Incoming calls to phone on CME9.1 over FXO
rynard.coetzee
I have a CME 9.1 running at cleint site with FXO port for incoming calls ,when i make a call into the site i can see it matches up with correct dial-peer for ephone but the ephone does not ring. I have Plar opx under voice-port configured.
voice-port 0/1/0
compand-type a-law
connection plar opx 1001
dial-peer voice 1 pots
destination-pattern .T
port 0/1/1
telephony-service
max-ephones 100
max-dn 100
ip source-address 172.17.12.129 port 2000
 timeouts interdigit 5
 max-conferences 8 gain -6
 transfer-system full-consult
 transfer-pattern .T
 create cnf-files version-stamp 7960 Jul 23 2013 07:54:32
ephone-dn  1  octo-line
 number 1001
!ephone  1
 mac-address C40A.CBE0.AAF7
 max-calls-per-button 2
 type 6911
 button  1:1
Manish Prasad
Level 5
Level 5
Can you share the debug please.
Manish
Apr 25 14:38:10.489: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x22D015C0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=1
Apr 25 14:38:10.489: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Apr 25 14:38:10.489: //-1/0EDDDEA0809F/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=1001
   cisco-desttype=0
   ci
andBeyond_NGALA_Tented_RTR#sco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Apr 25 14:38:10.489: //-1/0EDDDEA0809F/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x22D015C0, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=1001(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Apr 25 14:38:10.489: //-1/0EDDDEA0809F/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Apr 25 14:38:10.489: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 25 14:38:10.489: :cc_get_feature_vsa malloc success
Apr 25 14:38:10.489:  cc_get_feature_vsa count is 1
Apr 25 14:38:10.489: :FEATURE_VSA attributes are: feature_name:0,feature_time:996726880,feature_id:60
Apr 25 14:38:10.489: //60/0EDDDEA0809F/CCAPI/cc_api_call_setup_ind_
andBeyond_NGALA_Tented_RTR#common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=1001(TON=Unknown, NPI=Unknown))
Apr 25 14:38:10.489: //60/0EDDDEA0809F/CCAPI/cc_process_call_setup_ind:
   Event=0x22C692E0
Apr 25 14:38:10.489: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 1001
Apr 25 14:38:10.489: //60/0EDDDEA0809F/CCAPI/ccCallSetContext:
   Context=0x3B6A351C
   >>>>CCAPI handed cid 60 with tag 1 to app "_ManagedAppProcess_Default"
Apr 25 14:38:10.493: //60/0EDDDEA0809F/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Apr 25 14:38:10.493: //-1/0EDDDEA0809F/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1001, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1001
andBeyond_NGALA_Tented_RTR#H_DEST
Apr 25 14:38:10.493: //-1/0EDDDEA0809F/DPM/dpMatchSafModulePlugin:
   dialstring=1001, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Apr 25 14:38:10.493: //-1/0EDDDEA0809F/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20001
     2: Dial-peer Tag=1
Apr 25 14:38:10.497: //-1/0EDDDEA0809F/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
Apr 25 14:38:10.497: //-1/0EDDDEA0809F/DPM/dpMatchSafModulePlugin:
Apr 25 14:38:10.497: //-1/0EDDDEA0809F/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=1
Apr 25 14:38:10.497: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   C
andBeyond_NGALA_Tented_RTR#alling Number=1001, Called Number=1001, Peer Info Type=DIALPEER_INFO_SPEECH
Apr 25 14:38:10.497: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Apr 25 14:38:10.497: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=1
Apr 25 14:38:10.497: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1001, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
andBeyond_NGALA_Tented_RTR#abled=0, saf_dndb_lookup=0, dp_result=-1
   Result=SUCCESS(0)
     2: Dial-peer Tag=1
   dialstring=1001, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
     2: Dial-peer Tag=1
Apr 25 14:38:10.497: //60/0EDDDEA0809F/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=FALSE, Mode=0,
   Outgoing Dial-peer=20001, Params=0x3B6A49DC, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Apr 25 14:38:10.497: //60/0EDDDEA0809F/CCAPI/ccCheckClipClir:
   Destination Pattern=1001$, Called Number=1001, Digit Strip=TRUE
   Calling N
andBeyond_NGALA_Tented_RTR#umber=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=0EDDDEA0-CBBE-11E3-809F-EB53713AC66E, Outgoing Dial-peer=20001
Apr 25 14:38:10.497: //60/0EDDDEA0809F/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=1001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Apr 25 14:38:10.497: //60/0EDDDEA0809F/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x3DA3D578, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=1001(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Apr 25 14:38:10.497: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 25 14:38:10.497: :cc_get_feature_vsa malloc success
Apr 25 14:38:10.497:  cc_get_feature_vsa count
andBeyond_NGALA_Tented_RTR#is 2
Apr 25 14:38:10.497: :FEATURE_VSA attributes are: feature_name:0,feature_time:996726656,feature_id:61
Apr 25 14:38:10.497: //61/0EDDDEA0809F/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Apr 25 14:38:10.497: //61/0EDDDEA0809F/CCAPI/ccCallSetContext:
   Context=0x3B6A498C
Apr 25 14:38:10.497: //60/0EDDDEA0809F/CCAPI/ccSaveDialpeerTag:
Apr 25 14:38:10.497: //61/0EDDDEA0809F/CCAPI/cc_api_update_call_info:
   Interface=0x3DA3D578, Call Id=0x3D
Apr 25 14:38:10.501: //61/0EDDDEA0809F/CCAPI/cc_api_call_proceeding:
   Interface=0x3DA3D578, Progress Indication=NULL(0)
Apr 25 14:38:10.501: //61/0EDDDEA0809F/CCAPI/cc_api_call_alert:
   Interface=0x3DA3D578, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Apr 25 14:38:10.505: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Apr 25 14:38:10.505: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Apr 25 14:38:10.505: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     2: Dial-peer Tag=1
Apr 25 14:38:10.505: //60/0EDDDEA0809F/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
   Calling Number=, Called Number=, Peer Info Type=DIALPEER_INFO_SPEECH
   No Outgoing Dial-peer Is Matched;
andBeyond_NGALA_Tented_RTR# Result=NO_MATCH(-1)
   Result=NO_MATCH(-1)
andBeyond_NGALA_Tented_RTR#atchPeersCore:
   Result=SUCCESS(0)
     2: Dial-peer Tag=1
Apr 25 14:38:12.413: //61/0EDDDEA0809F/CCAPI/cc_api_call_connected:
   Interface=0x3DA3D578, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Apr 25 14:38:12.413: //60/0EDDDEA0809F/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=60
Apr 25 14:38:12.413: //60/0EDDDEA0809F/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0x3C, gcid=EDDDEA0-CBBE11E3-809FEB53-713AC66E, tag=0x0)
Apr 25 14:38:12.413: //61/0EDDDEA0809F/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0x3D, gcid=EDDDEA0-CBBE11E3-809FEB53-713AC66E, tag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=60, Call Id2=61, Tag=0x0
Apr 25 14:38:12.413: //60/0EDDDEA0809F/CCAPI/cc_api_bridge_done:
   Conference Id=0x11, Source Interface=0x22D015C0, Source Call Id=60,
   Destination Call Id=61, Disposition=0x0, Tag=0xFFFFFFFF
Apr 25 14:38:12.413: //61/0EDDDEA0809F/CCAPI/cc_api_bridge_done:
   Conference Id=0x11, Source Interface=0x3DA3D578, Source Call Id=61,
   Des
andBeyond_NGALA_Tented_RTR#tination Call Id=60, Disposition=0x0, Tag=0xFFFFFFFF
Apr 25 14:38:12.413: //60/0EDDDEA0809F/CCAPI/cc_generic_bridge_done:
   Destination Call Id=60, Disposition=0x0, Tag=0xFFFFFFFF
   Call Entry(Conference Id=0x11, Destination Call Id=61)
   Call Entry(Conference Id=0x11, Destination Call Id=60)
Apr 25 14:38:12.413: confID:0x11; callEntry1 callID1:0x3C, type:6; callEntry2 callID2:0x3D, type:6
Apr 25 14:38:12.413: //60/0EDDDEA0809F/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3DA3D578, Destination Call Id=61, Source Call Id=60,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Apr 25 14:38:12.413: //61/0EDDDEA0809F/CCAPI/cc_api_caps_ind:
   Destination Interface=0x22D015C0, Destination Call Id=60, Source Call Id=61,
   Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
Apr 25 14:38:12.413: //61/0EDDDEA0809F/CCAPI/cc_api_caps_ack:
   Destination I
andBeyond_NGALA_Tented_RTR#nterface=0x22D015C0, Destination Call Id=60, Source Call Id=61,
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Fax Version:=0, Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3648)
Apr 25 14:38:12.417: //60/0EDDDEA0809F/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1980)
Apr 25 14:38:12.417: //60/0EDDDEA0809F/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
Apr 25 14:38:12.417: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Apr 25 14:38:12.417: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Apr 25 14:38:12.417: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Result=SUCCESS(0)
     2: Dial-peer Tag=1
Apr 25 14:38:12.417: //61/0EDDDEA0809F/CCAPI/cc_api_voice_mode_event:
   Call Id=61
   Call Entry(Context=0x3B6A498C)
Apr 25 14:38:12.417: //60/0EDDDEA0809F/CCAPI/cc_api_voice_mod
andBeyond_NGALA_Tented_RTR#e_event:
   Call Id=60
Apr 25 14:38:12.417: //60/0EDDDEA0809F/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x3B6A351C)
Apr 25 14:38:12.417: //60/0EDDDEA0809F/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x11, Call Id1=60, Call Id2=61
Apr 25 14:38:15.497: //61/0EDDDEA0809F/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x3DA3D578, Call Id=61
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Apr 25 14:38:15.497: //60/0EDDDEA0809F/CCAPI/ccConferenceDestroy:
   Conference Id=0x11, Tag=0x0
Apr 25 14:38:15.497: confID:0x11; callEntry1 callID1:0x3C, type:6; callEntry2 callID2:0x3D, type:6
Apr 25 14:38:15.497: //60/0EDDDEA0809F/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=61, Disposition=0x0, Tag=0x0
Apr 25 14:38:15.497: //61/0EDDDEA0809F/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=60, Disposition=0x0, Tag=0x0
Apr 25 14:38:15.497: //60/0EDDDEA0809F/CCAPI/cc_generic_bridge_done:
Apr 25 14:38:15.497: //60/0EDDDEA0809F/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Apr 25 14:38:15.497: //60/0EDDDEA0809F/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
Apr 25 14:38:15.497: //61/0EDDDEA0809F/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Apr 25 14:38:15.497: //61/0EDDDEA0809F/CCAPI/cc_api_get_transfer_info:
Apr 25 14:38:
andBeyond_NGALA_Tented_RTR#15.497: //61/0EDDDEA0809F/CCAPI/cc_api_call_feature:
   Feature Type=6, Interface=0x3DA3D578, Call Id=61
Apr 25 14:38:15.501: //61/0EDDDEA0809F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3DA3D578, Tag=0x0, Call Id=61,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Apr 25 14:38:15.501: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 25 14:38:15.501: :cc_free_feature_vsa freeing 3B68D778
Apr 25 14:38:15.501:  vsacount in free is 1
Apr 25 14:38:15.521: //60/0EDDDEA0809F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x22D015C0, Tag=0x0, Call Id=60,
Apr 25 14:38:15.521: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 25 14:38:15.521: :cc_free_feature_vsa freeing 3B68D858
Apr 25 14:38:15.521:  vsacount in free is 0
Apr 25 14:38:19.489: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Apr 25 14:38:19.489: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Apr 25 14:38:19.489: //-1/143B27EE80A4/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=1001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdnt
andBeyond_NGALA_Tented_RTR#ype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Apr 25 14:38:19.489: //-1/143B27EE80A4/CCAPI/cc_api_call_setup_ind_common:
Apr 25 14:38:19.493: //-1/143B27EE80A4/CCAPI/ccCheckClipClir:
Apr 25 14:38:19.493: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 25 14:38:19.493: :cc_get_feature_vsa malloc success
Apr 25 14:38:19.493:  cc_get_feature_vsa count is 1
Apr 25 14:38:19.493: :FEATURE_VSA attributes are: feature_name:0,feature_time:996726880,feature_id:62
Apr 25 14:38:19.493: //62/143B27EE80A4/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
andBeyond_NGALA_Tented_RTR#nown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Apr 25 14:38:19.493: //62/143B27EE80A4/CCAPI/cc_process_call_setup_ind:
   Event=0x22C69D38
Apr 25 14:38:19.493: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Apr 25 14:38:19.493: //62/143B27EE80A4/CCAPI/ccCallSetContext:
   Context=0x3B68EE1C
   >>>>CCAPI handed cid 62 with tag 1 to app "_ManagedAppProcess_Default"
Apr 25 14:38:19.497: //62/143B27EE80A4/CCAPI/ccCallProceeding:
Apr 25 14:38:19.497: //-1/143B27EE80A4/DPM/dpMatchPeersCore:
Apr 25 14:38:19.497: //-1/143B27EE80A4/DPM/dpMatchSafModulePlugin:
Apr 25 14:38:19.497: //-1/143B27EE80A4/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=1
   Result=SUCCESS(0)
     2: Dial-peer Tag=1
Apr 25 14:38:19.497: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=1001, Called Number=1001, Peer Info Type=DIALPEER_INFO
andBeyond_NGALA_Tented_RTR#_SPEECH
Apr 25 14:38:19.497: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Apr 25 14:38:19.497: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=1
Apr 25 14:38:19.497: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=SUCCESS(0)
     2: Dial-peer Tag=1
   Result=SUCCESS(0)
     2: Dial-peer Tag=1
Apr 25 14:38:19.497: //62/143B27EE80A4/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=20001, Params=0x3B68D9FC, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Apr 25 14:38:19.497: //62/143B27EE80A4/CCAPI/ccCheckClipClir:
andBeyond_NGALA_Tented_RTR#   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Apr 25 14:38:19.501: //62/143B27EE80A4/CCAPI/ccCheckClipClir:
Apr 25 14:38:19.501: //62/143B27EE80A4/CCAPI/ccCallSetupRequest:
   Guid=143B27EE-CBBE-11E3-80A4-EB53713AC66E, Outgoing Dial-peer=20001
Apr 25 14:38:19.501: //62/143B27EE80A4/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=1001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Apr 25 14:38:19.501: //62/143B27EE80A4/CCAPI/ccIFCallSetupRequestPrivate:
Apr 25 14:38:19.501: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 25 14:38:19.501: :cc_get_feature_vsa malloc success
Apr 25 14:38:19.501:  cc_get_feature_vsa count is 2
Apr 25 14:38:19.501: :FEATURE_VSA attributes are: feature_name:0,feature_time:996726656,feature_id:63
Apr 25 14:38:19.501: //63/143B27EE80A4/CCAPI/ccIFCallSetupRequestPrivate:
Apr 25 14:38:19.501: //63/143B27EE80A4/CCAPI/ccCallSetContext:
   Context=0x3B68D9AC
Apr 25 14:38:19.501: //62/143B27EE80A4/CCAPI/ccSaveDialpeerTag:
Apr 25 14:38:19.501: //63/143B27EE80A4/CCAPI/cc_api_update_call_info:
   Interface=0x3DA3D578, Call Id=0x3F
Apr 25 14:38:19.501: //63/143B27EE80A4/CCAPI/cc_api_call_proceeding:
Apr 25 14:38:19.501: //63/143B27EE80A4/CCAPI/cc_api_call_alert:
Apr 25 14:38:19.505: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
andBeyond_NGALA_Tented_RTR#ECH
Apr 25 14:38:19.505: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Apr 25 14:38:19.505: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     2: Dial-peer Tag=1
Apr 25 14:38:19.505: //62/143B27EE80A4/CCAPI/ccCallAlert:
   Result=NO_MATCH(-1)
Apr 25 14:38:19.509: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Apr 25 14:
andBeyond_NGALA_Tented_RTR#38:19.509: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Apr 25 14:38:19.509: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     2: Dial-peer Tag=1
Apr 25 14:38:20.405: //63/143B27EE80A4/CCAPI/cc_api_call_connected:
   Connection Handle=0
Apr 25 14:38:20.405: //62/143B27EE80A4/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=62
Apr 25 14:38:20.405: //62/143B27EE80A4/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0x3E, gcid=143B27EE-CBBE11E3-80A4EB53-713AC66E, tag=0x0)
Apr 25 14:38:20.405: //63/143B27EE80A4/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0x3F, gcid=143B27EE-CBBE11E3-80A4EB53-713AC66E, tag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=62, Call Id2=63, Tag=0x0
Apr 25 14:38:20.405: //62/143B27EE80A4/CCAPI/cc_api_bridge_done:
   Conference Id=0x12, Source Interface=0x22D015C0, Source Call Id=62,
   Destination Call Id=63, Disposition=0x0, Tag=0xFFFFFFFF
Apr 25 14:38:20.405: //63/143B27EE80A4/CCAPI/cc_api_bridge_done:
   Conference Id=0x12, Source Interface=0x3DA3D578, Source Call Id=63,
   Destination Call Id=62, Disposition=0x0, Tag=0xFFFFFFFF
Apr 25 14:38:20.405: //62/143B27EE80A4/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x12, Destination Call Id=63)
   Call Entry(Conference Id=0x12, Destination Call Id=62)
Would i need the direct-inward-dial on the dialpeer if i use PLAR ?
Not necessary as you have already using Plar-opx.
Try configuring two more commands under FXO port..
caller-id enable
signal groundStart
Manish
