0-15
a=ptime:20
Sent:
ACK sip:7876871300@10.32.1.90:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.32.116.242:5060;branch=z9hG4bKB6A9D
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Apr 18 16:34:13.180: //-1/dpMatchPeersCore:
Apr 18 16:34:13.184: //-1/dpMatchCore:
Apr 18 16:34:13.184: //-1/MatchNextPeer:
Apr 18 16:34:13.184: //-1/dpMatchPeersCore:
Apr 18 16:34:13.184: //-1/dpMatchSafModulePlugin:
Apr 18 16:34:13.184: //-1/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
Apr 18 16:34:13.184: //-1/dpAssociateIncomingPeerCore:
Apr 18 16:34:13.184: //-1/dpMatchPeertype:
   Result=-1
Apr 18 16:34:13.184: //-1/dpMatchPeertype:exit@5908
Apr 18 16:34:13.184: //-1/dpAssociateIncomingPeer:exit@6520
   Result=-1
Apr 18 16:34:13.184: //-1/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Supported: replaces
Supported: sdp-anat
Content-Length: 249
v=0
o=CiscoSystemsSIP-GW-UserAgent 587 4483 IN IP4 10.32.116.242
s=SIP Call
t=0 0
m=audio 29260 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Apr 18 16:34:13.196: //-1/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.32.1.90:5060;branch=z9hG4bKia54eh10a8g00l8q44c1.1
CSeq: 589789286 ACK
Max-Forwards: 69
Content-Length: 0
Apr 18 16:34:13.912: //-1/Msg/ccsipDisplayMsg:
Received:
BYE sip:7876871300@10.32.116.242:5060 SIP/2.0
Via: SIP/2.0/UDP 10.32.1.90:5060;branch=z9hG4bKia54eh10a8g00l8q44c1cd3p9gnk1.1
CSeq: 589789289 BYE
Max-Forwards: 69
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 589789289 BYE
Reason: Q.850;cause=16
Content-Length: 0
Sent:
BYE sip:7876871300@10.32.1.90:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.32.116.242:5060;branch=z9hG4bKB717CE
Max-Forwards: 70
CSeq: 102 BYE
Content-Length: 0
Apr 18 16:34:13.912: //-1/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
Apr 18 16:34:13.912: //-1/dpMatchSafModulePlugin:
Apr 18 16:34:13.912: //-1/dpAssociateIncomingPeer:exit@6520
Apr 18 16:34:13.924: //-1/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
Apr 18 16:34:13.928: //-1/dpAssociateIncomingPeerCore:
   Calling Number=787......., Called Number=, Voice-Interface=0x0,
   Match Rule=DP_MATCH_ANSWER; Calling Number=787.......
Apr 18 16:34:13.928: //-1/dpMatchPeertype:
Apr 18 16:34:13.928: //-1/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=787.......T
   Result=-1
Apr 18 16:34:13.928: //-1/dpMatchPeertype:exit@5908
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=787.......
   Result=-1
Apr 18 16:34:13.928: //-1/dpMatchSafModulePlugin:
Apr 18 16:34:13.928: //-1/dpAssociateIncomingPeer:exit@6520
Green
You debug shows the 1st match is DP 200
What does this profile do
Please post the rules & profile
Alex
Regards, Alex. Please rate useful posts.
The profile and rules translate the called number to extention 200.
Here it is:
voice translation-rule 1
rule 1 /7876871300/ /200/
voice translation-profile GCHC_Main_Pilot
translate called 1
Green
Re: Incoming calls from PSTN cannot be completed
So the digits 2000 will be sent to CUCM
What is dn 2000 on CUCM ?
What is the expected DN length on the CUCH H323 gateway ?
Does the H323 gateway on CUCM have an incoming CSS that allows the partition with dn 2000 ?
Alex
Your traces look weird, what is the following:
10.32.1.90
10.32.116.242
What is your sip-server defined as? Post the sip-ua configuration.
Chris
Here is the voice gateway config guys:
version 15.0
service password-encryption
hostname gchc_voice_gateway
boot-start-marker
boot-end-marker
enable password 7 13064601085C557878
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone AST -4
clock calendar-valid
no ipv6 cef
ip source-route
ip cef
ip domain name gchccmf-domain
ip name-server 10.32.1.7
ip name-server 10.32.1.8
voice-card 0
voice call debug short-header
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
   outbound-proxy dns:sbcentdid.centixvoip.net
  early-offer forced
  midcall-signaling passthru
translate called 1
license udi pid CISCO2921/K9 sn FTX1545A15K
hw-module pvdm 0/0
username admin password 7 01105717585B575D72
username ncotto password 7 153C581C0C7D2A2879
redundancy
interface GigabitEthernet0/0
description Up-link to at&t PSTN
ip address 10.32.116.242 255.255.255.252
duplex full
speed 100
interface GigabitEthernet0/1
description VoIP Network Gateway
ip address 192.168.70.1 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.70.1
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
router ospf 1
log-adjacency-changes
network 10.32.116.240 0.0.0.3 area 0
network 192.168.70.0 0.0.0.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.32.116.241
ip route 10.0.0.0 255.255.255.248 192.168.70.4
ip route 10.32.1.7 255.255.255.255 10.32.116.241
ip route 10.32.1.8 255.255.255.255 10.32.116.241
control-plane
dtmf-relay rtp-nte
codec g711ulaw
no vad
dtmf-relay rtp-nte
codec g711ulaw
no vad
dtmf-relay rtp-nte
codec g711ulaw
no vad
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
credentials username 7876871300 password 7 071F33181E5D4A5641 realm gurabocommunitypr.com
authentication username 7876871300 password 7 071F33181E5D4A5641 realm gurabocommunitypr.com
no remote-party-id
set pstn-cause 47 sip-status 486
registrar dns:gurabocommunitypr.com expires 3600
sip-server dns:gurabocommunitypr.com
host-registrar
gatekeeper
shutdown
Hello Alex,
      The 200 is the receptionist directory number. The siginificant digits is set to All on gateway, and i just added the CSS on the gateway. So now the call gets routed to extention 200 as intended but when answered the calling party from the PSTN keeps ringing like if the call were not answered.
Please post full configuration and IOS version.
Chris
IOS version?
Can you post a clean "debug ccsip messages" again after the "improvement"?
Chris
Chris, the IOS version is 15.0(1)M7, RELEASE SOFTWARE (fc2). Here is the debug ccsip messages after imprvement:
Apr 18 17:01:22.316: //-1/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.32.1.90:5060;branch=z9hG4bK81ilvh10eol0eh0mg480.1
Call-ID: BW130253161180412-2024119031@10.31.1.4
CSeq: 590613877 INVITE
Supported: 100rel
Max-Forwards: 69
Content-Length: 201
v=0
o=BroadWorks 12028520 1 IN IP4 10.32.1.90
s=-
c=IN IP4 10.32.1.90
t=0 0
m=audio 53676 RTP/AVP 18 0 13 101
a=fmtp:101 0-15
a=ptime:20
a=fmtp:18 annexb=no
Apr 18 17:01:22.320: //-1/dpMatchPeersCore:
Apr 18 17:01:22.320: //-1/dpMatchCore:
Apr 18 17:01:22.320: //-1/MatchNextPeer:
Apr 18 17:01:22.320: //-1/dpMatchSafModulePlugin:
Apr 18 17:01:22.320: //-1/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=2
Apr 18 17:01:22.320: //-1/dpAssociateIncomingPeerCore:
Apr 18 17:01:22.320: //-1/dpMatchPeertype:
   Result=-1
Apr 18 17:01:22.320: //-1/dpMatchPeertype:exit@5908
Apr 18 17:01:22.320: //-1/dpAssociateIncomingPeer:exit@6520
   Result=-1
   Result=-1
   Result=-1
   Result=-1
Apr 18 17:01:22.320: //-1/dpAssociateIncomingPeerSPI:exit@6471
Apr 18 17:01:22.324: //-1/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 18 Apr 2012 17:01:22 GMT
Content-Length: 0
Apr 18 17:01:22.324: //-1/dpMatchPeersCore:
Apr 18 17:01:22.324: //-1/dpMatchCore:
Apr 18 17:01:22.324: //-1/MatchNextPeer:
Apr 18 17:01:22.324: //-1/dpMatchSafModulePlugin:
Apr 18 17:01:22.324: //-1/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=2
   Result=SUCCESS(0)
     2: Dial-peer Tag=2
   Result=SUCCESS(0)
     2: Dial-peer Tag=2
Apr 18 17:01:22.324: //-1/dpAssociateIncomingPeerCore:
Apr 18 17:01:22.324: //-1/dpMatchPeertype:
   Result=-1
Apr 18 17:01:22.324: //-1/dpMatchPeertype:exit@5908
Apr 18 17:01:22.324: //-1/dpAssociateIncomingPeer:exit@6520
   Result=-1
   Result=SUCCESS(0)
     2: Dial-peer Tag=2
   Result=SUCCESS(0)
     2: Dial-peer Tag=2
Apr 18 17:01:22.332: //-1/dpMatchPeersCore:
Apr 18 17:01:22.332: //-1/dpMatchCore:
Apr 18 17:01:22.332: //-1/MatchNextPeer:
Apr 18 17:01:22.332: //-1/dpMatchSafModulePlugin:
Apr 18 17:01:22.332: //-1/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
Apr 18 17:01:22.332: //-1/dpAssociateIncomingPeerCore:
Apr 18 17:01:22.332: //-1/dpMatchPeertype:
   Result=-1
Apr 18 17:01:22.332: //-1/dpMatchPeertype:exit@5908
   Result=-1
Apr 18 17:01:22.332: //-1/dpAssociateIncomingPeer:exit@6520
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
   Result=-1
   Result=NO_MATCH(-1)
Apr 18 17:01:22.336: //-1/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: "7876871300 7876871300"<>7876871300@gurabocommunitypr.com>;tag=4A2C7B8-1F2C
Require: 100rel
RSeq: 3808
Content-Length: 0
Apr 18 17:01:22.344: //-1/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.32.1.90:5060;branch=z9hG4bK99vpj320e8h14kosn101.1
CSeq: 590613878 PRACK
RAck: 3808 590613877 INVITE
Max-Forwards: 69
Content-Length: 0
Sent:
SIP/2.0 200 OK
Content-Length: 0
Apr 18 17:01:37.343: //-1/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:7876871300@10.32.116.242:5060 SIP/2.0
CSeq: 590613877 CANCEL
Max-Forwards: 69
Content-Length: 0
Apr 18 17:01:37.347: //-1/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 18 Apr 2012 17:01:37 GMT
Content-Length: 0
Sent:
SIP/2.0 487 Request Cancelled
Content-Length: 0
Apr 18 17:01:37.347: //-1/dpAssociateIncomingPeerCore:
Apr 18 17:01:37.347: //-1/dpMatchPeertype:
Apr 18 17:01:37.347: //-1/dpMatchCore:
   Result=-1
Apr 18 17:01:37.347: //-1/dpMatchPeertype:exit@5908
   Result=-1
Apr 18 17:01:37.347: //-1/dpMatchSafModulePlugin:
Apr 18 17:01:37.347: //-1/dpAssociateIncomingPeer:exit@6520
Apr 18 17:01:37.351: //-1/Msg/ccsipDisplayMsg:
Received:
CSeq: 590613877 ACK
Max-Forwards: 69
Content-Length: 0
Apr 18 17:01:37.351: //-1/dpAssociateIncomingPeerCore:
Apr 18 17:01:37.351: //-1/dpMatchSafModulePlugin:
Apr 18 17:01:37.351: //-1/dpAssociateIncomingPeer:exit@6520
Thanks Chris and all of you guys. The problem of incoming calls from the PSTN that kept ringing after being answered internally on the directory numbers was sloved by enabling fast start on the Device Gateway config page on the CUCM8.5 and disabling the
353
