Incoming POTS calls dropped when going to AA/VM, plar/plar opx
I am having problems with incoming PSTN calls. I have the voice-port setup to 'plar opx' to a hunt group. the hunt group rings fine, but the call drops when it is time to transfer to AA (final for the hunt group).
I think it's a dial-peer problem, but I'm not sure what to do about it.
I've noticed that if i change from 'plar opx' to just 'plar', it works fine. what are the differences between plar and plar opx, and how could it cause this behavior? should i just leave it at 'plar' or should it really be 'plar opx'? I haven't noticed any side effects, yet.
Here is some of the voice config:
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 800
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 801
b2bua
codec g711ulaw
no vad
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number .%
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
corlist outgoing call-local
description ** FXO pots dial-peer **
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 5
destination-pattern 9[2-9]......
port 0/1/0
forward-digits 7
no sip-register
dial-peer voice 55 pots
corlist outgoing call-domestic
preference 5
destination-pattern 91[2-9]..[2-9]......
port 0/1/0
prefix 1
no sip-register
dial-peer voice 56 pots
corlist outgoing call-international
preference 5
destination-pattern 9011T
port 0/1/0
prefix 011
no sip-register
dial-peer voice 57 pots
description ** FXO pots dial-peer **-Emergency dial-peer
preference 5
destination-pattern 9911
port 0/1/0
forward-digits 3
no sip-register
dial-peer voice 58 pots
preference 5
destination-pattern 911
port 0/1/0
forward-digits 3
no sip-register
dial-peer voice 59 pots
preference 5
destination-pattern 9[2-9]11
port 0/1/0
forward-digits 3
no sip-register
Silver
Re: Incoming POTS calls dropped when going to AA/VM, plar/plar o
http://www.cisco.com/en/US/docs/ios/12_3/vvf_r/vrg_c4_ps1839_TSD_Products_Command_Reference_Chapter.html#wp998575
Specifies a PLAR off-premises extension (OPX) connection. Using this option, the local voice port provides a local response before the remote voice port receives an answer. On Foreign Exchange Office (FXO) interfaces, the voice port does not answer until the remote side has answered.
From me:
If you didn't have any of the PLAR commands on the voice-port then the router will answer the incoming call after the first ring and present a dial-tone. (two-stage dialing.) The router is in essence expecting DTMF digits to be played. You can manually dial an extension to ring the final IP Phone.
You are not looking for that. The PLAR command will pickup the voice-port after the first ring then send the digits of the plar command to the router--matching an incoming-called number command.
OPX prevents the Voice-port from going off-hook after the first ring. It will only go off hook after the IP Phone goes off hook
This is useful when other devices share the POTS line, like an answering machine or cordless phone, which might want to answer the phone by themselves.
But may not work for hunt-groups or other entities that don't send an off-hook message.
So regular plar is fine.
Hall of Fame Super Gold
Michael,
actually hunt-groups and all cisco "entities" do "send an off-hook message" when the calls is answered.
If you are using an hunt-grop without AA, it's correct to use OPX so that caller will not be charged for non-answered calls.
I think the problem is due to some bug in the IOS used, CUE AA should take a forwarded calls even if OPX was specified.
So depending if you want to give caller the chance of hanging up before going to VM without being charged, you would use OPX as well.
In any case VM and FXO will need a supervisory disconnect configuration, but that's another issue.
206
