Community Member
Incoming Calls Have No Ringback, Goes to Fast Busy Tone
Recently, our provider had an outage. Coming back from the outage, our incoming calls are not working. Caller dials in and gets no ring back and then gets a fast busy tone. Carrier says everything is okay on their end. Any clues to why calls aren't working normally?
These are the logs I collected:
vg-3845#debug voip vtsp all
voip vtsp all debugging is on
vg-3845#u all
Jan 24 19:02:36 MST: //-1/xxxxxxxxxxxx/VTSP:(0/1/0:1):-1:-1:-1/vtsp_allocate_cdb:
   CDB=0x6B0F98C0
Jan 24 19:02:36 MST: //-1/xxxxxxxxxxxx/VTSP:(0/1/0:1):-1:-1:-1/vtsp_do_call_setup_ind:
   Event=E_TSP_SETUP_IND
   Progress Indication=3, CarrierIDCode=, Info Trans Capability=144, Source Carrier ID=, tg_label_flag=0
Jan 24 19:02:36 MST: //-1/983D3CBA8726/VTSP:(0/1/0:1):-1:-1:-1/vtsp_do_normal_call_setup_ind:
Jan 24 19:02:36 MST: //-1/983D3CBA8726/VTSP:(0/1/0:1):-1:-1:-1/vtsp_timer:
   Timer Start Time=2788497, Timer Value=180000(ms)
   XCC State Machine (XCCSM) Added
Jan 24 19:02:36 MST: //-1/983D3CBA8726/VTSP:(0/1/0:1):-1:-1:-1/vtsp_insert_cdb:
Jan 24 19:02:36 MST: //-1/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/vtsp_dsm_opened_cb:
Jan 24 19:02:36 MST: //-1/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/vtsp_process_event:
   [state:S_SETUP_IND_PEND, event:E_VTSP_DSM_OPEN_SUCCESS]
Jan 24 19:02:36 MST: //-1/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/act_setup_ind_pend_success:
Jan 24 19:02:36 MST: //-1/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/vtsp_realloc_cdb:
   CDB=0x6B0F98C0
Jan 24 19:02:36 MST: //-1/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/vtsp_indicate_call:
Jan 24 19:02:36 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/vtsp_insert_cdb:
vg-3845#u all
Jan 24 19:02:36 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/vtsp_timer:
vg-3845#u all
Jan 24 19:02:39 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/vtsp_process_event:
   [state:S_SETUP_INDICATED, event:E_TSP_DISCONNECT_IND]
Jan 24 19:02:39 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/act_generate_disc:
   Cause Value=31
Jan 24 19:02:39 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=2788797
Jan 24 19:02:39 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/vtsp_ring_noan_timer_stop:
Jan 24 19:02:39 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/vtsp_set_release_source:
   Release Direction=PSTN, Release Source=Calling Party-PSTN
vg-3845#u all
Jan 24 19:02:39 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/vtsp_cc_call_disconnected:
   Cause Value=31
Jan 24 19:02:39 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/vtsp_timer:
   Timer Start Time=2788797, Timer Value=15000(ms)
   Return Code=0
vg-3845#u all
Jan 24 19:02:41 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/vtsp_process_event:
   [state:S_WAIT_HOST_DISC, event:E_TSP_CALL_FEATURE_IND]
   Unexpected EVENT [E_TSP_CALL_FEATURE_IND] Received For STATE [S_WAIT_HOST_DISC];
   Previous STATE [0.3 ]
   [state:S_WAIT_HOST_DISC, event:E_TSP_DISCONNECT_CONF]
Jan 24 19:02:41 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/act_wrelease_release:
Jan 24 19:02:41 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/vtsp_play_busy_timer_stop:
   Timer Stop Time=2789008
Jan 24 19:02:41 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/vtsp_timer_stop:
Jan 24 19:02:41 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:1:1/vtsp_do_call_history:
   Coder Rate=-1
Jan 24 19:02:41 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:-1:-1/vtsp_dsm_closed_cb:
Jan 24 19:02:41 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:-1:-1/vtsp_process_event:
   [state:S_CLOSE_DSPRM, event:E_VTSP_DSM_CLOSE_COMPLETE]
Jan 24 19:02:41 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:-1:-1/act_terminate:
Jan 24 19:02:41 MST: //458/983D3CBA8726/VTSP:(0/1/0:1):-1:-1:-1/vtsp_timer_stop:
Jan 24 19:02:41 MST: //-1/983D3CBA8726/VTSP:(0/1/0:1):-1:-1:-1/vtsp_free_cdb:
   CDB=0x6B0F98C0
Jan 24 19:02:41 MST: //-1/xxxxxxxxxxxx/VTSP:(0/1/0:1):-1:-1:-1/vtsp_allocate_cdb:
   CDB=0x6B0F9600
Jan 24 19:02:41 MST: //-1/xxxxxxxxxxxx/VTSP:(0/1/0:1):-1:-1:-1/vtsp_do_call_setup_ind:
Jan 24 19:02:41 MST: //-1/9B54DDED872A/VTSP:(0/1/0:1):-1:-1:-1/vtsp_do_normal_call_setup_ind:
Jan 24 19:02:41 MST: //-1/9B54DDED872A/VTSP:(0/1/0:1):-1:-1:-1/vtsp_timer:
   Timer Start Time=2789016, Timer Value=180000(ms)
Jan 24 19:02:41 MST: //-1/9B54DDED872A/VTSP:(0/1/0:1):-1:-1:-1/vtsp_insert_cdb:
Jan 24 19:02:41 MST: //-1/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/vtsp_dsm_opened_cb:
Jan 24 19:02:41 MST: //-1/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/vtsp_process_event:
Jan 24 19:02:41 MST: //-1/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/act_setup_ind_pend_success:
vg-3845#u all
Jan 24 19:02:41 MST: //-1/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/vtsp_realloc_cdb:
   CDB=0x6B0F9600
Jan 24 19:02:41 MST: //-1/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/vtsp_indicate_call:
Jan 24 19:02:41 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/vtsp_insert_cdb:
Jan 24 19:02:41 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/vtsp_timer:
vg-3845#u all
Jan 24 19:02:44 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/vtsp_process_event:
Jan 24 19:02:44 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/act_generate_disc:
   Cause Value=31
Jan 24 19:02:44 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=2789316
Jan 24 19:02:44 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/vtsp_ring_noan_timer_stop:
Jan 24 19:02:44 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/vtsp_set_release_source:
vg-3845#u all
Jan 24 19:02:44 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/vtsp_cc_call_disconnected:
   Cause Value=31
Jan 24 19:02:44 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/vtsp_timer:
   Timer Start Time=2789316, Timer Value=15000(ms)
   Return Code=0
vg-3845#u all
Jan 24 19:02:46 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/vtsp_process_event:
Jan 24 19:02:46 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/act_wrelease_release:
Jan 24 19:02:46 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/vtsp_play_busy_timer_stop:
   Timer Stop Time=2789525
Jan 24 19:02:46 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/vtsp_timer_stop:
Jan 24 19:02:46 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:1:1/vtsp_do_call_history:
   Coder Rate=-1
Jan 24 19:02:46 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:-1:-1/vtsp_dsm_closed_cb:
Jan 24 19:02:46 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:-1:-1/vtsp_process_event:
Jan 24 19:02:46 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:-1:-1/act_terminate:
vg-3845#u all
Jan 24 19:02:46 MST: //459/9B54DDED872A/VTSP:(0/1/0:1):-1:-1:-1/vtsp_timer_stop:
Jan 24 19:02:46 MST: //-1/9B54DDED872A/VTSP:(0/1/0:1):-1:-1:-1/vtsp_free_cdb:
   CDB=0x6B0F9600
vg-3845#debug voip ccapi inout
voip ccapi inout debugging is on
vg-3845#ual
Jan 24 19:22:00 MST: htsp_process_event: [0/1/0:1(24), EM_ONHOOK, E_DSP_SIG_1100]em_onhook_offhook
Jan 24 19:22:00 MST: htsp_timer - 50 msec
Jan 24 19:22:00 MST: htsp_process_event: [0/1/0:1(24), EM_QUALIFY_SEIZURE, E_HTSP_EVENT_TIMER]em_qualify_seizure_timeouthtsp_setup_ind
Jan 24 19:22:00 MST: [0/1/0:1(24)] get_local_station_id calling num= calling name= calling time=01/24 19:22  orig called=
Jan 24 19:22:00 MST: htsp_timer - 3000 msec
Jan 24 19:22:00 MST: //-1/4E84F6B58782/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jan 24 19:22:00 MST: //-1/4E84F6B58782/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x66F27200, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=999010991, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Jan 24 19:22:00 MST: //-1/4E84F6B58782/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Jan 24 19:22:00 MST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 24 19:22:00 MST: :cc_get_feature_vsa malloc success
Jan 24 19:22:00 MST:  cc_get_feature_vsa count is 1
Jan 24 19:22:00 MST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1722625968,feature_id:481
Jan 24 19:22:00 MST: //481/4E84F6B58782/CCAPI/cc_api_call_setup_ind_common:
vg-3845#Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Jan 24 19:22:00 MST: //481/4E84F6B58782/CCAPI/cc_process_call_setup_ind:
   Event=0x6B504AE0
   >>>>CCAPI handed cid 481 with tag 999010991 to app "MGCPAPP"
vg-3845#
Jan 24 19:22:03 MST: htsp_process_event: [0/1/0:1(24), EM_WAIT_SETUP_ACK, E_HTSP_EVENT_TIMER]em_wait_setup_ack_timer
Jan 24 19:22:03 MST: em_start_timer: 400 ms
Jan 24 19:22:03 MST: htsp_timer - 400 msec
Jan 24 19:22:03 MST: htsp_timer_stop2 em_onhook (0)vnm_dsp_set_sig_state:[recEive and transMit0/1/0:1(24)] set signal state = 0x0
Jan 24 19:22:03 MST: //481/4E84F6B58782/CCAPI/cc_api_call_disconnected:
   Cause Value=31, Interface=0x66F27200, Call Id=481
   Call Entry(Responsed=FALSE, Cause Value=31, Retry Count=0)
vg-3845#
Jan 24 19:22:04 MST: htsp_process_event: [0/1/0:1(24), EM_GUARD_ALL, E_HTSP_EVENT_TIMER]em_guard_all_timer
Jan 24 19:22:04 MST: em_stop_timers
Jan 24 19:22:04 MST: htsp_timer_stop
Jan 24 19:22:04 MST: em_start_timer: 3000 ms
Jan 24 19:22:04 MST: htsp_timer - 3000 msec
Jan 24 19:22:04 MST: htsp_process_event: [0/1/0:1(24), EM_PARK, E_DSP_SIG_1100]em_park_offhook
Jan 24 19:22:04 MST: htsp_timer_stop2
Jan 24 19:22:04 MST: htsp_timer2 - 10000 msec
Jan 24 19:22:05 MST: htsp_process_event: [0/1/0:1(23), EM_ONHOOK, E_DSP_SIG_1100]em_onhook_offhook
Jan 24 19:22:05 MST: htsp_timer - 50 msec
Jan 24 19:22:05 MST: htsp_process_event: [0/1/0:1(24), EM_PARK, E_DSP_SIG_0000]em_park_onhook
Jan 24 19:22:05 MST: htsp_timer_stop
Jan 24 19:22:05 MST: htsp_timer_stop2 htsp_report_onhook_sig
Jan 24 19:22:05 MST: //481/4E84F6B58782/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x66F27200, Tag=0x0, Call Id=481,
   Call Entry(Disconnect Cause=31, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jan 24 19:22:05 MST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 24 19:22:05 MST: :cc_free_feature_vsa freeing 66AD2FA8
Jan 24 19:22:05 MST:  vsacount in free is 0
Jan 24 19:22:06 MST: htsp_process_event: [0/1/0:1(23), EM_QUALIFY_SEIZURE, E_HTSP_EVENT_TIMER]em_qualify_seizure_timeouthtsp_setup_ind
Jan 24 19:22:06 MST: [0/1/0:1(23)] get_local_station_id calling num= calling name= calling time=01/24 19:22  orig called=
Jan 24 19:22:06 MST: htsp_timer - 3000 msec
Jan 24 19:22:06 MST: //-1/519B619D8786/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jan 24 19:22:06 MST: //-1/519B619D8786/CCAPI/cc_api_call_setup_ind_common:
Jan 24 19:22:06 MST: //-1/519B619D8786/CCAPI/ccCheckClipClir:
Jan 24 19:22:06 MST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 24 19:22:06 MST: :cc_get_feature_vsa malloc success
Jan 24 19:22:06 MST:  cc_get_feature_vsa count is 1
Jan 24 19:22:06 MST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1722625968,feature_id:482
Jan 24 19:22:06 MST: //482/519B619D8786/CCAPI/cc_api_call_setup_ind_common:
Jan 24 19:22:06 MST: //482/519B619D8786/CCAPI/cc_process_call_setup_ind:
   Event=0x6B502EF0
   >>>>CCAPI handed cid 482 with tag 999010991 to app "MGCPAPP"
vg-3845#
Jan 24 19:22:09 MST: htsp_process_event: [0/1/0:1(23), EM_WAIT_SETUP_ACK, E_HTSP_EVENT_TIMER]em_wait_setup_ack_timer
Jan 24 19:22:09 MST: em_start_timer: 400 ms
Jan 24 19:22:09 MST: htsp_timer - 400 msec
Jan 24 19:22:09 MST: htsp_timer_stop2 em_onhook (0)vnm_dsp_set_sig_state:[recEive and transMit0/1/0:1(23)] set signal state = 0x0
Jan 24 19:22:09 MST: //482/519B619D8786/CCAPI/cc_api_call_disconnected:
   Cause Value=31, Interface=0x66F27200, Call Id=482
vg-3845#
Jan 24 19:22:09 MST: htsp_process_event: [0/1/0:1(23), EM_GUARD_ALL, E_HTSP_EVENT_TIMER]em_guard_all_timer
Jan 24 19:22:09 MST: em_stop_timers
Jan 24 19:22:09 MST: em_start_timer: 3000 ms
Jan 24 19:22:09 MST: htsp_timer - 3000 msec
Jan 24 19:22:09 MST: htsp_process_event: [0/1/0:1(23), EM_PARK, E_DSP_SIG_1100]em_park_offhook
Jan 24 19:22:09 MST: htsp_timer2 - 10000 msec
vg-3845#
Jan 24 19:22:11 MST: htsp_process_event: [0/1/0:1(23), EM_PARK, E_DSP_SIG_0000]em_park_onhook
Jan 24 19:22:11 MST: htsp_timer_stop
Jan 24 19:22:11 MST: htsp_timer_stop2 htsp_report_onhook_sig
Jan 24 19:22:11 MST: //482/519B619D8786/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x66F27200, Tag=0x0, Call Id=482,
Jan 24 19:22:11 MST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 24 19:22:11 MST: :cc_free_feature_vsa freeing 66AD2FA8
vg-3845#
Jan 24 19:22:11 MST:  vsacount in free is 0
Jan 24 19:22:12 MST: htsp_process_event: [0/1/0:1(24), EM_ONHOOK, E_DSP_SIG_1100]em_onhook_offhook
Jan 24 19:22:12 MST: htsp_timer - 50 msec
Jan 24 19:22:12 MST: htsp_process_event: [0/1/0:1(24), EM_QUALIFY_SEIZURE, E_HTSP_EVENT_TIMER]em_qualify_seizure_timeouthtsp_setup_ind
Jan 24 19:22:12 MST: [0/1/0:1(24)] get_local_station_id calling num= calling name= calling time=01/24 19:22  orig called=
Jan 24 19:22:12 MST: htsp_timer - 3000 msec
Jan 24 19:22:12 MST: //-1/5573456C878A/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jan 24 19:22:12 MST: //-1/5573456C878A/CCAPI/cc_api_call_setup_ind_common:
Jan 24 19:22:12 MST: //-1/5573456C878A/CCAPI/ccCheckClipClir:
Jan 24 19:22:12 MST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 24 19:22:12 MST: :cc_get_feature_vsa malloc success
Jan 24 19:22:12 MST:  cc_get_feature_vsa count is 1
Jan 24 19:22:12 MST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1722625968,feature_id:483
Jan 24 19:22:12 MST: //483/5573456C878A/CCAPI/cc_api_call_setup_ind_common:
Jan 24 19:22:12 MST: //483/5573456C878A/CCAPI/cc_process_call_setup_ind:
   Event=0x6B501300
   >>>>CCAPI handed cid 483 with tag 999010991 to app "MGCPAPP"
vg-3845#
Jan 24 19:22:15 MST: htsp_process_event: [0/1/0:1(24), EM_WAIT_SETUP_ACK, E_HTSP_EVENT_TIMER]em_wait_setup_ack_timer
Jan 24 19:22:15 MST: em_start_timer: 400 ms
Jan 24 19:22:15 MST: htsp_timer - 400 msec
Jan 24 19:22:15 MST: htsp_timer_stop2 em_onhook (0)vnm_dsp_set_sig_state:[recEive and transMit0/1/0:1(24)] set signal state = 0x0
Jan 24 19:22:15 MST: //483/5573456C878A/CCAPI/cc_api_call_disconnected:
   Cause Value=31, Interface=0x66F27200, Call Id=483
vg-3845#
Jan 24 19:22:15 MST: htsp_process_event: [0/1/0:1(24), EM_GUARD_ALL, E_HTSP_EVENT_TIMER]em_guard_all_timer
Jan 24 19:22:15 MST: em_stop_timers
Jan 24 19:22:15 MST: em_start_timer: 3000 ms
Jan 24 19:22:15 MST: htsp_timer - 3000 msec
Jan 24 19:22:15 MST: htsp_process_event: [0/1/0:1(24), EM_PARK, E_DSP_SIG_1100]em_park_offhook
Jan 24 19:22:15 MST: htsp_timer2 - 10000 msec
vg-3845#
Jan 24 19:22:17 MST: htsp_process_event: [0/1/0:1(24), EM_PARK, E_DSP_SIG_0000]em_park_onhook
Jan 24 19:22:17 MST: htsp_timer_stop
Jan 24 19:22:17 MST: htsp_timer_stop2 htsp_report_onhook_sig
Jan 24 19:22:17 MST: //483/5573456C878A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x66F27200, Tag=0x0, Call Id=483,
Jan 24 19:22:17 MST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 24 19:22:17 MST: :cc_free_feature_vsa freeing 66AD2FA8
Jan 24 19:22:17 MST:  vsacount in free is 0
Jan 24 19:22:17 MST: htsp_process_event: [0/1/0:1(23), EM_ONHOOK, E_DSP_SIG_1100]em_onhook_offhook
Jan 24 19:22:17 MST: htsp_timer - 50 msec
Jan 24 19:22:17 MST: htsp_process_event: [0/1/0:1(23), EM_QUALIFY_SEIZURE, E_HTSP_EVENT_TIMER]em_qualify_seizure_timeouthtsp_setup_ind
Jan 24 19:22:17 MST: [0/1/0:1(23)] get_local_station_id calling num= calling name= calling time=01/24 19:22  orig called=
Jan 24 19:22:17 MST: htsp_timer - 3000 msec
Jan 24 19:22:17 MST: //-1/588C1F88878E/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jan 24 19:22:17 MST: //-1/588C1F88878E/CCAPI/cc_api_call_setup_ind_common:
Jan 24 19:22:17 MST: //-1/588C1F88878E/CCAPI/ccCheckClipClir:
Jan 24 19:22:17 MST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 24 19:22:17 MST: :cc_get_feature_vsa malloc success
Jan 24 19:22:17 MST:  cc_get_feature_vsa count is 1
Jan 24 19:22:17 MST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1722625968,feature_id:484
Jan 24 19:22:17 MST: //484/588C1F88878E/CCAPI/cc_api_call_setup_ind_common:
Jan 24 19:22:17 MST: //484/588C1F88878E/CCAPI/cc_process_call_setup_ind:
   Event=0x6B4FF710
   >>>>CCAPI handed cid 484 with tag 999010991 to app "MGCPAPP"
vg-3845#
Jan 24 19:22:20 MST: htsp_process_event: [0/1/0:1(23), EM_WAIT_SETUP_ACK, E_HTSP_EVENT_TIMER]em_wait_setup_ack_timer
Jan 24 19:22:20 MST: em_start_timer: 400 ms
Jan 24 19:22:20 MST: htsp_timer - 400 msec
Jan 24 19:22:20 MST: htsp_timer_stop2 em_onhook (0)vnm_dsp_set_sig_state:[recEive and transMit0/1/0:1(23)] set signal state = 0x0
Jan 24 19:22:20 MST: //484/588C1F88878E/CCAPI/cc_api_call_disconnected:
   Cause Value=31, Interface=0x66F27200, Call Id=484
vg-3845#
Jan 24 19:22:21 MST: htsp_process_event: [0/1/0:1(23), EM_GUARD_ALL, E_HTSP_EVENT_TIMER]em_guard_all_timer
Jan 24 19:22:21 MST: em_stop_timers
Jan 24 19:22:21 MST: htsp_timer_stop
Jan 24 19:22:21 MST: em_start_timer: 3000 ms
Jan 24 19:22:21 MST: htsp_timer - 3000 msec
Jan 24 19:22:21 MST: htsp_process_event: [0/1/0:1(23), EM_PARK, E_DSP_SIG_1100]em_park_offhook
Jan 24 19:22:21 MST: htsp_timer_stop2
Jan 24 19:22:21 MST: htsp_timer2 - 10000 msec
Jan 24 19:22:22 MST: htsp_process_event: [0/1/0:1(23), EM_PARK, E_DSP_SIG_0000]em_park_onhook
Jan 24 19:22:22 MST: htsp_timer_stop
Jan 24 19:22:22 MST: htsp_timer_stop2 htsp_report_onhook_sig
Jan 24 19:22:22 MST: //484/588C1F88878E/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x66F27200, Tag=0x0, Call Id=484,
Jan 24 19:22:22 MST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 24 19:22:22 MST: :cc_free_feature_vsa freeing 66AD2FA8
vg-3845#
Jan 24 19:22:22 MST:  vsacount in free is 0
vg-3845#
Jan 24 19:22:24 MST: htsp_process_event: [0/1/0:1(24), EM_ONHOOK, E_DSP_SIG_1100]em_onhook_offhook
Jan 24 19:22:24 MST: htsp_timer - 50 msec
Jan 24 19:22:24 MST: htsp_process_event: [0/1/0:1(24), EM_QUALIFY_SEIZURE, E_HTSP_EVENT_TIMER]em_qualify_seizure_timeouthtsp_setup_ind
Jan 24 19:22:24 MST: [0/1/0:1(24)] get_local_station_id calling num= calling name= calling time=01/24 19:22  orig called=
Jan 24 19:22:24 MST: htsp_timer - 3000 msec
Jan 24 19:22:24 MST: //-1/5C7172948792/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jan 24 19:22:24 MST: //-1/5C7172948792/CCAPI/cc_api_call_setup_ind_common:
Jan 24 19:22:24 MST: //-1/5C7172948792/CCAPI/ccCheckClipClir:
Jan 24 19:22:24 MST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 24 19:22:24 MST: :cc_get_feature_vsa malloc success
Jan 24 19:22:24 MST:  cc_get_feature_vsa count is 1
Jan 24 19:22:24 MST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1722625968,feature_id:485
Jan 24 19:22:24 MST: //485/5C7172948792/CCAPI/cc_api_call_setup_ind_common:
Jan 24 19:22:24 MST: //485/5C7172948792/CCAPI/cc_process_call_setup_ind:
   Event=0x6B4FDB20
   >>>>CCAPI handed cid 485 with tag 999010991 to app "MGCPAPP"
vg-3845#
Jan 24 19:22:27 MST: htsp_process_event: [0/1/0:1(24), EM_WAIT_SETUP_ACK, E_HTSP_EVENT_TIMER]em_wait_setup_ack_timer
Jan 24 19:22:27 MST: em_start_timer: 400 ms
Jan 24 19:22:27 MST: htsp_timer - 400 msec
Jan 24 19:22:27 MST: htsp_timer_stop2 em_onhook (0)vnm_dsp_set_sig_state:[recEive and transMit0/1/0:1(24)] set signal state = 0x0
Jan 24 19:22:27 MST: //485/5C7172948792/CCAPI/cc_api_call_disconnected:
   Cause Value=31, Interface=0x66F27200, Call Id=485
vg-3845#
Jan 24 19:22:27 MST: htsp_process_event: [0/1/0:1(24), EM_GUARD_ALL, E_HTSP_EVENT_TIMER]em_guard_all_timer
Jan 24 19:22:27 MST: em_stop_timers
Jan 24 19:22:27 MST: em_start_timer: 3000 ms
Jan 24 19:22:27 MST: htsp_timer - 3000 msec
Jan 24 19:22:27 MST: htsp_process_event: [0/1/0:1(24), EM_PARK, E_DSP_SIG_1100]em_park_offhook
Jan 24 19:22:27 MST: htsp_timer2 - 10000 msec
vg-3845#
Jan 24 19:22:29 MST: htsp_process_event: [0/1/0:1(23), EM_ONHOOK, E_DSP_SIG_1100]em_onhook_offhook
Jan 24 19:22:29 MST: htsp_timer - 50 msec
Jan 24 19:22:29 MST: htsp_process_event: [0/1/0:1(24), EM_PARK, E_DSP_SIG_0000]em_park_onhook
Jan 24 19:22:29 MST: htsp_timer_stop
Jan 24 19:22:29 MST: htsp_timer_stop2 htsp_report_onhook_sig
Jan 24 19:22:29 MST: //485/5C7172948792/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x66F27200, Tag=0x0, Call Id=485,
Jan 24 19:22:29 MST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 24 19:22:29 MST: :cc_free_feature_vsa freeing 66AD2FA8
Jan 24 19:22:29 MST:  vsacount in free is 0
Jan 24 19:22:29 MST: htsp_process_event: [0/1/0:1(23), EM_QUALIFY_SEIZURE, E_HTSP_EVENT_TIMER]em_qualify_seizure_timeouthtsp_setup_ind
Jan 24 19:22:29 MST: [0/1/0:1(23)] get_local_station_id calling num= calling name= calling time=01/24 19:22  orig called=
Jan 24 19:22:29 MST: htsp_timer - 3000 msec
Jan 24 19:22:29 MST: //-1/5F87DB788796/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jan 24 19:22:29 MST: //-1/5F87DB788796/CCAPI/cc_api_call_setup_ind_common:
Jan 24 19:22:29 MST: //-1/5F87DB788796/CCAPI/ccCheckClipClir:
Jan 24 19:22:29 MST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 24 19:22:29 MST: :cc_get_feature_vsa malloc success
Jan 24 19:22:29 MST:  cc_get_feature_vsa count is 1
Jan 24 19:22:29 MST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1722625968,feature_id:486
Jan 24 19:22:29 MST: //486/5F87DB788796/CCAPI/cc_api_call_setup_ind_common:
Jan 24 19:22:29 MST: //486/5F87DB788796/CCAPI/cc_process_call_setup_ind:
   Event=0x6B4FBF30
   >>>>CCAPI handed cid 486 with tag 999010991 to app "MGCPAPP"
vg-3845#
Jan 24 19:22:32 MST: htsp_process_event: [0/1/0:1(23), EM_WAIT_SETUP_ACK, E_HTSP_EVENT_TIMER]em_wait_setup_ack_timer
Jan 24 19:22:32 MST: em_start_timer: 400 ms
Jan 24 19:22:32 MST: htsp_timer - 400 msec
Jan 24 19:22:32 MST: htsp_timer_stop2 em_onhook (0)vnm_dsp_set_sig_state:[recEive and transMit0/1/0:1(23)] set signal state = 0x0
Jan 24 19:22:32 MST: //486/5F87DB788796/CCAPI/cc_api_call_disconnected:
   Cause Value=31, Interface=0x66F27200, Call Id=486
vg-3845#
Jan 24 19:22:32 MST: htsp_process_event: [0/1/0:1(23), EM_GUARD_ALL, E_HTSP_EVENT_TIMER]em_guard_all_timer
Jan 24 19:22:32 MST: em_stop_timers
Jan 24 19:22:32 MST: em_start_timer: 3000 ms
Jan 24 19:22:32 MST: htsp_timer - 3000 msec
Jan 24 19:22:32 MST: htsp_process_event: [0/1/0:1(23), EM_PARK, E_DSP_SIG_1100]em_park_offhook
Jan 24 19:22:32 MST: htsp_timer2 - 10000 msec
vg-3845#
Jan 24 19:22:34 MST: htsp_process_event: [0/1/0:1(23), EM_PARK, E_DSP_SIG_0000]em_park_onhook
Jan 24 19:22:34 MST: htsp_timer_stop
Jan 24 19:22:34 MST: htsp_timer_stop2 htsp_report_onhook_sig
Jan 24 19:22:34 MST: //486/5F87DB788796/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x66F27200, Tag=0x0, Call Id=486,
Jan 24 19:22:34 MST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 24 19:22:34 MST: :cc_free_feature_vsa freeing 66AD2FA8
vg-3845#
Jan 24 19:22:34 MST:  vsacount in free is 0
Everyone's tags (1)
It seems the provider is releasing the call with cause code 31,
   Cause Value=31      >> this is reported as a normal event only when no other cause in the normal class applies
So please check with your provider once again and tell them we are receiving the disconnect from pstn.
     >> Are the outbound calls working ok?
Please rate all the useful posts
//Suresh Please rate all the useful posts.
Community Member
I ended up figuring it out. There was a number expansion command redirecting the caller to an extension that wasn't available due to a bug in the system.
I had to run "no mgcp" and then "mgcp" because the voice gateway lost connectivity to Call Manager.
854
