Community Member
Inconsistent results making international calls
Issue: Inconsistent results making international calls (able to make a call to Zurich, but not London). Assumed it was a carrier issue. Carrier (MCI) took a d-chan capture on calls to the UK -- tech indicated he was seeing call type "Int'l ISDN with 011" and explained that the NI2 is sending the 011 and our PBX is sending the 011 - causing the failed call. I am not sure I follow the "NI2 is sending". The tech then took a d-chan capture of a call to Switzerland and indicated he was seeing call type "unknown with 011" and further indicated call is successful because there is only one 011 sent. Both calls take place on the same PRI facility. Including all relevant config lines below.
- After some Internet reading, I came across a suggestion indicating -- navigate to 'Call Type' and change the International Call Types to 'Unknown'. This seemed relevant, but unfortunately the post did not reference a Cisco gateway. Does anyone know of a similar config parameter on a Cisco router?
- Can I issue a command that will allow the router to make a call (so I do not have to bother the local clients)?
Router#isdn test call interface Serial0/0/0:22 19145551212
the first few messages appear like this would work, but then the first hint that this is not correct:
Oct 8 03:25:48.721: ISDN Se0/0/0:23 **ERROR**: call_setup_ack_proceeding: NO HDLC available b channel 22 call id 0x838B
Oct 8 03:25:48.721: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x040A
Cause i = 0x80A2 - No circuit/channel available
What do I have wrong?
- I assume a next step would be to capture the calls from the CME's perspective. What are the appropriate debugs to run to determine why calls do not complete (debug isdn q931, debug voice dialpeer)?
The site is new, extremely low key, has only 15 phones and the site is generally < 50% occupied. Are there any debug concerns with respect to router load?
Relevant system info:
System CUCME running on C2821 ISR
Cisco IOS Software C2800NM-ADVENTERPRISEK9-M
Software Version 12.4(20)T / CME 7.0(0)
Relevant carrier Info:
Product: PRI (1) with 40 new numbers
CDDD: 8/11/2008
Signaling: 23 B Channels + Primary D
Framing/Coding: B8ZS/ESF
Protocol: NI2
Outpulsing Digits: 4
Hunting: Aseq/Dseq
Pic: 0222 (MCI) for Local, LD, and International
Relevant configuration:
isdn switch-type primary-ni
voice translation-rule 1
rule 1 /^\(21..\)$/ /781xxx\1/
voice translation-profile ANI
translate calling 1
controller T1 0/0/0
framing esf
linecode b8zs
cablelength long 0db
pri-group timeslots 1-24
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
voice-port 0/0/0:23
translation-profile outgoing ANI
dial-peer voice 5 pots
description International dialing
destination-pattern 9011.T
port 0/0/0:23
prefix 011 <--- is it possible that using forward-digits as opposed to prefix would result in a different outcome?
1 ACCEPTED SOLUTION
Community Member
Re: Inconsistent results making international calls
Had a similar problem recently. Needed to stop CME from sending International signal and 011 simultaneously as it confused the carrier:
isdn map address 011.* plan unknown type unknown
My dial peer looks the same as yours except the destination-pattern is 9011T
Try the csim command to make calls from the IOS:
csim start 9011
(enable isdn debug logging first)
can u make it explicit matching i mean ur dial-peer liek :
if u send 11 digit with 011 make it like
destination-pattern 9011.......
port 0/0/0:23
forward-digits 11
Community Member
csim start 9011
Community Member
Hi Frank....
Thanks very much for the feedback. Your recommendation worked. However, I was curious if you also had the issue of inconsistency -- I am confused why some calls used Unknown/Unknown while others used the ISDN/International -- not sure if you know why or did not go deeper once you had a solution.
With regard to making the call from the router, I tried the command you provided and it looks more or less like what I get with the command I had tried. I think my misunderstanding was that it would actually make a call to my phone. Is this possible? I used to be able to do this on a legacy Nortel.
....jeanne
PS - For anyone else interested in the link that explains the isdn map command, the link is:
http://www.cisco.com/en/US/docs/ios/12_3t/dial/command/reference/dia_i2gt.html#wp1212108
Community Member
I am having the same issue I think. I have a US ip phone-cme-vpn-cme-ip phone london and this works fine. I added nortel PBX--US CME--VPN--CME--London and it shows plan Private type unknown but the Cisco shows unknown and unknown (which calls work) our Nortel vendor doensnt know how to get it configured for unknown unknown.
Community Member
I think it might be these parameters in the RDB (LD 16):
OGNP a...a Outgoing Numbering Plan (a...a = (UKWN), PUB, or PRV)
OGNT a...a Outgoing Numbering Type (a...a = (UKWN), INTL, NTN, LCL,
LOC, CDP or SPN)
Community Member
For the Nortel PBX?
Community Member
Yes. Sorry for my assumption on your being familiar with the Nortel "LD 16 - RDB" lingo. RDB is route data block and where you would set the ISDN PRI parameters on the Nortel PBX.
310
