Incoming calls
I have a problem with one user, she can receive internal calls but when calls comes from outside her phone does ring but on the caller's site the phone is ringing. The problem seems to be with her profile but i deleted here profile and recreated the profile again with no luck. Thanks.
Silver
Re: Incoming calls
Could be a dodgy translation pattern which isn't going to her DN, which would explain why it's ringing but not going to her?
Re: Incoming calls
Try tracing the call through the system starting with a q931 debug.
Once into the CUCM, our very good friend 'Route Plan Report' will help you identify multiple instances of a DN or any existance of now traced number.
Alternatively you can reference 'Alternate Matches' in Dialed Number Analyzer.
Re: Incoming calls
thanks for your help, i have tried debug isdn q931 but it just says the debug is on but i cannot see any calls that are made or is there a command that i'm missing.
thanks.
Silver
Re: Incoming calls
Yes, type "term mon" and view the output....
Re: Incoming calls
Thanks, i have already done that and the lines seems to be very busy is it possible for me to specify the number i'm actually trying to trace. thanks again.
Silver
Re: Incoming calls
No, but assuming you know what her number is you should be able to trace with that?
Just do the debug, then phone her number from your mobile and monitor the output.
Re: Incoming calls
i have done that and i have actually dialed numbers that are working and i can trace them on the router but when i dial hers i cannot even trace it on the router.
Silver
Re: Incoming calls
Ok, so when you dial her number you don't see anything on the router but when you dial other people in the same office you do.
Does she definitely have a DDI number like everyone else in the office (is she included in your DDI range)?
Re: Incoming calls
she does have a DDI number like everyone else, her profile was working until she went on leave for a week, the problem started when she came back. They are renting a building in a bank Branch office, the branch gave them 12 numbers that they can use for our cisco IPT but the branch is using a different vendor. IS it possible that the branch may be using this number for themselves bcos on the WAN we can call her , its just calls from PSTN and cellphones that are not going through. Thanks.
Bronze
Re: Incoming calls
Could you pls check with carrier as what digits they are sending. How many digits extension you are using on campus?
Cheers
Ikram
Silver
Re: Incoming calls
Also check the carrier hasn't got any diverts in place.
Re: Incoming calls
i'll have to go and check with them.
Re: Incoming calls
ten full digits.
161
