Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Incoming translation rule
When i dial someone from the corporate directory it dials the full number ( eg 08 1234 5678) , even thou the person is internal, it set this way due to click to dial ( long story) . When the call is received you see the number 08 1234 5678 rather then Joe Blogs 5678
how can i create some translation patterns where from set ranges for example 08 1234 56XX and 08 1234 57XX when it hits cucm it strip the first 8 digits and just presents the 4 digit extentsion so that means you will also see the persons name come up
much appreciated.
1 REPLY
VIP Super Bronze
Just configure a translation
Just configure a translation pattern in cucm using a different partition to that of the route pattern and make sure this partition is higher than the partition of the route pattern
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
38
