Incorrect time on CME phone display.
Hall of Fame Super Gold
This is asked very often, have you tried searching before asking ?
Yes, I did creating cnf files under telephony services and  then reset all phones. it doesnt worked out.
please assist me on this.
Re: Incorrect time on CME phone display.
Maybe if you could take the time to read in full from the search results, as indicated above that would help you better.
under the telephony-service -
no create cnf-files
create cnf-files
Then reboot the individual phones
Whether above one is solution
Hall of Fame Super Red
Hi Karthikeyan,
Try the steps in this doc (pay special attention to Time Zone & phone model type)
Troubleshooting Incorrect Time Stamp on IP Phones in Cisco Unified CME
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/troubleshooting/guide/ts_time.html#wp1053981
Cheers!
Rob
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 2
sdspfarm tag 1 conferenceprof
sdspfarm tag 2 transcodeprof
conference hardware
no auto-reg-ephone
authentication credential admin cisco
max-ephones 110
max-dn 200
ip source-address 10.231.2.5 port 2000
max-redirect 20
service phone settingsAccess 1
timeouts ringing 60000
system message Nielsen - Chennai
url services http:///voiceview/common/login.do
url authentication http:///voiceview/authentication/authenticate.do
load 7942 SCCP42.8-4-2S.loads
load 7962 SCCP42.8-4-2S.loads
time-zone 39
time-format 24
date-format dd-mm-yy
voicemail 2100
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
hunt-group logout HLog
moh music-on-hold.au
web admin system name admin password cisco
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 0
directory entry 1 555 name HelpDesk
create cnf-files version-stamp 7960 Feb 02 2012 07:56:02
I reset all phones ,. still am not getting correct timing on all phones. phone type : 7942
Did you ever get this resolved?  If so what was the resolution?
Hello
you can configure as below and it will help
router# clock   (type your date and time)
router (config)# clock tomezone (name) (x)
router(config)# clock summer-time
telephony -service
time-zone X
time-format 24
no Create-cnf
create-cnf
Thank you
please rate if this will help
Hi, I have the same issue, I could resolved it pointing to a NTP server because my clock on CME was incorrect. What is your IOS version? Regards.
I had the same problem too
I had the same problem too and I solved it as follow:
router(config)# clock timezone zone hours-offset
router(config-telephony)# clock time-zone number
1766
