Incoming external number not appearing in IPT ??
Dears;
can you tell me how to make incoming external number not appearing in IPT,
I have CUCM 8.6.2 and FXO four ports card installed in Cisco router 2800, and I am connect four phone line to FXO, calling process, incoming, and outgoing calls work fine, but when any one call to me there number nut appear on IPT external number only see in screen of IPT, I told PSTN to check ID caller service on my line, and check the service is active on my four line and I do double check by put the line direct to phone and call to me number the number appear on analog telephone but not appear in my IPT when connect to router,I am using MGCP ,
can any one help my please
BR
Mohammad Barghouthi
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: Incoming external number not appearing in IPT ??
I suggest you upgrade your IOS. That IOS is too old. Secondly, when you tested on the analogue phone. when did the caller id display on the phone? after the first or 2nd or 3rd ring?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Can you post your configuration? sh run
and also send the output of
debug vpm signal
I think caller-ID for FXO will not work with MGCP.
VIP Super Bronze
Re:Incoming external number not appearing in IPT ??
Cucm 8.6 supports caller id wiith mgcp on fxo ports
Sent from Cisco Technical Support Android App
Hello aokanlawon;
I am doing the vpm signal debug and see my number in loges my number is 2977595 and called number is 2757770
so the external number 2977595 is appeared on router but not appear on IPT, what is the next step can I do to fixed problem .
please see vpm signal debug in attached
VIP Super Bronze
Do you have caller-id enabled configured on your voice port?
Also can you test to see after how many rings the caller id appeared on the analogue phone? You may need to configure this on the voice port..
voice-port 0/1/0
caller-id enabled
ring number 2---------------------------or 3 depending on after how many number of rings the caller id appeared o the analogue phone
or
voice-port 0/1/0
caller-id enabled
caller-id alerting ring 2
Hello;
already  I am apply two command to four FXO Port. and apply in gateway call manager
caller-id enabled
our IOS  version is
"Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(3g), RELEASE SOFTWARE (fc2)"
is compatible for FXO caller ID with MGCP Or need Upgrade version if yes what is the version need to solve this problem
BR
VIP Super Bronze
Hello;
we upgrade IOS to 12.4(24)6T, after Upgrade and reload router the caller ID appear on IPT, repeated test to same number same FXO Port the problem return "unknown external number".
after that I am applied command #no MGCP and #MGCP, repeated the test the caller ID work first time then make new call to the same FXO port the problem return.
it means the number appear after make  #no MGCP and #MGCP one time then return "unknown external number".
I am reset voice-port on router and gateway on CUCM.
caller id display on the phone after first ring
and apply
#caller ID enable
#caller-id alerting ring 1
#caller-id alerting ring 2
#caller-id alerting ring 3
#caller-id alerting ring 4
how can make caller ID appear ever time,
VIP Super Bronze
Have you tried..
voice-port 0/1/0
caller-id enabled
ring number 1
yes, a do this but the same thing one time appear on each port then not appear to do #no mgcp and #mgcp
voice-port 0/1/0
caller-id enabled
ring number 1
VIP Super Bronze
You can try this command on the voice-port
caller-id alerting dsp-pre-alloc
Hello;
our problem fixed by upgrade version of ISO and apply below command
timing hookflash-out 50
timing guard-out 1000
thanks for all
BR
Dear Sir,
I have the same problem.
Where I can configure this?
Here's my current configuration:
voice-port 0/0/1
cptone BR
connection plar opx 779
caller-id enable
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocate
Thanks.
471
