Community Member
Insight required on CCME
hi
i recently purchased the cisco 2811 ccme/k9
bundle with pvdm2-16, the ccme came with 36 phone lic.
i also bought the VIC2-2BRI-NT/TE to connect to my phone lines.
this is my first ip telephony setup.
ive read through all documentation, yet i dont know where to begin.
any and all help will be much appreciated.!!
Hall of Fame Super Gold
Re: Insight required on CCME
From config mode, you can run "telephony-service setup". Begin from there, then the additional commands will be added as necessary, and you can you can ask here.
If you have 2 BRi, configure them in trunk group, and reference this in your dp:
voice-port x/y/0
companding
trunk-group telco
voice-port x/y/1
companding
trunk-group telco
dial-peer voice 9 pots
destination-pattern 9...T
trunkgroup telco
Community Member
thank you
thats a begining!
Community Member
i have to configure both bri interfaces before i put them in a trunk group, right?
doing this will give me the "2nd line" ?
The Call Manager Express documents on Cisco.com are really good; however, if your new to CCME they can be a little challenging to piece together.
There is a Cisco Press book that I like that lays out CCME from start to finish and will really help get you up and running. It is call IP Communications Express: Call Manager Express with Cisco Unity Express.
There is an Adobe copy that you can download and get started without having to wait for a physicall book to ship. The link is posted below.
http://www.ciscopress.com/bookstore/product.asp?isbn=1587053918
Hope this helps. Please Rate All Helpful Posts!!
Community Member
im going to need some help configuring the bri's as well...
this is what ive got for the bri
interface BRI1/0
no ip address
isdn switch-type basic-net3
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
line-power
but after i do this, i cant get the
voice-port ??
Community Member
ALRIGHT!!i got the router to dial out!
under the show isdn status all was good
however, i still couldnt get the voice-port command...??
Community Member
through all the doc's that ive seen,
all of them have the voice-port.
perhaps im doing something in the wrong order?
what steps do i need to follow next,
in order to be able route my incoming calls to the appropriate phone?
ahh...i didnt mention in my original post how my network is layed out..
i have my cisco router 2811...and anything that comes into it is forwared by nat out the fa0/0 interface where there is a asa5505.
my vlans reside from there on out. my router doesnt have any vlan configurations. the asa5505 take what ever comes into its outside port and forwards it to the appropriate vlan. after the asa 5505 i have a cisco catalyst express500...
so basically, what are the steps (in general or not) that i need to follow to get the voice routed inside.
ive added my bri interfaces so you can have a proper look:
interface BRI0/1/0
no ip address
no logging event link-status
isdn tei-negotiation first-call
isdn point-to-point-setup
isdn sending-complete
trunk-group my-trunk
interface BRI0/1/1
no ip address
trunk-group my-group
thanks
180
