incoming sip calls are not working but outgoing is working with cme
I have CME setup with voip.ms on my 2800 router, my outgoing calls are working  but my incoming calls are not.  Below is my config, please let me know if it is something with my config:
voice translation-rule 3
 rule 1 /^9142281\(...\)$/ /\1/
voice translation-profile INCOMING_CALL_1
 translate called 3
dial-peer voice 1 voip
 translation-profile incoming INCOMING_CALL_1
 session protocol sipv2
 session target sip-server
 incoming called-number .%
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
Everyone's tags (2)
VIP Gold
Dear, Please attach 'debug
Dear, Please attach 'debug voip ccapi inout' for an incoming test call & sh run.
Suresh
The debug showed no output
The debug showed no output when I called, I verified that I do own this number on voip,ms
Attached is my config
VIP Gold
Did you check the same doing
Did you check the same doing 'show log' ? and Can you check below debug for one call as well.
deubg ccsip messages
If you will not get any debug messages, that means call is not hitting to router and in that case you need to ask to service provider.
Suresh
So I contact voip.ms and I
So I contact voip.ms and I got that issue resolved, I am able to see the call on my gateway.  Turns out it was not yet registered.  But the calls are not redirecting to my extension:  Attached is my output of debug ccsip messages
VIP Gold
Dear, You have configured
Dear, You have configured below translation profile wrongly. It should be "translate called 3" so modify it once and try. If still issue persists then attach 'debug voip ccapi inout'
 translate calling 3
Suresh
I made the change, but I am
I made the change, but I am getting no output from debug voip ccapi inout.  What does concern me from debug ccsip messages is:
Aug 31 12:42:04.195: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request - 'Invalid Host'
Via: SIP/2.0/UDP 107.6.67.238:5060;branch=z9hG4bK000d3c36;rport
From: "+19144410197" <sip:9144410197@107.6.67.238>;tag=as7439b9c1
To: <sip:9142281462@108.54.238.199:1061>;tag=829C8-2532
Date: Sun, 31 Aug 2014 12:42:04 GMT
Call-ID: 2b4b66bd109bfeea6f4e15b403fb5514@107.6.67.238:5060
CSeq: 102 INVITE
Allow-Events: telephone-event
Reason: Q.850;cause=100
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
I also am getting this:
voicertr2#debug ccsip error
SIP Call error tracing is enabled
voicertr2#
Aug 31 12:45:07.359: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 31 12:45:07.359: //-1/78AE76E98009/SIP/Error/sact_idle_new_message_invite: Invalid URL in incoming INVITE
I found the issue, I had to
I found the issue, I had to put a destination in my config for the dial-peer.  Below is the config for the incoming dial-peer
 destination-pattern .T
 voice-class sip bind control source-interface FastEthernet0/0.50
 voice-class sip bind media source-interface FastEthernet0/0.50
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
according to your config
voice translation-rule 2
 rule 1 /^.*/ /9142281462/
incoming called number is 9142281462
and it is translated to 1462
but you have two numbers 462 462
so you can fix it, making it simple and easy to understand
 rule 1  /^9142281462/  /462/
 rule 2  /^9142281463/  /463/
if it is not helps
so do
clea logg
deb ccsip mess
make call
sh logg
and dont forget to rate post
1233
