Community Member
Incorrect Caller ID on calls from outside line via FXO port.
   Have a public phone line connected to my CUCME 2801 router VIC2-2FXO card. All inbound calls are passed to DN-5001 (group number). Can receive and send calls without a problem, but incoming calls all show "911" for caller ID. Think this is simply an issue with the out bound dial-peer, of which the lowest numbered out bound dial-peer is for 911 services. Not sure how to correct this so inbound calls show the proper caller ID?
    Below is a copy of my CUCME show run output from the FXO port config thru all the dial-peers. Any pointers is greatly appreciated.
    Thanks.
           Kirk E.
voice-port 0/0/0
connection plar opx immediate 5001
voice-port 0/0/1
voice-port 0/2/0
station-id name POTS
station-id number 7000
voice-port 0/2/1
ccm-manager config
dial-peer voice 7000 pots
destination-pattern 5006
port 0/2/0
dial-peer voice 90 pots
description Emergency Services
destination-pattern 911
port 0/0/0
forward-digits 3
dial-peer voice 91 pots
description 10 Digit local dialing
destination-pattern [234].........
port 0/0/0
forward-digits 10
dial-peer voice 92 pots
description 11 Digit local/long distance dialing
destination-pattern 1[2348].........
port 0/0/0
forward-digits 11
dial-peer voice 93 pots
description Long Distance
destination-pattern 011T
port 0/0/0
prefix 011
dial-peer voice 94 pots
description Backup bench POTS phone
destination-pattern 7000
port 0/2/0
dial-peer voice 2 voip
destination-pattern 51..
session protocol sipv2
session target ipv4:172.16.2.155
dtmf-relay sip-notify
codec g711ulaw
no vad
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Incorrect Caller ID on calls from outside line via FXO port.
Correct, always shut/unshut.
Please mark the question as answered if you have no further questions.
Chris
Add "caller-id enable" to the voice-ports.
Chris
Community Member
Chris,
     Thanks, but that didn't work.
     I added "caller-id enable" to voice-port 0/0/0 (where the outside line plugs in) but it did not fix the issue. Called again and still got 911 as the caller-id. I know a good caller-id is being passed in because it shows up on a POTS phone tied off the same line.
                  Kirk
Perhaps caller ID is not available on the line, please provide the following:
debug vpm singnal
debug voice ccapi inout
Chris
Can you find the below:-
1- Please find the below table  as the following link  http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b53c7.shtml
Caller ID          Requires VIC-2FXO-M1, VIC-2FXO-M2, VIC-4FXO-M1, VIC2-2FXO, VIC2-4FXO, or MRP3-8FXOM1
under voice-port
caller-id enable
2-If above configure and still have no caller id , please add the below commannds to the voice-port
caller-id alerting line-reversal
cptone ?               "based on your"
caller-id alerting ring 2    "the default is 1" maximum number of rings to be detected before a call is answered over an FXO voice port.
4-Do debug to make sure all ok
"debug vpm signal "
[0/3/0] get_fxo_caller_id:Caller ID received. Message type=128 length=31 checksum=74
Thank you
please rate all useful information
I've seen this before, try this:
current setting:
port 0/0/0
forward-digits 3
new:
destination-pattern 91[1] <-- Modify the pattern like this
or
destination-pattern 91[.]
Just avoid a complete number match, I prefer the first one.
Give it a try and let me know.
~jorge
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Community Member
All,
     It is working now. After I added the caller-id enable I didn't stop, start the interface. Took me a bit to think of that. Now it is working well.
     Thanks to all.
                   Kirk
Congratulations for you , please donot forget to rate all useful information for all of here.
Thank you
Chris
439
