Incoming calls from SIP Trunk fails to CME
Hi Folks,
I have a SIP Trunk, Cisco 877 and an old 2611XM for VoIP running CME 4.1.  The routers are set up like Fibre->877->2611XM.  I've finally got some things working on my setup, I can make internal, POTS and outgoing SIP calls.
I've got 10 numbers allocated to the SIP trunk and 8 lines.  Each external number should be a DDI for an internal extension, the last 4 digits of the external number is the internal extension..  Outgoing calls all come from a single number (I've got that working).
My problem is that I can't get incoming SIP calls working at all. 've been trying for the last 8 hours with no success.  At the moment, I'm not sure if its a NAT problem on my 877, or a dial-peer problem on the 2611.  I'd really like some help
I've got the following NAT on my 877:
ip nat service sip tcp port 5060
ip nat pool SIPPORTFWD 192.168.1.254 192.168.1.254 netmask 255.255.255.0 type rotary
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static udp 192.168.1.254 5060 interface Dialer1 5060
ip nat inside source static tcp 192.168.1.254 5060 interface Dialer1 5060
ip nat inside destination list 100 pool SIPPORTFWD
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.2.0 255.255.255.0 192.168.1.254
access-list 1 permit 192.168.0.0 0.0.255.255
access-list 100 permit udp any any range 4000 6000
These are the parts of the 2611XM config that I think are needed:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  registrar server
   outbound-proxy dns:voip.zen.co.uk
voice translation-rule 1
rule 1 /^9\(.*\)/ /\1/
voice translation-rule 2
rule 1 /.*/ /012xxxx8882/
voice translation-profile SIP
translate calling 2
translate called 1
dial-peer voice 200 voip
description SIP Outgoing Dial Peer
translation-profile outgoing SIP
destination-pattern 9T
voice-class sip outbound-proxy  dns:voip.zen.co.uk
session protocol sipv2
session target dns:voip.zen.co.uk
session transport udp
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 150 voip
description SIP Incoming Dial Peer
destination-pattern 0125370
incoming called-number 012xxx0....
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
authentication username 012xxxxx82 password 7 11101A56411B0D1F0F0939
registrar dns:voip.zen.co.uk expires 3600
sip-server dns:voip.zen.co.uk
  host-registrar
permit hostname dns:voip.zen.co.uk
permit hostname dns:asterisk01.voip.zen.co.uk
permit hostname dns:asterisk02.voip.zen.co.uk
ephone-dn  1  dual-line
number xx82 secondary 012xxxx82 no-reg both
label Main Desk
name 012xxxxx88
ephone-dn  2  dual-line
number xx83 secondary 012xxxxx83 no-reg both
label Spare Desk
name 012xxxxx88
I am able to dial out and audio works both ways, but incoming calls don't work.  I get the following using debug ccsip all
Oct 25 16:15:10.950: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 212.23.7.228:5060
Oct 25 16:15:10.954: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Oct 25 16:15:10.954: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
Oct 25 16:15:10.954: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:012xxxxxx82@212.23.7.228 SIP/2.0
Via: SIP/2.0/UDP 212.23.7.228:5060;branch=z9hG4bK610cd600-Proxy
Via: SIP/2.0/UDP 212.23.7.226:5060;branch=z9hG4bK610cd600;rport
Max-Forwards: 70
From: "+447xxxxx1188" <sip:+447xxxxx1188@212.23.7.226>;tag=as2e3b9b65
To: <sip:012xxxxx882@212.23.7.228>
Contact: <sip:+447xxxxx1188@212.23.7.228:5060>
Call-ID: 1278ad607dc403861d86bb831e4107d1@212.23.7.226:5060
CSeq: 102 INVITE
User-Agent: Zen Internet Telephony Service
Date: Fri, 25 Oct 2013 16:15:10 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces
Content-Type: application/sdp
Content-Length: 297
v=0
o=root 900441406 900441406 IN IP4 212.23.7.226
s=Asterisk PBX 1.8.13.1~dfsg-1~bpo60+1
c=IN IP4 212.23.7.226
t=0 0
m=audio 29672 RTP/AVP 0 8 3 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Oct 25 16:15:10.958: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Oct 25 16:15:10.962: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x864D8764) with key=[13172] to table
Oct 25 16:15:10.962: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 212.23.7.228,Port 5060, Transport 1, SentBy Port 5060
Oct 25 16:15:10.962: //-1/74F528F38465/SIP/State/sipSPIChangeState: 0x864D8764 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Oct 25 16:15:10.966: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 212.23.7.228,Port 5060, Transport 1, SentBy Port 5060
Oct 25 16:15:10.966: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone BST to SIP default timezone = GMT
Oct 25 16:15:10.970: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 212.23.7.228,Port 5060, Transport 1, SentBy Port 5060
Oct 25 16:15:10.974: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Oct 25 16:15:10.974: //-1/74F528F38465/SIP/Error/sact_idle_new_message_invite: Invalid URL in incoming INVITE
Oct 25 16:15:10.974: //-1/74F528F38465/SIP/Info/ccsip_set_cc_cause_for_spi_err: Categorized cause:100, category:100
Oct 25 16:15:10.978: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[-1], src[6]
Oct 25 16:15:10.978: //-1/74F528F38465/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
Oct 25 16:15:10.978: //-1/74F528F38465/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x864D8764 key=1278ad607dc403861d86bb831e4107d1@212.23.7.226:506001253708882
Oct 25 16:15:10.978: //-1/74F528F38465/SIP/Info/sipSPIUaddCcbToUASRespTable: ****Adding to UAS Response table.
Oct 25 16:15:10.978: //-1/74F528F38465/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x864D8764 key=1278ad607dc403861d86bb831e4107d1@212.23.7.226:50606C0F8E6F-F0B
Oct 25 16:15:10.987: //-1/74F528F38465/SIP/Transport/sipSPITransportSendMessage: msg=0x88B322CC, addr=212.23.7.228, port=5060, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x8137A1B8
Oct 25 16:15:10.987: //-1/74F528F38465/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Oct 25 16:15:10.987: //-1/74F528F38465/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Oct 25 16:15:10.987: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x88B322CC, addr=212.23.7.228, port=5060, connId=0 for UDP
Oct 25 16:15:10.987: //-1/74F528F38465/SIP/Info/sentErrResDisconnecting: Sent an 3456XX Error Response
Oct 25 16:15:10.991: //-1/74F528F38465/SIP/State/sipSPIChangeState: 0x864D8764 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
Oct 25 16:15:10.995: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request - 'Invalid Host'
Via: SIP/2.0/UDP 212.23.7.228:5060;branch=z9hG4bK610cd600-Proxy,SIP/2.0/UDP 212.23.7.226:5060;branch=z9hG4bK610cd600;rport
To: <sip:012xxxxx882@212.23.7.228>;tag=6C0F8E6F-F0B
CSeq: 102 INVITE
Allow-Events: telephone-event
Reason: Q.850;cause=100
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Oct 25 16:15:11.011: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 212.23.7.228:5060
Oct 25 16:15:11.011: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Oct 25 16:15:11.011: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
Oct 25 16:15:11.015: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:01253708882@212.23.7.228 SIP/2.0
Max-Forwards: 70
From: "+447xxxxxxx88" <sip:+447xxxxxxx88@212.23.7.226>;tag=as2e3b9b65
To: <sip:012xxxxxxx2@212.23.7.228>;tag=6C0F8E6F-F0B
X-ZEN-Transaction: OK
CSeq: 102 ACK
Content-Length: 0
Oct 25 16:15:11.015: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Oct 25 16:15:11.023: //-1/74F528F38465/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x864D8764
Oct 25 16:15:11.023: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 212.23.7.228,Port 5060, Transport 1, SentBy Port 5060
Oct 25 16:15:11.023: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone BST to SIP default timezone = GMT
Oct 25 16:15:11.027: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 212.23.7.228,Port 5060, Transport 1, SentBy Port 5060
Oct 25 16:15:11.027: //-1/74F528F38465/SIP/State/sipSPIChangeState: 0x864D8764 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
Oct 25 16:15:11.027: //-1/74F528F38465/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x864D8764
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           :
Called Number            : 012xxxxx882
Source IP Address (Sig  ): 192.168.1.254
Destn SIP Req Addr:Port  : 212.23.7.228:0
Destn SIP Resp Addr:Port : 212.23.7.228:5060
Destination Name         : 212.23.7.228
Oct 25 16:15:11.031: //-1/74F528F38465/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 100
Disconnect Cause (SIP)   : 400
Oct 25 16:15:11.031: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[13172] removed.
Oct 25 16:15:11.031: //-1/74F528F38465/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
Oct 25 16:15:11.031: //-1/74F528F38465/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x864D8764 key=1278ad607dc403861d86bb831e4107d1@212.23.7.226:506001253708882
Oct 25 16:15:11.035: //-1/74F528F38465/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
2611xm-1#
Oct 25 16:15:11.035: //-1/74F528F38465/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x864D8764 key=1278ad607dc403861d86bb831e4107d1@212.23.7.226:50606C0F8E6F-F0B
Oct 25 16:15:11.035: //-1/74F528F38465/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Oct 25 16:15:11.039: //-1/74F528F38465/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 864D8764
Oct 25 16:15:11.039: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[13172]
Please can someone help?!
Thanks!
Everyone's tags (4)
The error message 'SIP/2.0 400 Bad Request - 'Invalid Host' mostly indicates the NAT issue.
Perhaps the IP address 212.23.7.226 is not configured in any of the CME interfaces. Kindly check it.
//Suresh Please rate all the useful posts.
Re: Incoming calls from SIP Trunk fails to CME
Hi Andy.
As mentioned in many posts here in this forum, this is a tipical nat issue.
Remove static nat associaton to the Cube.
If you have multiple interface bind signaling and media to the interface leading to the internet by issuing bind all source-interface g0/0 under voice service voip -> sip.
Also under voice service voip you can add ip address trusted list
ipv4 x.x.x.x y.y.y.y (address an subnet mask)
Carlo
Please rate all helpful posts "The more you help the more you learn"
I've been playing with this, and still not managed to get it working! :-(
On my 2611XM I've added:
interface Loopback0
ip address 212.23.7.227 255.255.255.255 secondary
ip address 212.23.7.226 255.255.255.255 secondary
ip address 212.23.7.228 255.255.255.255
no ip route-cache
Then changed my voice service voip to:
voice service voip
sip
  bind control source-interface FastEthernet0/0.1
  bind media source-interface FastEthernet0/0.1
  registrar server
I also removed the static nat association so my NAT is now:
In this configuration, no calls work.  If I remove the loopback interface, outgoing calls work again.
If I add the the following to the 877:
ip nat inside source static udp 192.168.1.254 5060 82.70.85.118 5060 extendable
I can get an incoming call to ring a phone, but the call can't be established (plus, there's no security on this and I can occasionally see other people try and bounce calls through my CME).
I think what I need to do is put static NAT on so I can only accept calls from 212.23.7.226/7/8 never any other addresses and forward this to my CME box, then tell the CME to ignore the loopback interfaces and send calls out via fa0/0.1 - its difficult as I'm using CME 4.1 and some commands don't work.
I supose the only other option I have is using a bridge (again with an ACL for those IP addresses) and placing an interface on the CME directly on the Internet, but this is far beyond my skills at the moment!
I'm really stuck with this now, please can someone help?!
Thanks!
Anyone able to help with this one?
2436
