Incoming Calls from PSTN Not Working on SPA400/SPA9000
I give up!!  I have been spent two whole days on this and can't figure it out!  I have just installed a voip system using a SPA400 gateway for 2 PSTN lines connecting to a SPA9000 with 2 phones (both SPA942).  I'm only using PSTN service.  I got everything working except for the most important thing -- no incoming calls!  Outbound calls work fine.  All internal calls work.  Voice mail works.  AA works internally.
Here's my setup . . .
I installed everything entirely from the setup wizard.  Connected the SPA400 to the network.  Connected the SPA9000 to the network.  Ran the Setup Wizard.  Both devices were discovered.  I meticulously followed the steps.  Upgraded the firmware on all devices (SPA400, SPA9000, SPA942s).  Setup the 2 PSTN phone lines on the SPA400 to connect to Line 1 of the SPA9000.  Setup incoming calls to route to Ext 101, then to AA (101, cfwd=AA).  After completing all the steps, running through a series of reboots I got outbound calls to go through.  Voice mail setup was a breeze (to my surprise).   When I try to receive a call from the outside -- no go.
Here's what happens . . .
1. With both lines connected to the SPA400 Lines 1 and 2 -- I see the line 1 LED on the SPA400 flash as the call comes in.  After about 2-3 rings the both the Line 1 and Line 2 LEDs goes solid on the SPA400 (odd I thought) and then after about 2 more rings the call is drop (the caller hears the standard AT&T message -- beep, beep, beep "We're sorry, your call did not go through . . .).
2. If only ONE line is plugged into the SPA400 (I was just curious to see what would happen so I pulled one of the lines) as call comes in the LED flashes on the SPA400 for the associate line and this time the call just rings forever (no messages, no pick up).
Here's what I've done . . .
I've tried factory resets, various reboot sequences, manual config of SPA9000 and SPA400, reran Setup Wizard about a million times.  It's absolutely killing me -- what am I missing here?
Can anyone help?
Everyone's tags (3)
1 REPLY
Re: Incoming Calls from PSTN Not Working on SPA400/SPA9000
Lee
I have a few suggestions to try:
1 Silly one - is extension 101 properly registered and does not have DND or call divert set up permanently?
2 Have you tried setting up an ITSP account (some are free to setup and just require top-ups if you make outgoing calls) and seeing if inbound calls are routed correctly using the same configuration. That would eliminate the SPA9000 configuration.
3 I have recently had a problem with SPA941 which would not accept inbound calls without CallerID presented. This is recent phenomenon, and hasn't been resolved.
4 I don't understand both line LEDs going steady if only one line is connecting. Is there any interconnection between the two lines of your PSTN connections. Have you checked whether both lines operating alone behave the same way? Also have you tried using ports 3 and 4?
5 Check the total number of calls permitted for your SPA9000 line 1
Hope something might help here.
Pete
525
