incoming calls on sip trunk
cisco 2651XM router
IOS: c2600-adventerprisek9-mz.124-15.T8.bin
cme: 4.1
four ip phones:7940G
I have four 7940 phones, two of which (ephone 3 and 4) I use to make PSTN calls over sip trunk. In order for the two phones to be able to call out, both have to be configured with my sip number, but the problem is that when I get an incoming sip call both ephone-4 and ephone-3 rings (naturally) and I'd like it to be that only ephone 3 rings, but both can call out.
attached is the ephone section of my running config. Thanks for any advice.
1 ACCEPTED SOLUTION
Re: incoming calls on sip trunk
Sorry about that,
add 'voice' behind translation-rule 1
Hall of Fame Super Gold
You're not explaining your full setup.
You want two phones to call via sip, and the others ?
This actually isn't the best way to do this.
You would give phones 3 and 4 different DNs, and only phone 3 has the correct DN. Phone 4 would have a dummy DN configured.
And then you do one of two things:
1) sip-ua
calling-info pstn-to-sip from number set
2) outgoing translation profile
translation-rule 1
rule 1 /.*/ /5551234/
translation-profile set-sip-number
translate calling 1
dial-peer voice 1 voip
destination-pattern 9.T
translation-profile outgoing set-sip-number
hth,
nick
thanks for the info, I was following your instructions but when I got to..
vpn(config)#translation-rule 1
vpn(config-translate)#rule 1 /.*/ /5551234/
Incorrect format for Translation Match Pattern
regular expression must be of the form ^(\^)?(\+)?([0-9,A-F.*%?#]+)$
Invalid match pattern string input /.*/
Sorry about that,
ah yes thanks nick I did your config instructions and it now works the way I want. This is great and thanks for your help.
272
