Incoming calls now working + SIP
I have a UC520 and it runs SIP to the ISP. Outgoing calls works fine but not incoming. The configuration is posted in a .txt file. Anyone that has any suggestions to what it could be?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Incoming calls now working + SIP
Means mismatched codec, see the ITSP doesn't use G.711 that is cisco default. Just put "codec G.711" under the incoming voip DP.
Take "debug ccsip message" with "term mon", this will tell you the error. In most cases, mismatching numbers or codec.
I looked at the debug and I highlighted the reason. But I dont know what the fix is for that?
145
