Incoming FAX via SIP Trunk to an FXS port on an H323 GW
Can anyone let me know how to get this to work? I have read the message boards and have attempted multiple configurations (MGCP, STCAPP), but I cannot get the incoming fax to work. I haven't bothered with outbound yet.
What I have is a fax number that I recently ported to a SIP provider. The call comes in and I can ring the FXS port, but the fax never comes through.
The way I left (open to ALL suggestions though) it right now is; the incoming fax hits the CUBE (Denver), is routed to Call Manager 7.1 (Denver), and the call manager uses a Xlate Pattern / Route Pattern to send it to the H323 gateway  (Pittsburgh).
1) Is there a better way?
2) If not, can I see someone's dial-peers/config who have this working by chance?
3) FYI...there is no VG224 involved here.
Thanks.
Everyone's tags (9)
VIP Super Bronze
On your H323 gateway I assume you have FXS cards on them?. What fax protocol are you using? What fax protocol does your ITSP provider support?
Can you send you configuration (sh run)
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Yes, I have 4 FXS ports.
Trying to set this up using the t38 fax protocol and provider does support T38. I am not getting a lot of help from them so far.
***********************************CUBE******************************************************
dial-peer voice 7000 voip
*** FROM THE CUBE ***
preference 1
destination-pattern [23456789].........
session protocol sipv2
session target ipv4:10.255.201.21 (call manager IP - v 7.1)
session transport udp
incoming called-number [23456789].........
voice-class codec 2
dtmf-relay rtp-nte
no vad
voice service voip
address-hiding
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  emptycapability
sip
  registrar server expires max 3600 min 600
  early-offer forced
  midcall-signaling passthru
  g729 annexb-all
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice class codec 2
***********************************H323******************************************************
dial-peer voice 401 pots
destination-pattern 4231
port 0/2/1
dial-peer voice 3000 voip
*** H3232 Gateway ***
progress_ind setup enable 3
incoming called-number 423[01]
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
no vad
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729br8
codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 3
  h225 timeout setup 2
h225 display-ie ccm-compatible
  telephony-service ccm-compatible
VIP Super Bronze
Can you send the ff debugs from the CUBE
1. debug ccsip messages
2. debug voip vtsp all
3. debug fax relay t30 all-level-1
Re: Incoming FAX via SIP Trunk to an FXS port on an H323 GW
Attached are the log outputs.
303-220-0100 faxed to 412-243-9030.
VIP Super Bronze
I have looked at your trace and there is something that doesnt look quite right during the call setup. Have you edited the IP before sending the trace over..?? In the trace below when cucm sends a 200 ok, it should send the IP address of the h323 gateway where the fax machine resides. However I see the IP address of the CUBE.
Received:
SIP/2.0 200 OK
Date: Fri, 24 Aug 2012 17:05:38 GMT
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
From: "CIBER, INC." <>3032200100@siptrunk.myvtel.com>;tag=1E03E668-13F4
Allow-Events: presence, kpml
Supported: replaces
Supported: Geolocation
Remote-Party-ID: <4231>;party=called;screen=no;privacy=off
Content-Length: 237
Require:  timer
To: <4122439030>;tag=b4eca503-64ba-4efd-ac07-76a365113a0c-30948365
Contact: <4122439030>
Content-Type: application/sdp
Call-ID: D2F8C381-ED4011E1-9B8495D9-6809FCA@10.255.205.22
Via: SIP/2.0/UDP 10.255.205.22:5060;branch=z9hG4bK3BFA71401
CSeq: 101 INVITE
P-Preferred-Identity: <4231>
Session-Expires:  1800;refresher=uas
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 10.255.201.21
s=SIP Call
c=IN IP4 10.255.205.22 (this shuld be the ip add where the fax machine resides)
t=0 0
m=audio 16964 RTP/AVP 18 101
a=rtpmap:18 G729/8000
a=ptime:20
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
1230500: *Aug 24 10:37:37: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4122439030@10.255.201.21:5060 SIP/2.0
Via: SIP/2.0/UDP 10.255.205.22:5060;branch=z9hG4bK3BFA85D0
Date: Fri, 24 Aug 2012 16:37:27 GMT
Max-Forwards: 70
CSeq: 101 ACK
Allow-Events: telephone-event
Content-Length: 0
Can you please do another test call and send me the ff debugs from the h323 gateway
debug voip ccapi inout
debug voip vtsp all
1986
