Incoming sip call are rejected
When I receive an INVITE on a SIP trunk, I got a 404 not found.
I got this message in the log:
DOES NOT MATCH top level org domain
If I reset the trunk, everything is ok after. This error occurs after a shutdown of the server (Power outage).
Silver
Re: Incoming sip call are rejected
If you see a incoming SIP call being rejected by sending a 401 Unauthorized reponse to INVITE. then Define a new softswitch trunkgroup with the IP address or domain name used in the FROM field of incoming calls INVITE message.
Dear Richard,
Did you came accross any cause and/or solution to this matter? Something similar is happenning to us. in our case qe get the 404 code when we bandwitdh of the called location is fully in use and we receive a new call for that location.
Best regards,
Amaia Lesta
442
