Community Member
insert pause when dialing
I saw that if you put a "," in some componen in CRA Editor it is translated in a pause of 1 second. example #1234,5678 it dials 1234 then wait 1 second, then dials 5678.
How can i obtain the same functionality on jtapi class?
Re: insert pause when dialing
I thought I had read that CallManager does not recognize pauses. Unless you are using some sort of IPCC script.
Community Member
I found how to generate DTMF tones whit the metod generateDtmf(String) of the interface MediaTerminalConnection. Can some one tellme how i can use it
Community Member
179
