Incoming translation rule
dorelp777
When i dial someone from the corporate directory it dials the full number ( eg 08 1234 5678) , even thou the person is internal, it set this way due to click to dial ( long story) . When the call is received you see the number 08 1234 5678 rather then Joe Blogs 5678
how can i create some translation patterns where from set ranges for example 08 1234 56XX and 08 1234 57XX when it hits cucm it strip the first 8 digits and just presents the 4 digit extentsion so that means you will also see the persons name come up
much appreciated.
Ayodeji Okanlawon
Just configure a translation pattern in cucm using a different partition to that of the route pattern and make sure this partition is higher than the partition of the route pattern
Please rate all useful posts
