Incoming SIP calls dropped on call-forward
We have a range of SIP numbers in CME4 set up as dial-peers (so they can authenticate with their appropriate username / passwords):
dial-peer voice 670583 pots
description x2603 David
destination-pattern 670583
port 0/3/1
authentication username 670583 password xxx
And these are mapped thru to ephone-dn's, such as:
ephone-dn 24
number 670583 no-reg both
label x2603
description David Deskphone
call-forward noan 7123 timeout 25
However, when an external call comes into this SIP number, the e-phone-dn rings correctly, but upon call-divert, the call is dropped.
x123 is an Asterisk voicemail (SIP client, trunk 7T, ext 123).
All works fine with a similarly configured pots dial-peer for an FXO interface.
Can anyone suggest where I'm going wrong?
br/
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Incoming SIP calls dropped on call-forward
Please upgrade to 12.4(11)XJ4 and you should be able to configure the feature.
Try:
voice service voip
no supplementary-service sip moved-temporarily
My system is a 2811 running c2800nm-adventerprisek9-mz.124-11.T.bin, and under "voice service voip" I don't have a "sip" option under supplementary-service, just Hxxx. Any ideas?
br
Sorry for the delay in responding - but we had to wait for a window to upgrade the image. Your one line solved our call-forward problem instantly, and we are sincerely grateful. A+++ Netpro.
Glad to know it worked. Thanks for the nice rating and good luck!
Silver
Hmm... interesting. I notice that this release is solving many GW related SW defects - huh?
Ajaz
Yes, many indeed.
195
