Incoming calls issue in Third Party SIP Phone
Yesterday I configured my third party sip phone which is yealink in this case on cucm and successfully registered it with cucm, despite of registration i have some calling issue in this phone. I am able to make outbound calls from this phone to any other phone however issue is related to inbound calls.I tried calling its DN from anywhere but call disconnect after sometime. Also didnt get any proper sip session trace in RTMT. Kindly suggest some step to sortout this issue.
Everyone's tags (5)
Does the call actually get set up with audio both ways? How much time does it take before the call is disconnected? Can you capture detailed callmanager traces for a test call
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
Manish
Dear Manish,
Call normally dicsonnected after 30-40 sec with termination code 102 in session trace. PFB SDI  trace with 5030 is Thirdparty sip phone and 5033 is c7945. Looking forward for your suggestion.
CallingPartyNumber=5033
|DialingPartition=
|DialingPattern=5030
|FullyQualifiedCalledPartyNumber=5030
|DialingPatternRegularExpression=(5030)
|DialingWhere=
|PatternType=Enterprise
|PotentialMatches=NoPotentialMatchesExist
|DialingSdlProcessId=(0,0,0)
|PretransformDigitString=5030
|PretransformTagsList=SUBSCRIBER
|PretransformPositionalMatchList=5030
|CollectedDigits=5030
|UnconsumedDigits=
|TagsList=SUBSCRIBER
|VoiceMailbox=
|VoiceMailCallingSearchSpace=PT-LHR-LOCAL:PT-Local:Unityvmpt:PT-F6-Local:PT-ISL-LOCAL:PT-KHI-LOCAL:PT_Operator_LHR:PT_Operator_KHI:PT_Operator_ISL
|VoiceMailPilotNumber=7103
|RouteBlockFlag=RouteThisPattern
|RouteBlockCause=0
|AlertingName=Syed Ahmer
|UnicodeDisplayName=Syed Ahmer
|DisplayNameLocale=1
|OverlapSendingFlagEnabled=0
12:17:38.028 |//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 172.16.200.21:[5062]:
[23928282,NET]
INVITE sip:5030@172.16.200.21:5062 SIP/2.0
Via: SIP/2.0/UDP 10.100.200.11:5060;branch=z9hG4bK1ca0cc6e317649
From: "Syed Ahmer" <5033>;tag=8787406~039e2a80-8561-4586-8954-d01ed2aa12c8-246211918
To: <5030>
Date: Thu, 30 Jan 2014 07:17:38 GMT
Call-ID: 84e24a80-2e91fc72-1a6940-bc8640a@10.100.200.11
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence
Send-Info: conference, x-cisco-conference
Alert-Info: <>
Contact: <5033>
Remote-Party-ID: "Syed Ahmer" <5033>;party=calling;screen=yes;privacy=off
Max-Forwards: 70
Content-Length: 0
|14,100,50,1.14103336^10.163.14.4^SEP00230432C828
12:17:38.028 |EnvProcessUdpPort - EnvProcessUdpHandler::fireSignal() varId = 0|14,100,50,1.14103336^10.163.14.4^SEP00230432C828
12:17:38.028 |EnvProcessUdpHandler::fireSignal - SEND: index = 0, handler = 0xaf299320|*^*^*
12:17:38.028 |EnvProcessUdpPort::fireSignal - SEND, destination = 172.16.200.21:5062|*^*^*
12:17:38.028 |EnvProcessUdpPort - EnvProcessUdpHandler::send(buff, 850, 172.16.200.21:5062)|*^*^*
Hi Syed,
This only shows the Invite message without SDP, are there no other messages if you filter through
Manish
Dear Manish,
I didnt find any other sip messages except register and invite  in SDI trace.
Re: Incoming calls issue in Third Party SIP Phone
I am  facing the similar issue on Avaya phone registered on cisco  call manager 9.X.
both phone avaya and cisco  registered to same call manager and DN are in same partiton .
issue Avaya can call  cisco phone with both way audio normal/good call .
however cisco  try to reach avay DN in same partion call get disconnected with after some time i.e. 30 to 40 second
and no traces even.
Lalit Arora
Finally a Solution to this issue.
Noticed that the Alert-Info Header is causing the problem, part of the INVITE message being sent out to AVAYA Phone (Third Party SIP device in my case).
Alert-Info: <file://Bellcore-dr1/>
1. Configured a SIP Normalization Script to remove the Alert-Info Header from the INVITE message.
2. Applied the Normalization script to a SIP Profile.
3. Applied the SIP Profile to the Avaya Phone.
4. Test calls were successful both-sided with proper 2-way audio communication.Script.JPG
Thank you Vishal
572
