10-08-2013 10:31 AM - edited 03-16-2019 07:46 PM
Hello TAC indicated that the Informacast application is only available to be installed on a virtual server. I wanted to verify that and also see if we do install Informacast on a VM is it supported/will it work in the Communication Manager is on a physical server? Yes, there would be network connectivity. CUCM is 9.1
Thanks in advance. All replies rated.
Solved! Go to Solution.
10-08-2013 11:12 AM
10-08-2013 11:12 AM
Sure, it will.
Chris
10-08-2013 02:46 PM
Thanks Chris!
