Inline power for CISCO 79xx standard phones
I need a solution to provide inline power to standard CISCO 79xx phones from a non-proprietary POE switch without utilizing a power brick. The switch in this case is a D-Link DES 1228P.
Hall of Fame Super Gold
Re: Inline power for CISCO 79xx standard phones
Which phone model exactly? If standard PoE, it should work.
currently have 7960, 40, and 7911 series deployed on a CCM 4.2 sr3
If it's standard 802.3af/IEEE it should work. Just looked this switch up and yes it supports 24 Ports IEEE 802.3af PoE.
http://www.dlink.com/products/?pid=541
Just beware that some of the older Cisco IP phones may not support 802.3af POE and only support Cisco Pre standard (http://www.cisco.com/en/US/products/hw/phones/ps379/products_qanda_item09186a00808996f3.shtml#qa4).
Hall of Fame Super Red
Hi Joseph,
Because you are using a non-Cisco switch that provides 802.3af PoE. The problem is that the 7940,7960 and other older Cisco phones use a pre-standard power and not 802.3af PoE which this manufacturer uses. The 7911 should be good to go :)
Q. What IP phone models support the Cisco pre-standard method of powered device detection?
A. These Cisco IP phones can accept Cisco pre-standard PoE from a card integrated with a Cisco Catalyst switch or a Catalyst in-line power patch panel:
7985G
7960G
7940G
7910G
7910G + SW
7912G
7905G
7902G
These phones can draw local power from a power cube (CP-PWR-CUBE-2=) in addition to a country or regionally specific power cord (CP-PWR-CORD-xx=).
Q. What IP phone models support the IEEE standard method of powered device detection?
A. These Cisco IP phones support IEEE 802.3af PoE:
7961G-GE
7971G-GE
7931G
7911G
7941G-GE
Note: These Cisco IP phones support both the Cisco pre-standard PoE and IEEE 802.3af PoE:
7970G
7961G
7941G
7906G
From this great doc;
Power over Ethernet (PoE) Power Requirements FAQ
You probably need a third party product like;
http://www.microsemi.com/PowerDsine/Products/Midspan/Splitters/
Hope this helps!
Rob
Or you can put a Cisco aironet power injector between ip-phone and switch.
Greets,
Norbert
475
