increase time between digits
Dear Experts,
Can I increase time between digits (disconnect time) .
That will be if dialing any external number (PSTN Number) such as 00962777556669 and I stop dial the digits after 7 digits (dial 009627 and stop) so I will get a disconnect message. So how I can increase this time??
Hall of Fame Super Gold
Re: increase time between digits
Hi, you have asked this in otheer forum as well, please contain posts to a single place.
Anyway, you need to mention what exact system do you have.
This option is specified using the "timeouts interdigit" command under "Telephony Service"
The default is 10 seconds.
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/dial_peer/dp_plan.html
Hello Islam,
I have to add to please beware when changing your inter digit timeout, especially when working with international dian plans.
Justin
115
