03-03-2007 08:12 PM - edited 03-14-2019 08:18 PM
I NEED FOR HELP GUYS!!!!PLEASE
I have the following scenario.
When I call from telefono DN:9510 attached to h323 ATA through the h323 IOS Gateway to CallManager at IP PHONE DN: 9002.
The IP PHONE rings but as soon as I pickup the PHONE, I get a fastbusy tone.
I ran some debug:
1. debug voip ccapi inout, and it showed the disconect cause code is 47.
2. show h323 gateway, it gave the same code disconect.
I was looking on Cisco web I couldn?t fine any informacion.
THANK VERY MUCH IN ADVANCE
REGARDS
WALTER
03-04-2007 06:28 AM
Please post your config for your H323 gateway. It appears that the call is using the same dial-peer for incoming AND outgoing call legs. You might want to try separating that part first by adding a separate dial peer for the outgoing call leg.
03-06-2007 06:56 AM
