Community Member
Incoming calls go to the wrong direction.
Background:
Cisco unity connection 9.1
Scope:
I have an external number from telco (let say 6041111111).
Also I have a forwarding service on telco site which  forwards all calls into the Cisco Unity Connection number (let say 6042222222).
However, instead of doing that, all calls go to another number on CUCM (let say 6043333333).
What debug command could help to trace incoming call ?
Thank you,
Sergey
How to trace incoming call.
Install the RTMT tool and use the Unity Connection>Port Monitor. You can also install the "Remote Port Status Monitor" from the link below:
http://ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/PortStatusMonitorCUC7x.html
Yosh
HTH Regards, Yosh
Community Member
HI,
I performed some debugging on the voice gateway and have found 1 interesting line:
             Redirecting Number i = '!', 0x008F, 6041111111
What it can be ????
Sergey
Re: How to trace incoming call.
If you don't elaborate on why the need to do this, or the problem you're facing, you cannot expect answers.
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
Here is the scope:
So, the issue is that  incoming calls going to the wrong direction.
Also below is the log from the voice gateway:
Feb 28 07:12:52.572: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x11E6
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98386
                Exclusive, Channel 6
        Facility i = 0x9F8B0100A117020114020100800F535552474559204C5542454E4B4F56
                Protocol Profile =  Networking Extensions
                0xA117020114020100800F535552474559204C5542454E4B4F56
                Component = Invoke component
                        Invoke Id = 20
                        Operation = CallingName
                                Name Presentation Allowed Extended
                                Name = SERGEY
        Calling Party Number i = 0x2183, '604XXXXX18'
                Plan:
bgd-bur-r2921-01#ISDN, Type:National
        Called Party Number i = 0x80, '2222'
                Plan:Unknown, Type:Unknown
        Redirecting Number i = '!', 0x008F, '6041111111'
                Plan:ISDN, Type:National
Feb 28 07:12:52.588: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x91E6
Feb 28 07:12:52.588: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x91E6
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Feb 28 07:12:52.848: ISDN Se0/0/0:23 Q931: TX -> CONNECT pd = 8  callref = 0x91E6
        Display i = 'VoiceMail'
Feb 28 07:12:52.912: ISDN Se0/0/0:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x11E6
bgd-bur-r2921-01#
Feb 28 07:12:52.916: ISDN Se0/0/0:23 Q931: RX <- STATUS pd = 8  callref = 0x11E6
        Cause i = 0x80E328 - Information element not implemented
        Call State i = 0x0A
bgd-bur-r2921-01#
Feb 28 07:12:57.812: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x11E6
        Cause i = 0x8090 - Normal call clearing
Feb 28 07:12:57.844: ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x91E6
Feb 28 07:12:57.864: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x11E6
So, the issue is that  incoming calls going to the wrong direction. -- Send across debug voice ccapi inout and  dial-peer config from your router.
Manish
Community Member
OK, the solution was as usual
OK, the solution was as usual pretty simple:
Because calls came from  "Redirecting Number" (as you can see in  log), the cisco unity used the "Forwarded Routing Rule" instead of "Direct Rule" as in all other cases.
So, I just added one more "Forwarded Routing Rule" to redirect calls to the correct number and it solved the problem.
Sergey
198
