02-02-2009 03:24 AM - edited 03-15-2019 03:54 PM
Hi Guys,
Probablay a really easy one, but my incoming numbers being displayed on my Cisco Phones are missing the leading zero. so 01603 111111 called and phone says 1603111111 , its causing issues with call number lookup.
Many Thanks
Paul
Solved! Go to Solution.
02-02-2009 05:30 AM
You're welcome. Please remember to rate useful posts with the scrollbox below.
02-02-2009 05:31 AM
You could also use this..
voice translation-rule 2
rule 2 /\(.+\)/ /90\1/ type unknown unknown
rule 3 /\(.+\)/ /90\1/ type national national
rule 4 /\(.+\)/ /900\1/ type international international
voice translation-profile DDI
translate calling 2
02-02-2009 03:36 AM
CM? MGCP or H.323 ?
02-02-2009 04:29 AM
Sorry,
CME 7 and MGCP.
02-02-2009 04:36 AM
What do you mean CME7 and MGCP...MGCP is used with cisco callmanager!!! not CCME
Can you clearify what protocol your gateway is running and what call routing agent you are using..CCM4 or 5 or 6
02-02-2009 04:52 AM
Sorry
I have a CME 7 to which BT are providing 30 IDSN channels over a E1 Serial Interface. The CME is handing all call processing.
Paul
02-02-2009 04:59 AM
You should be fine with the following:
voice-port x/y:15
translation-profile incoming IN
voice translation-rule 10
rule 1 // /0/ type national national
rule 2 // /00/ type international international
voice translation-profile IN
translate calling 10
02-02-2009 05:14 AM
Absolute winner, I always get confused with translation rules.
Thanks Again
Paul
02-02-2009 05:30 AM
02-02-2009 05:31 AM
translate calling 2
