Community Member
Install CUCM 6.1 on Proliant DL360 G4
I am trying to instal CUCM 6.1 on a HP Proliant DL260 G4. When I go to install I get the below error.
The hardware you are using is not supported for this product. installation will now halt.
I found another forum that said the the DL360 was compatable? Is that true and is there a way around the error I am getting?
1 REPLY
Re: Install CUCM 6.1 on Proliant DL360 G4
Refer to this link for supported platforms
Cisco Unified Communications Manager Server Support Matrix
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Or EXACTLY match the specs found here www.cisco.com/go/swonly
PCD will look for those specs, if the server does not meet them it won't install
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
250
