Community Member
Informacast Paging
Hello TAC indicated that the Informacast application is only available to be installed on a virtual server.  I wanted to verify that and also see if we do install Informacast on a VM is it supported/will it work in the Communication Manager is on a physical server?  Yes, there would be network connectivity.  CUCM is 9.1
Thanks in advance.  All replies rated.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Informacast Paging
Sure, it will.
Chris
Informacast Paging
Sure, it will.
Chris
Community Member
Informacast Paging
Thanks Chris!
153
