Incoming calls from PSTN during SRST operation mode
Branch IP phones work in a SRST mode during WAN or CUCM failure.
IP phones register on a router with extensions. 2....
These extensions correspond to PSTN number range 67032...
The problem: incoming calls from PSTN don't work, outgoing calls to PSTN work fine.
Could anyone point  what wrong or missed in the configuration shown below?
voice translation-rule 1
rule 1 /^/ /9/
voice translation-rule 2
rule 1 /^6703\(....\)$/ /\1/
voice translation-rule 3
rule 1 /^\(2...\)$/ /6703\1/
voice translation-profile INCOMING
translate calling 1
voice translation-profile SRST_IN
translate called 2
voice translation-profile SRST_OUT
translate calling 3
voice-port 0/2/0:15
dial-peer voice 1 pots
description incoming from PSTN
translation-profile incoming INCOMING
incoming called-number .
direct-inward-dial
dial-peer voice 10 pots
description outgoing to PSTN
destination-pattern 9T
port 0/2/0:15
dial-peer voice 100 voip
destination-pattern 67032...
voice-class codec 1
session target ipv4:10.100.1.2
dtmf-relay h245-alphanumeric
no vad
call-manager-fallback
max-conferences 8 gain -6
ip source-address 10.100.2.1 port 2000
max-ephones 100
max-dn 200
translation-profile incoming SRST_IN
translation-profile outgoing SRST_OUT
  • IP Telephony
1 ACCEPTED SOLUTION
Super Bronze
Re: Incoming calls from PSTN during SRST operation mode
I see your error... basically you are trying to apply trans rule 2 to incoming calls, but have applied it under call-man-fallback mode.
This means it applies to calls to/from ephones - the outbound leg in this case.
As the call coming in hasn't been sent to any ephone yet, it doesn't hit the translation.
You need to translate it either on the inbound peer (dp 1) or use the dialplan-pattern command under call-manager-fallback.
e.g.
dialplan-pattern 1 67032... extension-length 4 extension-pattern 2...
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Do a debug isdn q931 first, to see what the SP actually sends. It may not be 8 digits.
Aaron
I have already done q931 debug. SP sends 8 digits
would it be easier to apply a translation to the voice-port so that the 8 digits are converted to match your dial plan?
during normal operation all translations that convert 8 digit PSTN numbers to internal dialplan  are made on CUCM.
Super Bronze
e.g.
Aaron
I agree that this translation might not work.
I have thought about this command: "dialplan-pattern" before. But I am not sure how this command work.
In my case I have " voice dial-peer 100" voip with destination-pattern 67032.... which sends all incoming calls to CUCM.
Will "dialplan-pattern'' commnad have preference over dial-peer 100 during SRST and why ?
Could you point to some documention how call routing logic works during SRST ?
what's the intention of translation-rule 1?
This rule add 9 to the calling number. Users can callback from  "missed calls " menu on IP phones without editing numbers
391
